OK, now I got the Dish Network....the whole thing works in the house AND in the back yard with my portable dish that the intaller/tech gave me
Of course the back yard installation was easy.....no receiver resettings necessary and I just matched sighting-wise the angle/rotation of the dish in the yard.
My question now is do I need a Winegard Satellite Finder SF-1000? Do I need anything? Would another brand suffice?
By the way, the Winegard tripod is prone to tipping as someone on this forum said--he is getting a "suitcase model".....don't exactly understand that.
I bought a "healthier" auger at Home Depot (it's really for staking your pet out)....and am hoping for the best.
Kistler
Brenda
Misty (Maltese)
Maxwell (grey tabby)
2002 Classic 25'
2003 Expedition EB 5.4L, AWD, AdvanceTrac Class IV hitch pkg. Reese dual cam/Prodigy
I think the name of my sat finder is a channel master. It takes less than a minute to normally locate and lock in. I had a screw similar to what you describe. In soft soil it goes in easy and does a good job. In hard soil it won't go in at all. I am using a suspended lead weight hung from the middle of the tripod. It is a coffee can filled with lead. It keeps it upwright most of the time. If you are interested I will find the name and model of the sat finder, it does a good job.
Keep the shiny side up. WBCCI # 3485 Region 3 1stVP
Past President Tidewater Unit 111
visit tidewater Virginia's web page @ www.tidewaterwbcci.com
Rick Bell in "Silverbell"
Aaah the person from John Edward's territory....by the way what you think of him there?
And where do you buy lead, sir?
I guess this will give me something else to do while "setting up" in the park. Brenda usually brings me out a gin and tonic...fighting malaria here while I am setting up...
Apparently, she should hold off a little until we get a picture
Lead has become the bad boy, but you can still find wheel weights that most local tire places would love to let you have, or at least that is still the case here. It doesn't take much heat (propane torch or cast iron pot on a burner) to melt it down. Well I happen to be one on the few in that I am a NC Democrat, John Edwards is top shelf in my book, but then so is Jimmy Carter.
For lead, you might try a local diving shop. They have lead shot in sealed mesh bags in 1lb, 2lb, etc..., up to 5lbs weights. They also have lead powder in elastic pouches. Both obviously are waterproof , and surprisingly strong. They can be used as is. Just a thought.
John-Boy
__________________ Sarchasm (n): The gulf between the author of sarcastic wit and the person who doesn't get it.
1975 31' Sovereign
2004 Dodge Ram 2500 'Laramie', HEMI
Heck, I just mounted a dish to a chunk of treated 6X6, about 2 feet long. For added stability nail or screw a 2' piece of 2X4 on one end. Cheap, works fine, even in mild winds. Saw another fellow A/Ser doing this. I bought a "sat finder" at Radio Crap.
CP 9 miles off Exit 399, I75.
Propane Powered Honda EU2000i
Lots of Hot Sauce! Air # 283
Reason: Cannot disclose.
You can find lead bags with handles in professional photo and movie supply stores. They wrap nicely around the legs or also lay flat nicely. Come in various weights.
David
Retirement happens when you get over the illusion of usefullness.
