Old 04-04-2003, 07:06 PM   #29
Not as good as 2 batteries, but:
We had only one battery in our 1974, and when we changed the refrigerator, this paused a problem, as the control panel on these "new" models was something unexpected. This is the place where you do not want to run out of juice. So, our fridge now has it's own battery.
To avoid wiring it in the system, we've put it at the bottom of the pantry, and use a Sears battery minder. We have been using that for over 2 years.
There is close to one inch venting at the bottom of the doors, and we make a point to leave the door ajar when we are on shore power.
Maybe a similar set-up can help you.
Name:	fridge battery.jpg
femuse is offline   Reply With Quote
vintage airstream battery wildcat455 Electrical - Systems, Generators, Batteries & Solar 4 07-02-2003 12:50 PM
Battery Exploded wayner1239 Electrical - Systems, Generators, Batteries & Solar 15 05-11-2003 08:43 AM
Univolt with Battery Minder COArgosy78 Electrical - Systems, Generators, Batteries & Solar 32 03-10-2003 07:59 PM
deep cycle battery replacement 26Argosy.ca Electrical - Systems, Generators, Batteries & Solar 6 01-02-2003 05:19 AM
igniton switch and the mystery of the dead battery Curtis-79MH Airstream Motorhome Forums 3 10-25-2002 02:58 PM
