Old 12-17-2018, 12:26 PM   #1
Minneapolis , Minnesota
Safe battery procedure for MN Winter storage?
Hey Everyone,
I know there are a lot of threads about this already. I've been reading most of them the last 2 days. But I'm still a bit confused as there seems to be conflicting info. I'm wondering about the best battery procedure for cold weather storage? We live in MN, so Winters get cold. Our 2018 AS sport has been in the driveway, plugged into shore power for the last 2 months. I was planning on keeping it this way at least another 3 months. I was told and have read that people have been doing this for years with no problems and their batteries are fine. I've just recently been reading that that long term connection to shore power can hurt the batteries. There was one post here where someone mentions his battery exploded. Now I'm really freaked out and am confused about the best procedure. I just checked the batteries and they seem fine. Reading was 12.8 after disconnecting shore power. Any helpful comments would be greatly appreciated! Below are few of my questions.
Can I leave connect to shore power all Winter?
Could I leave batteries connected to trailer and plug into shore power once a week for a day? Will batteries discharge and freeze in less then a week?
If I decide to disconnect batteries and bring inside, is it safe after being connected for 2 months? (explosion post really scared me!)
Can I leave detached batteries in unheated garage connected to a battery tender?
fishbisquit is offline   Reply With Quote
Old 12-17-2018, 02:37 PM   #2
2007 22' International CCD
Seriously, ANY of these methods will work. I'm also relatively sure the 'exploding battery' one was a fluke...with reasonable care, flooded wet-cell batteries don't spontaneously explode in the sense of a violent, destructive explosion. They are more likely to bulge and crack, and spill their contents--which is a mess, true.
My personal choice, however, would be to put the batteries in a warm space, like a semi-heated basement, on a battery tender so you can easily check water levels and replenish them over the winter if needed. Put the batteries on a solid surface, in a convenient area for checking them, and not subject to falling or flooding...or curious children.
Old 12-17-2018, 02:54 PM   #3
I should have also stated that I know the long time "right" way to do this is to disconnect batteries and bring inside. However I am hoping to avoid this for a few reasons. Since I have easy access to shore power I was hoping for a convenient solution.
The 2 batteries I have are Interstate Deep Cycle Marine group 24. I just called up Interstate to find out what they recommend for cold weather storage. They said that if there is no draw on the batteries they should be fine for 1.5-2 months outside. They suggested checking the voltage once a month and if it gets to 12.5 to plug them in for a few hours to charge up and then unplug shore power again. This sounds like my perfect solution unless someone sees an issue I do not? Also should I pull the fuse to the CO2 monitor?
Old 12-17-2018, 03:25 PM   #4
Images: 59
Your best bet is to move it to your unheated garage and leave it on a battery tender.
The only reason is if you wake up some morning and your car battery is dead, you have a charged up spare sitting in the garage ready to use to jump start your car.
Or leave it in the trailer and just Uber to work.
Old 12-17-2018, 03:33 PM   #5
OK, now I understand your situation better. Since you have shore power available, you are in a better situation than I am. I depend on solar power, and store the Airstream outside, winterized, here in the Southern California high desert. We don't get quite as cold as your area...but I know what it's like--I lived many years in Chicago...
I'd leave the batteries installed, totally disconnected from the trailer loads, and use a battery tender to keep them charged. That way, if you forget to check, the battery tender won't be trying to power the parasitic loads in the trailer, and will keep the batteries charged.
I'd consider installing a real manual battery disconnect switch at the batteries to totally cut off the loads in the trailer in the winter. This avoids fiddling with the cables, and trying to remember how to hook them back up. There are several threads about how to install and properly wire a manual disconnect switch. I use one from Blue Sea Systems, but there are other mechanical positive disconnect switches available.
Hook the battery tender directly to the battery posts using ring terminals, and use with the fuse assembly that comes with it to protect the wires against accidental shorts.
