Old 11-11-2003, 05:15 PM   #1
Rewiring a 1973 31 ft. International
Present set-up has 30 amp feed, with 2 30 amp circuit breakers. Neutral wire fried!?
Planning on a complete redo at 50 amps, plus more circuits.
My question: is my problem and solution typical, or would 50 amps restrict camp ground sites?
Thanks in advance.
Dick
Navigator is offline   Reply With Quote
Old 11-11-2003, 05:33 PM   #2
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Welll, depends on where you camp We do a lot of state park camping and the ones around here have not upgraded to 50 amp service. I suppose you could always carry a 30-50 amp adapter. Why do you need the 50 amp? Or is it just an upgrade. FWIW this summer while we were on the road I would say only about 70% of the commercial campgrounds we stayed in had 50 amp service readily available. We saw a couple of the big boys nearly come to blows over the last 50 amp site at one campground we were staying in.
Aaron
Old 11-11-2003, 05:41 PM   #3
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
I would stick with the 30 amp setup. The 50 amp plugs are sometimes hard to come by, and unless you are going to run 2 roof ac units there is no real need.
Note: some campgrounds charge more for a 50 AMP vs a 30 AMP.
Also unless you wire it to the RVIA standard the 50 amp feed could blow a pole based GFCI and have no power at all. Much simpler to just rewire it as it is and go from there. Not to mention the time saved!
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Cabinets 1972 Ambassador 31 ft Alex Cabinets, Counter Tops & Furnishings 2 11-29-2003 11:58 PM
1973 27 ft airstream rear bath LA008 Plumbing - Systems & Fixtures 8 10-05-2003 08:18 PM
