Old 11-29-2006, 11:39 PM   #15
guy99's Avatar
1984 31' Airstream310
Dunsmuir , California
Images: 16
Yeah, its a real mess. We've been using dish with distance networks in our MH for a couple of years. But given the court and Newscorp that's over. So I decided that rather than rail against the machine I'd order Directv. Had it installed last Wednesday, filed the RV waiver on Friday, Distance Network channels showed up today.
I don't like Directv as well as Dish but it seems to do everthing we need.
I think local stations are "spot beamed" so that once you get a certain distance from home, you 'local' stations will no longer work.
1984 310 Limited Motorhome
guy99 is offline   Reply With Quote
Old 11-30-2006, 10:32 PM   #16
gryphon's Avatar
I guess we will wait it out since we don't tote the satellite with us on short trips. Maybe by the end of jan we will see where this leads. I may give directv a call and see what their deal is. I imagine when the warm temps return many oif the rvers will do the same.
This is all incredibly stupid. We who comply with the law and sign the rv waiver should not be part of this.
FCC maybe not let dish out of this easy. Are there any other satellite companies besides dish and direct?
What were the costs when you switched to direct. Did they have to install new dishes or do anything to the wiring?
gryphon
WBCCI #6978
There are two ways to die in the desert.
One is by thirst and the other is drowning.
gryphon is offline   Reply With Quote
Old 12-01-2006, 06:46 AM   #17
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Portable on tripod or ground. That way you can park you trilaer under the trees and put the dish where you can get reception. Upgrading the dish is easier too.
Michelle TAC MT-0
Sarah, Snowball
Old 12-01-2006, 08:10 AM   #18
Denis4x4's Avatar
Durango , Colorado
We lost our "distant" Denver channels last night. Even though we had waivers and satellite TV for 21 years and an RV waiver, there're gone!
However, there is a bill in congress to allow distant channels sponsored by CO senators and representives.
Call your representative and push the issue.
Denis4x4 is offline   Reply With Quote
Old 12-01-2006, 08:56 AM   #19
guy99's Avatar
Images: 16
gryphon
Equipment and installation was free (after rebate) but there is a commitment period. Programming cost is about the same. You just need a RG6 cable from the dish to the receiver so however you get the signal from your DISH dish should work for a Directv dish. If you get a DVR, it will need two cables from the dish to the DVR. (the DVR has two tuners so you an record two different shows at the same time).
You get a new dish with the installation. They send an installer. (I just had him run the cables through the windows because I have moved our television and I need to figure out how I want to get the cable into my MH. I did not want him to decide how that was done. With the install you get a new triple LNB dish. The dish uses the same mount as a DISH dish. While the dish is capable of receiving three different satellites at once, you really only need one satellite to get regular (non-HD) programing and distance networks. An additional satellite is used to get local stations and a third satellite is used for HD programming.
Old 12-01-2006, 09:04 AM   #20
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Dish/Direct?
Guy,
I just came across your thread here. Will this this info help you out? I hope so. My Caravel is absolutely no tech.
https://www.mydistantnetworks.com/faq.htm
Old 12-01-2006, 09:39 AM   #21
guy99's Avatar
Images: 16
Originally Posted by Melody Ranch
Guy,
I looked at their web site, looks promising although the FAQ does not mention RV declarations.
I've sent them an email and will report back.
Old 12-01-2006, 10:52 AM   #22
guy99's Avatar
Images: 16
I emailed these guys asking about RV Declarations.
They responded but did not answer the question. So I'm not going to pursue this any further since I have already switched to Directv.
For those of you on Dish it may still be worth checking into.
Old 12-01-2006, 12:18 PM   #23
guy99's Avatar
Images: 16
A little more information on this option
I got this from another forum so cannot be sure how accurate it is
NPS will beam DNS for $9 per month, using Atlanta and San Franciscostations, over Dish Satellite 119. It appears that NPS, which until now has provided programming only for C-Band subscribers, has never heard of an RV waiver. Nobody appears to know if they will have RV waivers or not.
