Old 07-17-2015, 08:06 PM   #1
StreamAholic's Avatar
2014 25' FB International
Bryant , Arkansas
Reverse Polarity - Need Help
Alright Streamers. Just checked into my campsite. RP light is showing on my Surge Guard... What do I do? Is it ok to run the AC? It's hot in South Arkansas so need some help.
Tim
2014 25' International Onyx edition
2014 F150 SuperCrew
StreamAholic is offline   Reply With Quote
Old 07-17-2015, 08:12 PM   #2
Bryant , Arkansas
I also have a cheap tester that plugs into the outlets. I just tried it in several of the outlets and it says "correct"
Tim
2014 F150 SuperCrew
Old 07-17-2015, 08:14 PM   #3
Echelon73's Avatar
2010 30' Flying Cloud
Mocksville , North Carolina
I had that problem earlier this summer. Everything worked inside, but Surge Guard said reverse polarity. It had been raining and I believe there may have been some corrosion on the socket. I had a few circuit checking devices that all read ok so I went ahead and used it. Everything ran fine. Do you have any of the circuit testing plugs you can check it with?
Echelon73 is offline   Reply With Quote
Old 07-17-2015, 08:15 PM   #4
Echelon73's Avatar
Oops, just saw your post about the tester saying it is good. That is the exact same way mine did. I ran everything without any problems.
Old 07-17-2015, 08:17 PM   #5
Bryant , Arkansas
Thanks for the reply. I've been running everything for 15 minutes without a problem. Just wanted to make sure I'm not doing any permanent damage.
Tim
2014 F150 SuperCrew
Old 07-17-2015, 08:36 PM   #6
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
What is the level of the AC voltage with and without the air conditioner running?
MICHAEL
Old 07-17-2015, 10:17 PM   #7
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Sounds like a "backfeed" on the neutral... I would suggest being very careful touching the AS while standing on the ground.
Check for a "hot skin" condition. Is there ANY voltage between the shell and the actual ground/dirt.
Peace and Blessings..
Channing
WBCCI# 30676
Old 07-17-2015, 10:57 PM   #8
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
If you have a 30 amp to 15 amp adaptor. Unplug the shore power cord and surge suppressor.
Plug the adaptor in. Then use one of the outlet circuit testers to check for reverse polarity and other issues.
This should tell you if there is in fact reverse polarity.
Old 07-18-2015, 06:13 PM   #9
1967 26' Overlander
Spartanburg , South Carolina
We had that happen last year when we plugged in to a receptacle at someone's home which had a ground fault system. The surge protector showed out of phase but the plug in tester used inside the A/S said ok. We did not check for hot skin, but everything went ok by not using the surge protector. The ground fault detector in the house also said everything was ok.
Jacob D is offline   Reply With Quote
Need Outside Polarity Light for 70's Airstream RivetGirl Airstream Classifieds 0 06-24-2014 09:00 AM
Installing a back-up camera help, reverse on steering column of motorhome? Timotreous Classic Motorhomes 6 05-20-2013 08:14 AM
I need a reverse light housing!!! gretchen Lights - Interior & Exterior 1 05-21-2007 08:08 PM
Honda 2000 polarity screwy??? crazylev Generators & Solar Power 4 09-19-2004 12:29 PM
Polarity light function (diode?) walter1 Electrical - Systems, Generators, Batteries & Solar 12 09-03-2004 02:59 PM
