Old 04-22-2015, 07:51 AM   #1
1999 25' Safari
Winamac , Indiana
Seelevel 700 series monitor from Garnet
I am new to the AS forums. My 99 Safari (which I have owned since new) fresh water qty. lights finally quit this season. Knowing all the problems with older monitoring systems & AS not having wiring prints for my year, I'm wondering if anyone has installed the Seelevel 700 series monitoring sys from Garnet on their trailer. I really like the simplicity of their system, but getting access to the tanks is my big Q to install the strips.
Thanks for any thoughts.
Robo104 is offline   Reply With Quote
Old 04-22-2015, 08:21 AM   #2
ghatfield's Avatar
2006 19' Safari SE
Anacortes , Washington
Installed one in my '06 Bambi.... love it.
See http://www.airforums.com/forums/f444...-a-129739.html
George
ghatfield is offline   Reply With Quote
Old 04-27-2015, 06:31 AM   #3
trekerboy's Avatar
1979 31' Excella 500
Charlevoix , Michigan
I use this system. We installed it during the initial stages of our renovation, so it was easy to access the tanks from the ripped-up floorboards.
I highly recommend it as a replacement for the old system. In your case, might be easier to access the tanks for installation of the strips by removing a section of the belly aluminum, but only do that if you're willing to work with rivets to replace the belly paneling when you're done.
trekerboy is offline   Reply With Quote
Old 04-28-2015, 06:35 PM   #4
grizbear's Avatar
2004 25' Safari
Crestview , Florida
tank monitor
Did you have to rewire or can you use existing wiring?
grizbear is offline   Reply With Quote
Installing new Seelevel 700 series monitoring sys Robo104 1999 Safari 0 04-21-2015 03:09 PM
Tank side wall height for SeeLevel Sensors? mtntime Plumbing - Systems & Fixtures 1 06-15-2012 10:26 AM
SeeLevel II display not working johnandlauri General Repair Forum 0 09-17-2010 08:09 AM
Seelevel Monitoring Systems rickandsandi Waste Systems, Tanks & Totes 3 10-13-2009 07:48 AM
SeeLevel Gauges 68 Overlander Commercial Listings 11 07-11-2007 11:12 AM
