Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 05-04-2004, 01:02 AM   #1
Condoluminum
Condoluminum's Avatar
Profile:  1988 25' Excella
Sunnyvale , California
Rotary 12V Bath Vent Switch
In the process of "enhancing" our '88 Excella 25 bath vent with new screen, I managed to destroy the little rotary switch with round plastic knob that controls the on-off noisemaker fan under the up-down aluminum dome.. Switch appears to be 1/2' in diameter, with plastic claws that retain it in small hole at side of vent screen. It has pair of wires attached, and turns from on to off to on in 360 degrees..
None of local home center places carry anything similar. Seems like a common "RV Parts" item, but no luck at Camping World.com or other sites.. Any suggestions for part number or source??
John McG
Condoluminum
Condoluminum is offline   Reply With Quote
Old 05-04-2004, 06:32 AM   #2
Dwight
Dwight's Avatar
Profile:  1999 34' Excella
Joshua , Texas
I replaced the same switch, fan blade and lid on my '86 a few years back. The fan unit is made by VentLine, I was able to find all of my parts from the local RV dealer.
Dwight is offline   Reply With Quote
Old 05-04-2004, 08:24 AM   #3
j54mark
Profile:
I found the switch at Lowes, but had to ask for help in finding it. They had it hid in with other small electric switches in little plastic bins. It is a common switch.
I also put in a 2 ohm 10 watt wire wound resistor to slow down the fan a bit and lower the noise.
Mark
Old 05-04-2004, 08:38 AM   #4
TomW
TomW's Avatar
Profile:  1967 26' Overlander
Normal , Alabama
Images: 77
Originally Posted by j54mark
...I also put in a 2 ohm 10 watt wire wound resistor to slow down the fan a bit and lower the noise.
Does that resistor get warm enough to worry about?
Tom
Old 05-04-2004, 09:02 AM   #5
j54mark
Profile:
Tom
The two ohm resistor didn't. Besides, I mounted it just below the fan blades so that air is pulled past it when running.
Mark
switch for 12v supply to refrigerator nickcrowhurst Refrigerators 11 02-09-2004 03:33 PM
12V System....Sudden Death! Help, please Alan and Mardel Electrical - Systems, Generators, Batteries & Solar 6 12-13-2003 12:04 PM
No 12v Power wcdelorme Electrical - Systems, Generators, Batteries & Solar 13 05-11-2003 10:53 AM
Rotary Light Switch 74SovereignInt. Electrical - Systems, Generators, Batteries & Solar 20 10-15-2002 07:31 PM
12V question uwe Electrical - Systems, Generators, Batteries & Solar 16 09-05-2002 02:14 PM
test
