Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 05-15-2005, 06:15 PM   #1
Chuck
Sad Moderator
Chuck's Avatar
Profile:  1973 23' Safari
Images: 99
Rocker switches--still available?
anyone know if you can still get these? one of these is busted...jammed. won't move. seems like perhaps a little piece of the plastic may have broken off and jammed itself in there so the switch won't move.
haven't seen any "around"...one rv catalog I checked had some rockers, but totally different style (appearance) than this. wondering if A/S might still have them...
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 05-15-2005, 06:34 PM   #2
74Argosy24MH
Profile:  LOST , Hawaii
If you can't find one from an rv outfit and don't mind replacing both (color probably won't match otherwise) try Digikey or Mouser Electronics.
John
74Argosy24MH is offline   Reply With Quote
Old 05-15-2005, 08:49 PM   #3
eubank
Lynn
Commercial Vendor
eubank's Avatar
Profile:  1967 30' Sovereign
Angel Fire , New Mexico
Looks like your attached thumbnails didn't attach.
Lynn
WBCCI 21043
Lynn's blogsite: http://forum.aardvarkrv.com/blog/
If you're WBCCI, come visit us at the park (and get more cool air and less oxygen and ... a 50% discount!)
Old 05-15-2005, 09:05 PM   #4
garry
garry's Avatar
Profile:  1969 31' Sovereign
Broken Arrow , Oklahoma
I found some at Colaws, send them the picture and they can send you a look alike however it will be a used switch.
http://www.colawrvsalvage.com/
Garry
Old 05-15-2005, 09:30 PM   #5
davidh
1977 31' Sovereign
davidh's Avatar
Profile:  Kalispell , Montana
Why don't you try this. take a drill and drill out the rivets for the switch that dose not move. If there is a piece of plastic that is jammed in the switch remove it and your switch will most likely work without haveing to replace it. And if worse comes to worse you need to replace it, eather way you half to remove no matter what you do. Hope this helps. God Bless..
davidh is offline   Reply With Quote
Old 05-15-2005, 09:46 PM   #6
Jim & Susan
Jim & Susan's Avatar
Profile:  1973 27' Overlander
McDonough , Georgia
Images: 37
Chuck, I've got all of mine apart. Just tried to go out and take some pictures, but light problems this time of night. I'll try again tomorrow if you need pics. These switches seem fairly common, Radio Shack, Grainger, your local electrical supply. If you need better pics, let me know.
To lodge all power in one party and to leave it there is to insure bad government. -- Mark Twain
www.nesa.org
Air No. 6427
Old 05-16-2005, 02:28 PM   #7
Chuck
Sad Moderator
Chuck's Avatar
Images: 99
how do you get them apart? just a flat screwdriver, and pry carefully? I'll check the 'shack, and see what they have.
Air:291
Wbcci: 3752
'73 Safari 23'
Old 05-16-2005, 06:49 PM   #8
69 Silverback
69 Silverback's Avatar
Profile:  1969 27' Overlander
Firth , Nebraska
I bought some from an rv supply, they are black and just a tiny bit larger. The rivets just hold the plate to the wall and the switch clips ito the wall plate. a little work with a fine file on the switch plate opening and they look and work great. I didn't like the chrome plates the new switches came with. The little effort was worth it.
Good luck
Loren
69 Silverback is offline   Reply With Quote
Old 05-16-2005, 08:59 PM   #9
Jim & Susan
McDonough , Georgia
Images: 37
Pics
Still not the best pics, I don't have the good camera now. See if you can make these out. see the tiny hole on the side? Gently pry this apart with a small screw driver, it'll all come apart. Remeber, be gentle. Jim
ID:	12188  Click image for larger version
www.nesa.org
Air No. 6427
Old 05-17-2005, 10:13 AM   #10
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
Chuck.
Any Airstream dealer that stocks parts for the vintage trailers, has that switch.
They are available in white and black.
Also that switch comes in different arrangements.
They can be SPST. SPDT, momentary, etc.
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
800-8777311
Inland RV Center, In is online now   Reply With Quote
Old 05-17-2005, 10:28 AM   #11
Chuck
Sad Moderator
Chuck's Avatar
Images: 99
what's that mean?
oh, wait: "single pole, single/ double throw, etc" right?
(thanks, Andy! )
Air:291
Wbcci: 3752
'73 Safari 23'
Old 05-17-2005, 10:51 AM   #12
Commercial Vendor
Chuck.
Sorry.
SP= single pole
DP= double pole
ST= single throw (on-off)
DT= double throw (a three way switch)
Momentary= When you flip the switch, a circuit is connected, or disconnected, as the case may be. When you let go, the switch returns to it's normal position.
The above is for toggle or rocker type switches.
Rotary switches are a different ball game.
Inlandrv.com
800-8777311
Old 05-17-2005, 01:52 PM   #13
Anon
Profile:
Rocker switches from Mouser.
You can get them for as little as .92 or as much as 9.00. I did not pull up the exact one. I like Mouser because you can upgrade the switch for less money.
Here is the catalog page link:
http://www.mouser.com/catalog/622/1093.pdf
This will require the use of Adobe Acrobat Reader or Acrobat Professional to view.
Anon is offline   Reply With Quote
Warning: Ceiling Light Switches DPeakMD Electrical - Systems, Generators, Batteries & Solar 30 08-20-2008 05:28 AM
3-Way Roof Light Switches roadcam Electrical - Systems, Generators, Batteries & Solar 8 09-06-2004 03:31 PM
What are these switches doing_Excella 1990 femuse 1990 - 1993 Excella 8 04-27-2003 05:29 PM
Rotary Light Switch 74SovereignInt. Electrical - Systems, Generators, Batteries & Solar 20 10-15-2002 07:31 PM
"univolt" Chuck Electrical - Systems, Generators, Batteries & Solar 10 06-07-2002 02:30 PM
test
