Old 01-19-2011, 11:03 AM   #15
nswhite's Avatar
2005 30' Classic S/O
Phoenix , Arizona
Does this explain why my replacement led tail lights are failing?
nswhite is offline   Reply With Quote
Old 01-19-2011, 11:18 AM   #16
Wise Elder
Jammer's Avatar
2010 30' Classic
Originally Posted by ck21084 View Post
Jammer,
My rig did not come with fluorescent lights. Could you post a few pics of what the look like? Also do you have the over head door light or the scare light? If over head what comes in this?
My lights are stock. I believe Airstream uses the Taylorbrite lights. They have pics:
Taylorbrite(R)
Most of the ones in my trailer are a semi-recessed design which isn't on the Taylor website. They recess enough that the exposed height is somewhat less than an inch. I have six of the 16W and one of the 30W.
The 16W Taylorbrite fixtures use two 8W tubes which each produce 360 lumens each if high quality 3000K tubes are used. The G4 LED retrofit units people often use produce 60 lumens with 2W, less light per watt by the ratings although I believe it ends up being about the same when ballast losses are considered.
You should be able to find some interior pics on any of the dealer web sites that include the lights.
I have an incandescent scare light. I would like to replace it with the Maxxima M42327 at some point. That is an LED fixture and suspect that the heat problems are better addressed by the manufacturer than they would be with a conversion. A fluorescent light won't fit the 4" cutout, obviously, so LEDs are the better alternative.
Old 01-19-2011, 11:19 AM   #17
Wise Elder
Jammer's Avatar
2010 30' Classic
Originally Posted by tpi View Post
One point made by dljosephson i think bears repeating. The fluorescent and LED phosphors are similar and produce a similar quality of light. Almost all of the original equipment fluorescent fixtures use a low end lamp with poor color rendering. This lamp can be replaced with a superior lamp.
I got mine here:
F8T5/30U PHILIPS $7.10 8W T5 11 5/16 ULTRALUME 3K PHILIPS 20702-7 85 CCRI 360 LUMENS (ALB-UPC: CANZZZEY)
They produce more light, warmer light, and better color rendition than the cheap OEM bulbs.
Old 01-19-2011, 11:06 PM   #18
Santa Cruz , California
Images: 12
It's a good bet.
dljosephson is offline   Reply With Quote
Old 01-19-2011, 11:26 PM   #19
Images: 12
Originally Posted by Johnco View Post
I replaced all my interior lighting a couple of years ago with leds purchased from superbrightleds.com and have been completely satisfied. There have been no failures and their intensity is the same as when they were installed. All were ordered as warm white.
Those are the ones I have been happy with, too. On some of the other threads there's a picture of the circuit consisting of a small outline IC, four diodes, an inductor and a filter capacitor. This is the "LED driver" circuit, there are several makers of this IC and most of them work well over the range 10-30 volts. I tested the superbright over the range 8 to 32 volts -- it gets to full brightness at about 10.5 and stays the same up to 32 (where my power supply stops). With increasing voltage, the current drops so the power stays constant (it draws current only during short pulses, the ratio of "on" to "off" time determines the average input current while the output voltage is maintained constant.) It's the same sort of circuit in lots of other switch-mode power supplies.
Using four white LEDs in series with a resistor might not be the best idea. The bandgap voltage is typically at least 3.2 volts, 4x3.2 is 12.8 which means the light will be very dim once the battery isn't being charged. All of the white LED stuff I've seen uses three in series plus a diode and/or resistor.
The current requirement varies widely. Small 5mm ones will take no more than 20 mA. Some of the bigger ones will take up to an amp, given adequate heatsinking.
Old 01-19-2011, 11:29 PM   #20
Images: 12
Originally Posted by Jammer View Post
I got mine here:
Philips is definitely the leader in high end phosphors -- Europe is ahead of the US in phasing out incandescent bulbs and I think Philips is the market leader there. They also do LEDs but I don't know whether they are their own or in cooperation with one of the big Asian LED makers.
