With the univolt/magnetek on and pigtail plugged in you just jumper the charge line to the marking lights with a piece of wire. You can get the pin out out of you tow vehicle manual or just play with it. The 12 VDC feed would be eaiser to find with a meter or test light.
Brett G
WBCCI #5501 AIR # 49
"Stop worrying about the potholes in the road and celebrate the journey." -- Fitzhugh Mullan
Wise men talk because they have someting to say; fools, because they have to say something. -- Plato
In politics, absurdity is not a handicap— Napoleon
I haven't seen one advertised for more than twenty years, but when I purchased my Nomad new in 1980 it had a device that was plugged into the Bargman connector and would cause all of the exterior lights on the trailer to illuminate - - there was also a switch on the device that would cause the lights to flash. I think it was sold as a safety/convenience device.
I recently purchased one of these devices via an e-Bay auction. I haven't had a chance to test it as of yet, but it has the constant on as well as flash feature. The one that I recently purchased is key controlled while the one that I had in the 1980s was much simpler with just a toggle switch to switch between constant on and flash.
Kevin
Kevin D. Allen WBCCI (Lifetime Member)/VAC/Free Wheelers #6359 AIR #827
The device that I purchased via an e-Bay auction was an NOS unit that likely dates to the early 1980s if not before. It was being sold by an individual who was liquidating the inventory of an Airstream dealership that had gone out of business. I haven't seen another listed in the four or five months since I purchased the one that I have.
Kevin
We were at a camping show where they had the TT wired for this & we were told to just run a jumper wire between the top two pins. The trailer battery would supply the power. I did look the connection over & it appeared to be what they had quoted. Some people when they are at a campground & expecting company to come in during the night will do this. I would be careful that it would not annoy the neighbors or run the TT battery down.
Best,
The hot lead on the pigtail is the charging lead from the tow vehicle to the trailer battery(s). From your tow vehicle it is usally isolated by a relay so the trailer does not drag the engine battery down on an overnight stay.
It can work to your advantage, you could actually charge the battery of the tow vehicle if it were weak before trying to start by turning on the key with the pigtail and trailer plugged in. I would not reccomend trying to start an engine with a wek nbattery with this seut plugged in, but it might help you out of a jam.
As to the spark, that would be normal. The amperage from the 12 volt feed is fairly high and the sparks you are seeing are normally encased in a switch. There is one of those wires in the connector that is a ground. You want to verify it prior to inserting the jumper, or you may blow some fuses.
Brett G
Most trailers use the 7-Pin Pollack connector.
A properly wired Pollack connector plug has Pin #4 as the +12V source and Pin #3 as the contact for the running lights. Attaching a short jumper wire between those two contacts energizes the running lights.
However, it might be difficult to locate pins 3 &4 inside the plug to connect the jumper wire. Therefore instead of just using a jumper wire, a more elegant solution is to buy the inexpensive Pollack mating socket, which will come with a wiring diagram. Internally wire together Pin #4 to #3 inside the plug, seal it up, connect to plug to the socket and you’ll see the light(s). (Batteries will last longer if you’re on shore power.)
Now since you have actually created a “running lights” tester, you can take it a step further and design and configure ways to similarly test the signal lights and the break lights. Hope you get the general idea.
The beauty of this technique is that one can test the all the trailer lights without using the tow vehicle. Sometimes to troubleshoot an electrical problem one has to isolating the TT from the TV.
I use a dolly to position my trailer in it's parking spot, the dolly has a control box which plugs into the connector and the grabs power from the battery to activate the brakes. Works like a charm I have though about adding the wiring to test the lights and so on, not really a big deal.
Greetings all- Here is my two 1/2 cents worth. First to can go to any good auto supply store and pick up a HEAVY DUTY flasher relay. This thing has two pins that match perfect to a TT pigtail. Just plug into #1 & #6 and you have flashing clearance and tail lights! COOL Or you can buy a flat fuse in line fuse holder, crimp a flat yellow collar connector to each wire, plug one into #1 and the other into #6 and you have protected clearance and tail light on! The whole thing will cost you $8.00 or less and take just a few minutes to make.
Have fun! We put ours on flash for the girls when dinner is ready!
__________________ J. Rick Cipot Sandi Gould NEUNew England Unit Airstream Life Magazine WBCCI #3411 AIR #17099
We use the big E for camping and I like to leave the running lights on at night so I can find it in the dark. Also, I like to be able to leave the running lights on when the TV connected, but without leaving the TV's lights on. My solution was to buy another female connector and wire it to an old rotary automotive heater fan switch. I slipped the connector into one end of a piece of PCV pipe and put the switch into the other. I wired the switch to put power onto the tail light/running light circuit, the left, and the right brake/turn circuit. Now I can plug this gizmo into the trailer and test the lights without having the TV nearby.
It is convenient enough that I wonder why there isn't a commercial product like it.
"Not all who are lost are wondering" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
rickandsandi: What model TT pigtail uses pin #1 & #6 for clearance and tail lights?
All I know about is the Pollak connectors, and for that type pin #1 is ground and pin #6 is stop & RH turn signal.
Interesting to learn there are other modern TV to TT cable wiring configuration. Where can I view a diagram of that model?
To get “flashing clearance and tail lights,” with the Pollak connectors, it appears that one needs to put the flasher relay between pin #4 (+12VDC) and the other lead on pin#3,5, & 6.