All parties involved are in court in Florida as I type this; the networks are asking that Echostar be held in contempt, and that the original injunction be reworded to make it clear that it applies to anyone using an Echostar satellite for transmission.
Old 12-03-2006, 06:18 AM   #24
Always Airstreaming!
rickandsandi's Avatar
2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
Send a message via AIM to rickandsandi
Well everyone, with so many dish problems I think you helped us decide; forget about it! Too much hassle. When we camp at SP we are boondocking anyway and when at a KOA or Good Sams 60% of the time they have cable. For the other times Barnes & Nobles has some really great books, and with the cost of a DVD, hey we can one watch it and then share it.
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
Proud Member of WBCCI
WBCCI #3411
AIR #17099
2009 Silverado 2500HD
2004 22' Safari
1960 24' Tradewind
rickandsandi is offline   Reply With Quote
Old 12-03-2006, 10:35 AM   #25
gryphon's Avatar
Rickandsandi,
Generally SAT tv is no problem. We have had and used it in the rv several years. These problems we are having with dish are very new. Hopefully they will be resolved, maybe not.
We also went several years with no TV. We went to bed early, read many books and spent lots of time outdoors. far better than sitting on the sofa watching TV when we all know...There is nothing on TV.
Good luck and happy camping!!!
Gryphon
WBCCI #6978
Old 12-03-2006, 10:41 AM   #26
Roscinante's Avatar
2006 19' Safari
Suisun City , California
changfe sucks!
Caught in the Dish change myself. Just had my local affiliates changed from San Francisco to Sacramento based only on my zip code. I have had the SF local channels for several years (more than five) and now suddenly I am a Sacramento boy?
Jer
Roscinante
Jerry and Avis
2006 Safari Bambi 19'
2005 Toyota Tacoma PU
"Mi Casa Es Su Casa!"
WBCCI #6716
AIR #17388
Roscinante is offline   Reply With Quote
Old 01-09-2007, 08:09 PM   #27
Finn's Avatar
1973 25' Tradewind
Keewatin , Ontario
Any Canucks have info about Bev or StarChoice? I am thinking of replacing the "aluminum clothesline" on the roof for a "wok". I currently have Starchoice at home and want to take the receiver with us when we travel.
Finn is offline   Reply With Quote
Old 01-10-2007, 05:21 AM   #28
steelbird312's Avatar
1956 22' Safari
2000 39' Land Yacht XL Diesel w/slide
Crossville , Tennessee
Images: 11
Back to the original thread.
Fewer holes in the Airstream makes me happy!
Satelite dishes as much as 200' from the unit, my TV on WITH RECEPTION, makes me happy.
Reception while parked under a shade tree makes me happy.
Replacement dishes for tripod mounts can be found for mere cents, yet repair/replacement of a roof mount are exhorbitant.
make mine a portable tripod mount.
Also, if you are going to spend much time WAY up in Canada or Alaska, a larger, more proficient dish can be purchased for that travel (weak signals). Roof mounts do not have that option.
steelbird312
2000 390 Landyacht XL
1989 29' Excella
WBCCI #6673 jerry Hodge
Have no intention of arriving at the grave safely, but rather to skid in sideways, chocolate in one hand,throttle in the other, totally worn out and screaming
"WOO HOO, WHAT A RIDE!"
steelbird312 is offline   Reply With Quote
Dish Network vs Direct TV gwsullivan Electrical - Systems, Generators, Batteries & Solar 36 01-17-2005 02:49 PM
Satellite Dish Installation John Brimer Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 4 12-28-2004 09:13 AM
Satellite Antenna Don in E Texas Electrical - Systems, Generators, Batteries & Solar 2 04-25-2003 03:57 PM
Satellite Question davthr Our Community 11 03-17-2003 11:31 AM
