Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 10-14-2006, 03:50 PM   #1
Profile:  1985 34' Excella
Houma , Louisiana
Question Second Trailer - Wiring problem
The 1985, 35' Excella that I have now is the second Airstream I have owned. At present I am repairing some electircal damage that was caused by Voltage Surges during Hurricane Katrina. Our town was hit by both Katrina and Rita last year. I am changed out the converter and have allready changed out the refrigerator. Both were damaged by the storms. I have a problem with a black wire, small guage that comes off of the origonal converter and I am not sure where to tie it into the new converter, as there seems to be only ground, and the two large negative and positive wire positions on the new Intellavolt converter. Does any one know where it connets at?
jronhunt is offline   Reply With Quote
Old 10-14-2006, 05:18 PM   #2
InsideOut's Avatar
Profile:  1964 19' Globetrotter
1956 22' Safari
Only Airstreamer in Edgewater , Colorado
Images: 87
Airstream Registry
Welcome to the forums!
I have moved your thread into the Electrical Forum where someone may "in the know" will be more likely to find it and help you.
Hope you are well on your way to recovery from those "bad girls"...hang in there!
Shari
RMVAC | WBCCI DenCO Unit | Maxwell | Birdy
Old 10-15-2006, 11:34 AM   #3
Profile:  1986 31' Sovereign
jonesboro , Arkansas
odd wire out
If you have every thing else hooked up you can check individual items ie: frig,heater blower ,lights etc to find out what does not work.Also red and black wires are usually hot wires not grounds.Good luck
joel is offline   Reply With Quote
two tiny orange lights on left front side trailer overlander Lights - Interior & Exterior 25 12-03-2008 07:50 PM
Trailer lights Dbraw Electrical - Systems, Generators, Batteries & Solar 1 09-13-2002 04:51 PM
New years added to Trailer Forum 83Excella Our Community 3 07-08-2002 06:24 AM
Trailer tire article 83Excella Tires 0 06-10-2002 09:20 PM
Trailer Listing To "Street Side" montanaandy Axles 4 06-07-2002 12:15 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
