Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 09-07-2006, 05:51 PM   #1
toastie
toastie's Avatar
Profile:  1965 17' Caravel
1955 22' Safari
Livingston County , Michigan
Replacing my Univolt in my 1965 Caravel
and would like to know what would be a good brand to go with, and the size that I would need........thanks for you time
toastie is offline   Reply With Quote
Old 09-07-2006, 06:12 PM   #2
Streamin 65
Streamin 65's Avatar
Profile:  1965 26' Overlander
Marysville , Ohio
Images: 14
Intellipower!
I put a 45 amp intellipower in our '65 Overlander and it has been just great. I got it new from Ebay for about $110 delivered in an OEM box, and it did come with the charge wizard and instructions. Easy to hook up and does not buzzzzzzzz like the old Univolt. Not to mention it's about 40 lbs. lighter. So far, it has kept the batteries charged and has ample power to run all the 12v stuff without any problems whatsoever. Highly recommended. --dave
Streamin 65 is offline   Reply With Quote
Old 09-07-2006, 06:34 PM   #3
Pick
Pick's Avatar
Profile:  1972 31' Sovereign
High Springs , Florida
Images: 36
Ditto on the Intellipower 9100, with Charge Wizard. Wish I had done this a couple of years ago. Before my nice Trojan battery had it's brains boiled out twice by the Univolt.
CP 9 miles off Exit 399, I75.
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
Old 09-07-2006, 06:40 PM   #4
Melody Ranch
Melody Ranch's Avatar
Profile:  1966 17' Caravel
1947 22' Liner
Valley View , Texas
Images: 18
replacement
Probably wont help with all the advice going on....but, I went with WFCO and Lifeline battery. Stayed away from the 9200 intellipower on advice from service facility.
Love them Caravels!!!
Old 09-07-2006, 07:34 PM   #5
toastie
toastie's Avatar
1955 22' Safari
When hook-up to shore power I hear no buzzzzzzzz from my univolt.........
Old 09-07-2006, 09:31 PM   #6
Stan Z
Vallejo , California
toastie,
Mine never hummed either, but it also didn't charge the battery. If found an explanation somewhere on these forums (try the search function) that some Caravels just had a "univolt" labelled switch box but no charger. If your Caravel is like mine it has a "univolt" switch box under the side gaucho and a transformer box just to the rear of the wheel well. The transformer changes 110v to 12v when you are plugged in.
I was just pulling the battery out and using a car charger to charge up the battery before a trip. Then I got a Intellipower with charge wizard. It charges the battery anytime the trailer is plugged into shore power. I am very happy with the set up.
Stan Z is offline   Reply With Quote
Old 09-12-2006, 04:46 PM   #7
toastie
toastie's Avatar
1955 22' Safari
Originally Posted by Stan Z
toastie,
I looking at buying Inteli-Power 9245C Converter/Charger with Charge Wizard 45 Amp,725 Watts, Dimensions 4.5"H x 8.25"L x 7.25W". Input: 120 VAC Nominal, 50/60 Hz. Output: 13.6 VDC Nominal. Is this large enough for a 1965 Caravel or should I go larger
Old 04-29-2008, 05:27 PM   #8
cosmo9404
cosmo9404's Avatar
Tualatin , Oregon
toastie,
Stan, where did you install the Intellipower? Did you pull the transformer, use the 110V AC input, and use the 19VAC and 12VAC as the Intellipower output?
Thanks, Cosmo9404
cosmo9404 is offline   Reply With Quote
Old 04-29-2008, 06:51 PM   #9
Smokin Camel
Profile:  1972 25' Tradewind
Madison , Wisconsin
My 2 cents--I ordered a 55 amp WFCO from Randy (Best Converter) and have been very happy with it.
Smokin Camel is offline   Reply With Quote
Old 04-29-2008, 08:08 PM   #10
Lothlorian
Profile:  1973 27' Overlander
Loganville , Georgia
I have a 30 amp trailer so I bought a 30 amp converter. I was patient and took my time shopping. I bought mine off the Internet new and got it for under 100 dollars. Everything I have read says go with a converter that reflects the amps your trailer uses. If you have a 30 amp wired trailer get a 30 amp converter.
SIU Bound
Brian
Lothlorian is offline   Reply With Quote
Old 04-29-2008, 08:55 PM   #11
Toldfield
Tom O
Toldfield's Avatar
1968 26' Overlander
Altadena , California
I put a 45 amp Intelli-Power in a couple of weeks ago. I purchased it from Progressive Dynamics, Hot Deals- RV Power Converters and Marine Battery Chargers for sale. They have factory refurbished ones for about $159 with a warranty. It arrived in a couple of days with no hassles. The area where the old transformer lived was pretty small and had no ventilation so I installed it on the vertical panel forward of the battery. I wired into the original factory rats nest fuse/distribution setup and will replace that mess in the next couple of weeks. A day after I completed the job we went up north of Santa Barbara for three days and were amazed to find electrical hookups in a county park campground. It worked just great. The battery was kept fully charged, we had more electrictiy than needed, and it was quiet. I think the trash guy got a hernia when he lifted the can with the old Univolt.
Tom
"Badges? We ain't got no badges. We don't need no badges. I don't have to show you any stinking badges!"
Toldfield is offline   Reply With Quote
Univolt FACTS smily Electrical - Systems, Generators, Batteries & Solar 69 08-19-2005 12:47 AM
Restoration of our Airstreamer Caravel Hagen 1965 Caravel 2 11-10-2002 03:15 AM
1981 Airstream Excella Univolt dienst1 Airstream Motorhome Forums 1 08-20-2002 10:05 AM
univolt III wiring McGill Electrical - Systems, Generators, Batteries & Solar 0 07-05-2002 09:26 PM
Bambi II is a Caravel... VintageRV 1964 Bambi II 0 02-24-2002 08:55 PM
test
