Old 11-20-2006, 06:41 AM   #15
Jim Clark's Avatar
2012 28' International
New Orleans , Louisiana
Thanks Works
Originally Posted by balrgn
I use a fusable link, put it in the top two on your pigtail
Thanks works, so dose the $2.99 thermal flasher with the angled pins, fits better than the fuse. I may add a box with a fuse socket and swithc to go from steady to flash. I think this is good if you ever have to leave the trailer on the side of the road for some reason. Crank up the warning flashers.
Jim N5TJZ Air# 174
2012 International Serenity 28
2005 Safari 25 SS Traded
1968 Globetrotter Sold
2011 F150 Ecoboost
Jim Clark is offline   Reply With Quote
Old 12-18-2006, 01:48 PM   #16
ESCAPE POD's Avatar
2007 19' Safari SE
Seal Beach , California
Running lights
Jim:
Could you post a photo or two demonstrating your solution to running lights while disconnected from the tow vehicle. I would also welcome photos or drawings depicting the solution(s) reached by AS owners.
Jerry
"I have found through trial and error that I work best under duress. In fact, I work only under duress." -Ed Abbey
Jerry & Susan
2007 19' Bambi SE; 2010 Ford F-150 5.4L SuperCrew 4x4 w/ FlipPac camper shell
ESCAPE POD is offline   Reply With Quote
Old 12-18-2006, 02:20 PM   #17
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Originally Posted by ESCAPE POD
Jim:
Jerry
Ditto. I'd like to see it as well if possible.
Old 12-18-2006, 02:52 PM   #18
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
On my way to autozone now, picking up a truck side plug to do all this jumping with fusable links and relays - got some ideas from all of you and want to test them out.
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 12-18-2006, 06:10 PM   #19
1975 27' Overlander
High River , Alberta
My Overlander came with a switch inside near the front window that turns all the running lights on. And I thought it came from the factory that way!
AlbertF is online now   Reply With Quote
Old 12-18-2006, 07:30 PM   #20
1976 25' Caravanner
Campton , New Hampshire
Ditto
ticki2 is offline   Reply With Quote
marker lights dont work wb13798 Mechanics Corner - Engines, Transmission & More... 6 11-09-2002 11:40 AM
Trailer lights Dbraw Electrical - Systems, Generators, Batteries & Solar 1 09-13-2002 04:51 PM
marker lights bhsl8 Lights - Interior & Exterior 6 09-12-2002 06:01 AM
Rainwater leak James Schmidt Leaks - Weatherstrips, Gaskets, Caulks & Sealants 8 09-11-2002 06:28 AM
Rrunning Lights niftypkg Electrical - Systems, Generators, Batteries & Solar 7 08-22-2002 10:30 AM