Old 01-20-2011, 01:55 AM   #21
Star-Man's Avatar
1953 21' Flying Cloud
Encinitas , California
I have a company that designs and produces LED lighting and controls. I have been involved in this industry since 2002. The quality of LED products on the market is highly variable. Typically the stuff from Asia that opportunistically floods the market is poorly designed with low manufacturing cost being the primary criteria. Whoever you buy from, get a solid warranty (I recommend 3 to 5 years if you can find it, and read the fine print).
The LED lights with integral voltage regulators are probably not dimmable (if that is of interest). For me, it is a show stopper. I prefer the constant voltage (with resistor) type that I can run in parallel and dim with a pulse modulation dimmer. For an RV, this would require a DC-DC converter that holds 12 volts no matter what the input. I would have separate circuits for LED lighting and place the DC-DC converter near my main panel. The dimmer acts on the regulated voltage side of the converter. A 20W DC-DC converter is smaller than a cell phone and costs about $30. Many other sizes are available. I have used some from here: PowerStream Power Supplies and Chargers for OEMs in a Hurry
Thermal management is of paramount importance when implementing LED lighting. LEDs do not radiate their heat forward like an incandescent bulb does. They conduct heat from their base. Aluminum is an excellent conductor of heat. Try to couple the hot spot of the light fixture to interior skins (exterior skins may get too hot in the sun). Also try to get airflow over the hot spots.
And, in case anyone is wondering, I do not produce any lighting for airstreams or other RVs... yet. I am working on my '53 Flying Cloud ground up renovation. When the time comes I will be making my own custom fixtures. There will be no incandescents or fluorescents anywhere on the trailer.
Chris I.
Star-Man is offline   Reply With Quote
Old 01-20-2011, 06:35 AM   #22
1986 25' Sovereign
Plant City , Florida
Here is a link to the LEDs I bought. They are 350ma on the forward current and 3.2 volt. I did the setup with the LEDs @ 60%. Are you saying i should go higher? I based this on the voltage of 13.8 which is the max I have ever seen on the system with the exception of equalization.
ck21084 is offline   Reply With Quote
Old 01-20-2011, 10:16 AM   #23
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
ck21084? DealExtreme direct out of china has LED's and drivers for about 30-50% of the ones you linked. Not that I'm pro-import but 95% come from there anyways... Reading the comments of the devices gives some good insight too.
Old 01-20-2011, 02:44 PM   #24
RankAm's Avatar
1956 22' Flying Cloud
Dallas , Texas
Chris I.
Thanks for your informative message. There is so much to learn about when redoing an Airstream, and it is extremely helpful to learn from others with more knowledge! Hank L.
RankAm is offline   Reply With Quote
Old 01-20-2011, 11:56 PM   #25
Images: 12
Originally Posted by Wabbiteer View Post
Karma to dljosephson for couching technology so understandably.
A vehicles flooded lead-acid battery will appear as an open circuit to the charging source when its fully charged. It starts rejecting acceptance of current around ~14.7V which can allow the alternator (converter) charging circuit to not be limited by the battery load allowing voltage drift to whatever the internal alternator (converter) regulation will allow.
Ouch! I wish that were so! May I send you some exploded batteries that were fed 16 volts for a few days? Fully charged, a lead-acid cell sits at about 2.09 to 2.12 volts (12.6 nominal for a 6-cell battery like we use). It starts drawing a little current at this voltage (lower if it's discharged) and more as the applied voltage is increased, practically without limit. Alternators are typically regulated to try to produce 14.2 to 14.6 volts to make up for some losses in the wiring, and maintain this voltage even without a battery connected. It would be very dangerous to assume that a battery rejects current at any higher voltage.
