Old 08-04-2004, 04:17 PM   #1
Orland Dewey's Avatar
Safety Flasher Lights?????
My 1985 325 MH does not have the safety flasher or hazzard lights do not
work at all. I have good stop lights and tail lights and turn signal lights. Just
wondering if anyone has any suggestions as to where to start looking. I have
changed the flasher control with the blinker light control and makes no dif-
ference. Thanks for any ideas.
ODD
ODD
Orland Dewey is offline   Reply With Quote
Old 08-04-2004, 07:38 PM   #2
jimmickle's Avatar
2000 31' Land Yacht
Normally, there is a separate flasher unit for the warning flashers. Check and see if it is OK and the fuse feeding it is OK
jimmickle is offline   Reply With Quote
Old 08-04-2004, 08:19 PM   #3
Flashers???
Thanks for the quick reply,
I did check the round 3 pronged flasher module. Thats ok
I will look for a fuse in the system. If its behind the fuse box it will be
a real bear to get at. Will see what I find.
Thanks ODD
ODD
Old 08-05-2004, 06:30 AM   #4
jimmickle's Avatar
2000 31' Land Yacht
Did you check both flashers? The warning light flasher is probably a 2 prong.
Running Lights Joe Z Lights - Interior & Exterior 7 12-11-2003 08:48 PM
Rear Indicator Lights Cracker Lights - Interior & Exterior 7 11-03-2003 02:42 PM
running lights mazda997 Electrical - Systems, Generators, Batteries & Solar 0 08-27-2003 08:55 PM
Upper Identification Lights aka(Clearance Lights) pap Lights - Interior & Exterior 7 04-08-2003 06:14 PM
looking for brake lights and back up lights larrylisa Lights - Interior & Exterior 6 12-07-2002 06:43 PM
