Old 08-17-2013, 10:34 PM   #1
1971 31' Sovereign
fresno , California
Question running lights not working.
Thanks for everyones help on the breakaway switch. There turned out to be a wire disconnected from the breakers in the front. Now the clearence and running lights don't work. I have turn signals and brake lights but nothing else. Is there a fuse in the trailer or should I be looking for a blown fuse in the tow vehicle. I installed an electronic brake controller and that is working great. I am thinking I must be overlooking something simple. Thanks in advance for your input.don't know what I would do without Airforums.
imbighoe is offline   Reply With Quote
Old 08-18-2013, 07:55 PM   #2
Dan and Liz's Avatar
1987 25' Sovereign
Fort Collins , Colorado
In our case it was a relay in the tow vehicle that caused the same problem. Found it in the TV owner's manual (F150). About $12 and I got a spare to carry just in case.
Dan & Liz H
"I'd rather be happy for just one day than miserable for the rest of my life."
Dan and Liz is offline   Reply With Quote
Old 08-21-2013, 07:56 AM   #3
Skater's Avatar
1995 30' Excella
Bowie , Maryland
Run a wire from the +12 volt terminal on the camper umbilical plug to the marker light terminal and see if they work then. That'll help you figure out where the fault lies.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
