Old 08-08-2012, 12:14 PM   #1
VeggieBullet's Avatar
1973 31' Sovereign
2007 20' Safari SE
Wesley Chapel , Florida
Romex size
we are in the process of gutting the 1973 31ft and we are wondering for the "re-wiring" what is the size of preference for the romex? 12/2 or 14/2. All will still be on the 30Amp.
Thanks for the help.
Still One Nation under GOD
2 chronicles 7:14
VeggieBullet is offline   Reply With Quote
Old 08-08-2012, 12:20 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
The 30 amp cord wants to be #10, the 20 amp circuits want to be @12, and any 15 amp circuit should be #14
2004 Excursion 4x4
Old 08-08-2012, 12:24 PM   #3
1973 31' Sovereign
2007 20' Safari SE
thanks howie
So basically we should do
AC in 12/2
Outlets on 14/2
And we will keep the 25Ft cord (looks like #8 to me)
Thanks again
2 chronicles 7:14
Old 08-08-2012, 12:30 PM   #4
HowieE's Avatar
Images: 12
Can't go wrong there
2004 Excursion 4x4
Old 08-08-2012, 12:31 PM   #5
BeachHouse's Avatar
2005 25' International CCD
Lilburn , Georgia
You should do 20 amp (12/2) for kitchen and bath (hair dryer) specific outlets and microwave if you have one.
BeachHouse is offline   Reply With Quote
Old 08-08-2012, 12:47 PM   #6
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
14/2 is minimum - there is no rule you can't run 12/2 everywhere that 14/2 could be run.
Confirm what you're buying has equal sized & insulated copper ground wire, some grounds run bare and some have smaller or aluminum conductors.... Just one of the things the lowest priced wire tries to sneak home with buyers.
Old 08-08-2012, 12:59 PM   #7
1981 31' Excella II
New Market , Alabama
I would buy a 250ft roll of 12/2 and call it good. I would only use 14/2 for lights. I ALWAYS use 12/2 for wall outlets. In reality 14/2 is fine especially if you never plan to upgrade to a 50 A or 220V 30A system. I tend to want to plug in space heaters and the system in my AS won't support it. There is one 15A circuit that powers the fridge, univolt, and outlets so there is no much left of that 15A for heaters and such.
Perry
Old 08-08-2012, 01:03 PM   #8
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Yes, 12-2 w/ground. If you prewire for solar, use 8 awg for that in case you want to mount a lot of panels. Airstream uses 10, but for more than a couple of hundred watts, that's not enough. Other wiring would include HDMI for TV to sound system, USB if you don't have a wireless printer or other electronic items, and wiring for wifi booster or cell booster antennas which are mounted on the roof or side.
Gene
Old 08-08-2012, 08:14 PM   #9
Awesomeness. In a word.
SkratchCo's Avatar
1964 24' Tradewind
Hendersonville , Tennessee
12/2 is fine, just harder to work in small outlet boxes. 14/2 is much easier. Also remember gfci outlets near water.
Jimmy
SkratchCo is offline   Reply With Quote
Old 08-08-2012, 08:19 PM   #10
lewster's Avatar
Naples, FL , Hood River, OR
Jimmy
Stranded Marine grade 12/2 with ground is very pliable and easy to work with. I won't use Romex on ANY RV. Quality never costs in the long run!
Old 08-09-2012, 05:43 AM   #11
1981 31' Excella II
You got a spec on the 12/2 marine grade? Is it just 12/2 SO cable or something different than that?
Perry
Old 08-09-2012, 06:22 AM   #12
SkratchCo's Avatar
1964 24' Tradewind
Good Point!
Old 08-09-2012, 04:30 PM   #13
lewster's Avatar
Perry
105ºC rated and fully insulated (including ground). Flame retardant marine wire and cable options meet and exceed requirements from US Coast Guard, ABYC and DOT. Available in single conductor and multi-conductor options for a variety of applications. Multi-conductor marine cable has electro-tinned plated copper conductors with a flame retardant PVC jacketing. Single conductor tinned UL1426 Marine Wire is extra flexible for easy routing and bending through marine applications. The flame retardant PVC jacket provides maximum protection from water, vibration, abrasion and chemicals.
Old 08-09-2012, 07:20 PM   #14
mapleton , Utah
Lewster, do you have a mfg preference or a good source that you are willing to share?
tim
rumrunner is offline   Reply With Quote
