Old 10-19-2010, 10:40 PM   #1
2006 25' Classic
Newport Beach , California
Resetting 12 volt circuit
Hi!
If may be stating the problem incorrectly as Pete is camping without the computer and he is trying to explain the situation to me over the phone because I have the computer at home---but here goes!!
Pete removed the screen from the bathroom fan for cleaning as described in the thread about bathroom fan cleaning. When he cut the wire it popped the 12 volt circuit.
Following the directions in the trailer manual he located the 12 volt panel under the gaucho---BUT---
There doesn't appear to be any way to reset anything. Nothing is 'popped' or 'slid' in the manner of a 110 panel.
So, any thoughts on how to reset the 12 volt circuit?
He sent me a picture of the panel, but when I tried to post it here, all I managed to do was lose the entire post I had written out.
Any help would be appreciated, and I will forward it on!!
Thanks, Cathy
Cathy&Pete is offline   Reply With Quote
Old 10-19-2010, 10:56 PM   #2
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, I just checked my trailer and you need to look inside of the fuse panel. The circuit breakers are for the 120 volt system and the fuses are for the 12 volt system. In my fuse panel it shows a 20 amp [yellow] fuse in the number one position, top left. It controls a few other things and the bathroom fan in my trailer. Read the information inside of the fuse panel door.
Hope this helps you.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 10-19-2010, 11:34 PM   #3
Salem , Oregon
Images: 18
Hi, Cathy. I meant the yellow fuse on the left, not top left. If your panel is the same as mine, and wired the same, the fuse should be easy to find and replace.
2005 Safari 25-B
Old 10-19-2010, 11:39 PM   #4
Salem , Oregon
Images: 18
Hi, having a hard time posting second picture; WIFI is weak here. I'll try again. If you click to enlarge picture, so you can read the label, mine says "Circuit #1 compartment lights, bedroom lights, and bathroom fan". Replace the yellow fuse on the far left. [if your panel is the same as mine]
2005 Safari 25-B
Old 10-20-2010, 07:56 AM   #5
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
I searched for a thread that covers bathroom screen cleaning so I could see Why you would have to cut a power supply wire in the job. Can't find any. Nor, can I figure out the wire cut in the first place. I hope the fuse replacement works. (Besides, just cutting the power wire should not pop the fuse.)
Old 10-20-2010, 09:33 AM   #6
2006 25' Classic
Thanks Bob!
I will be passing all this info on to Pete when I talk to him this morning.
I really appreciate you taking the time to help us out!!
Cathy
Old 10-20-2010, 11:13 PM   #7
Salem , Oregon
Images: 18
Hi, I don't know how to find that thread either, but I cut my wires, one at a time, and replaced the switch with a much better one. And it makes cleaning the vent a lot easier.
2005 Safari 25-B
Old 10-20-2010, 11:15 PM   #8
Salem , Oregon
Images: 18
Originally Posted by Cathy&Pete View Post
Thanks Bob!
Cathy
Hi, happy to help you out. Hope you get it going again.
2005 Safari 25-B
12 volt
Resetting circuit breaker? 68Glbtrotter Electrical - Systems, Generators, Batteries & Solar 4 11-02-2005 06:19 AM
6 volt vs 12 volt brakes? lwebb Brakes & Brake Controllers 17 07-14-2005 08:32 AM
Help! 12 Volt Circuit Not Working on 97 Excella mello mike Electrical - Systems, Generators, Batteries & Solar 0 07-08-2005 02:16 PM
Wiring Sequence to hook up 2 x 6 volt battery pack to your 12 volt trailer battery TobyJH Batteries, Univolts, Converters & Inverters 0 05-21-2004 12:04 AM
1961 - 12 volt or 6 volt? Marlboro Mafia Electrical - Systems, Generators, Batteries & Solar 4 04-19-2004 09:03 AM
