Old 03-28-2016, 03:53 PM   #1
Chuhhuniban's Avatar
2013 25' FB Flying Cloud
Prescott , Arizona
Rigging Up A Solar Trickle Charger
I bought a solar panel trickle charger for my 25FB. The AS is stored under a roof and the stall is north-south, so the sunny end is south, at the rear of the trailer. The panel has a cigarette lighter plug on the end of the cable. What I want to do is run a cable from the battery box back to the storage compartment in the rear bumper. That cable will be tied into the batteries and have a female cigarette lighter socket on the other end inside the storage box.
My question is where to hook the battery box ends. The negative conductor to the black terminal at the upper left and the positive conductor to the red terminal at the lower right? Correct?
Chuhhuniban - Grey Coyote (Tohono O'odham)
A late convert to Airstreaming after 30 years of white boxes and motorhomes, now we have the Tin Twinkie.
Chuhhuniban is offline   Reply With Quote
Old 03-28-2016, 04:29 PM   #2
2015 30' Classic
Pleasanton , California
Upper left and lower right OR lower left and upper right. Either way, you'll be charging both batteries in parallel in a balanced configuration.
Al, K6IV
2015 30' Classic, "Chez Nu"
2014 RAM 2500 w/Cummins Diesel
ProPride Hitch, 400 W Solar
alano is offline   Reply With Quote
Can I leave my Interstate marine flooded batts on trickle charger in winter? bonginator Batteries, Univolts, Converters & Inverters 20 10-06-2012 11:06 AM
Great deal on Solar Trickle Charger ddruker Generators & Solar Power 1 08-28-2012 06:33 AM
Recommendations for trickle charger? bonginator Batteries, Univolts, Converters & Inverters 2 09-27-2010 09:10 AM
Solar trickle charger.... drboyd Generators & Solar Power 27 09-20-2003 07:51 PM
Trickle charger to replace Univolt jwaldin Electrical - Systems, Generators, Batteries & Solar 2 02-18-2003 10:12 AM