Old 12-18-2018, 07:39 AM   #6
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Welcome Aboard!! 👍
What I did...started out removing and storing inside, evolved to checking the batteries regularly and plug in when needed...
Others have noted some of the upgrades that will present themselves down the road, one of our first was installing better batteries and converter. (IOTA IQ4 55a & 2 AGM Lifeline)
Sweet Streams
BTW...gets cold in Bflo too..😂
Instead of going to ’Starbucks…I make my own Coffee at home, yell out my name rong, then light a five dollar bill on🔥
"The hardest thing about Airstreaming, clearing your head and accepting how others feel it’s supposed to be done"…..
Amanamus
"Tahawus"
Old 12-18-2018, 08:04 AM   #7
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
One way is to put the trailer on a timer so that it has power for one to two hours per day.
Old 12-18-2018, 10:32 AM   #8
2017 16' Sport
Cutler Bay , FL
Thumbs up
What he said!
eva52 is offline   Reply With Quote
Old 12-18-2018, 01:51 PM   #9
1975 27' Overlander
gurnee , Illinois
batteries
I have a dedicated battery charge area in the garage. 2 Airstream batteries 1 corvette battery 2 motorcycle and 2 four wheeler batteries all on a wooden flat surface, each connected to their own trickle charger.When I'm ready to go so are they.
75Bob is offline   Reply With Quote
Old 12-18-2018, 01:56 PM   #10
This is a brilliant idea! So simple, I love it. Curious how you came up wiht 1-2 hours per day? Thanks again, love these boards!
Old 12-18-2018, 02:17 PM   #11
2015 20' Flying Cloud
Lander , Wyoming
My 2015 FC20 sits outside all winter in Wyoming hooked up to shore power, and the batteries do just fine. I doubt it gets any colder in MN. Apparently some older Airstreams came with chargers that don’t automatically throttle back to trickle, and you will read lots of threads claiming what I do will “boil the batteries”.
Wetfeet is offline   Reply With Quote
Old 12-18-2018, 06:18 PM   #12
waninae39's Avatar
2017 22' Sport
NCR , Ontario
i bring my LiOn battery inside as it does not like 0C or below
i put my old Lead Acid battery inside the As in the winter to run any system i monitor
waninae39 is offline   Reply With Quote
Old 12-18-2018, 06:39 PM   #13
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Since my trailer always has a draw of power (even though the master disconnect is switched off), I cannot leave the batteries in the trailer without providing some sort of charge to them. Constantly leaving the trailer plugged in will not work without causing excessive evaporation of the battery fluids.
I now pull the batteries when I winterize. The batteries are in my garage on a trickle charger. Once spring comes I reinstall the batteries prior to bringing the trailer home to dewinterize. In the summer I don't charge the batteries since a once a month travel cycle keeps the batteries sufficiently charged. However I do always turn the master disconnect off when I park the trailer between trips. Leaving it on, even with all appliances turned off will kill the batteries within 4 weeks or so.
I did measure the draw on the batteries and found with master disconnect on, the draw was .1 of an amp. With the disconnect off, the draw is .01 amp. Dealer told me that all the electronics in the trailer while turned off still draw power with the master disconnect on. When it is switched off, the only draw is from the propane detector.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 12-18-2018, 08:31 PM   #14
I shut the power down completely. 👍 Leave the batteries in the AS and monitor from inside the house with Victron dongle.
Amanamus
"Tahawus"
Winter Battery Storage "How To" DreamsInSlvr Winterizing, Storage, Carports & Covers 30 10-08-2017 09:19 AM
Short term storage procedure Kilhenyhill Winterizing, Storage, Carports & Covers 8 08-23-2017 06:18 AM
Winter travel with the family, safe? Ted S. On The Road... 48 12-27-2015 04:07 PM
Gun/Valuables Safe - What safe is the best? BrandonJenna General Interior Topics 22 02-21-2013 01:24 PM
Winter AS'ing 'Safe' Temps. Air Cruiser On The Road... 15 12-04-2010 07:57 AM