Usual values for newer higher output LEDs is 3 to 3.5V at 300 to 350 milliamps which yields a 1 watt LED (3.5 x .300 =1.05w) so if I string three in series I would need 9 to 10.5V with a resistor to limit the string to 300mA. If they use a generous resistor the light looks good when running off a battery alone but will fry itself eventually when it sees 15V. If they use a stingy resistor the light survives the higher voltage but may appear dim when fed off the battery alone.
That's right -- which is why they use low value resistors, to get the most light out of culled cheap LEDs. On 12 volts they are probably okay, but on typical Univolt or programmed charger voltage of 13.6 to 14.5, not good.
Anyway - just some more detail to throw into the fray. Looking for aluminum housings and the wide-voltage range may mean a little better initial design....
Agreed - but there are "aluminum" LED housings out there that are actually plastic, and some I've seen aren't thermally coupled to the LED die at all.
Like anything else, caveat emptor ...
Old 03-06-2011, 10:54 PM   #26
Road Geezer
Road Geezer's Avatar
2011 27' FB Flying Cloud
San Jose , California
Images: 34
We just bought a 2011 27 FC. The interior lights are--were--all LED. My wife and I found that they were such intense point sources of light that we started seeing yellow spots after being inside with the ceiling lights on. I posted this inquiry in a different thread and the few that read it had had no adverse experience like we did. I'm wondering if anyone here has had the same experience. So, with apologies for repetition, here's my question: Has anyone else had this problem, and if so how did you fix it? For example, did anyone make some sort of diffuser to lessen the intensity of the LEDs? Also, the factory-installed LED color temperature--blue-white--is too harsh for our taste, but before I replace them with warmer color LEDs, I'd like to know if there's a solution to the intensity problem.
As a stopgap, I replaced all the LED "pancake" light fixtures with 12v halogens. They work great, but the obvious problem we've had is that these lights seem to suck the batteries dry.
I'd appreciate any help
Paul
Road Geezer is offline   Reply With Quote
Old 03-29-2011, 06:22 PM   #27
64GlobeTrotter68Overlande
man7sell's Avatar
1964 19' Globetrotter
1969 27' Overlander
Snohomish , Washington
Converted most of the lighting in my boat to LED. The marine lights are designed for the same voltages as an RV would get from an alternator, battery charger, or converter from the shore power.
One thing that can be done is for all lighting circuits put in a Zenor diode rated for 12 VDC. I found that on the boat just one of these lengthened the life of my incandescents and then later my LEDs.
You can now but 12VDC rope lighting that I intend to use like airplane mood lighting by hiding the rope behind a valance.
Here's a mock up shot of the rope lighting behind the stereo cabinet, looks cool with the curvature of the AS end.
Capt. Paul Mansell
1964 Globe Trotter
1968 Overlander
https://www.airforums.com/attachment...ic34024_12.gif
man7sell is offline   Reply With Quote
Old 03-29-2011, 07:48 PM   #28
2007 25' Safari FB SE
Eureka Springs , Arkansas
I installed 3 LED's from diff sources in the ceiling.
Last weekend was our first trip.
I did learn that they are a better indicator of battery strength than the "Status monitor".
Status monitor showed batteries were good(green). LED's wouldn't light, nor would the furnace @ 37 degrees outside!
After a cold nite, removed batteries, had them checked, both 10+ volts, replaced them and all is OK!
I do think I will replace all lights with LED's as they are much cooler. Color seems much better than earlier ones. There are brights dots, but don't look directly at them.
triplenet is offline   Reply With Quote
Tail Light Monitors? MDSilverado Lights - Interior & Exterior 3 10-19-2015 07:15 PM
How to Light the Pilot in the Oven lcurrie Stoves, Ovens & Microwaves 3 08-01-2011 07:16 PM
Upgrading to LED lights denali Lights - Interior & Exterior 17 02-20-2011 09:10 AM
LED light upgrade BarnacleBill Lights - Interior & Exterior 11 01-31-2011 10:50 AM
Panel indicator light for water pump and Water heater DJW Water Heaters, Filters & Pumps 3 01-05-2011 07:01 PM
