Old 08-31-2013, 05:19 PM   #1
Desert64's Avatar
1964 26' Overlander
Bend , Oregon
Scare light replacement and wiring
Hi everyone,
A newbie here trying to replace the exterior lights on our '64 Overlander. Once I took off the old scare light, and gobs of goo that surrounded, it I found two wires. Once I pulled in them a bit the two were pig tailed to a single orange heavy gauge wire. Probably 10AWG. Anyone know what is going on here? Is this right? Also the switch inside the door (other side of window) doesn't seem to have any effect on this wire when connectivity was checked with a voltmeter. Anyone fought this battle already?
Desert64 is offline   Reply With Quote
Old 09-01-2013, 01:03 AM   #2
57BB's Avatar
1964 26' Overlander
1954 29' Liner
Washington , Washington, D.C.
Yep that orange wire is a dedicated 12v line that runs from the rear hatch (electrical circuit breaker area under the bath bench) along the street side up to the overhead bin on the front then over the window down to the scare light. In total it is the power or positive side of the circuit powering the 12v outlets next to the bath mirror, the one next to the TV antenna on the street side, the radio in the overhead and the scare light. It would allow those things to work directly from the battery. The outlets were grounded individually to the trailer body. The orange cover is a pain to remove if you need to but overall it should be in great shape to reuse.
57BB is offline   Reply With Quote
Old 09-01-2013, 06:18 AM   #3
57BB's Avatar
1964 26' Overlander
1954 29' Liner
Oops one more thing the two black wires connect to the toggle switch inside the wall. This provides power to turn the light off and on.
Old 09-01-2013, 01:26 PM   #4
Desert64's Avatar
1964 26' Overlander
Bend , Oregon
Wow. Thanks a ton. That really helps. Previous owner snipped the two wires so looks like I'll be drilling some rivets to get to it. Thanks again.
Old 09-01-2013, 02:56 PM   #5
57BB's Avatar
1964 26' Overlander
1954 29' Liner
Sure and please let me know how it works out. I'm almost finished restoring my 64 Overlander got a thread on here about if you're interested. I'd enjoy seeing pics of yours
Michael
Old 09-01-2013, 03:05 PM   #6
Excella CM's Avatar
1978 31' Excella 500
Venice , California
Check out the threads on modifying the lights to l.e.d.s
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 09-01-2013, 04:24 PM   #7
Desert64's Avatar
1964 26' Overlander
Bend , Oregon
64 Overlander restoration
Will do 57BB. We're just getting started with our Overlander. Good bones and floor, but PO was challenged to say the least. Going through the utilities right now. Changing our vents and AC this week...stay tuned.
