Old 08-23-2019, 01:55 PM   #1
susans69's Avatar
1976 Argosy 26
Lake Wales , Florida
Replacement A/C
I am replacing the a/c on my 26' Argosy 1976. I am looking at the Dometic Brisk II 13,500 btu . Anyone have that unit and is it a good one?
susans69 is offline   Reply With Quote
Old 08-23-2019, 02:01 PM   #2
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
I had the original Coleman a/c replaced with a 13,500 btu Dometic at JC a few years ago. Last winter I added the Micro-Air Easystart - https://www.microair.net/products/ea...nt=30176048267 - It works just fine.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
WBCCI 8080
blkmagikca is offline   Reply With Quote
Old 08-23-2019, 04:15 PM   #3
2019 25' Flying Cloud
Hendersonville , North Carolina
13,500 vs 15,000
Would this be a good time to upgrade cooling capacity a bit by going with a 15,000 BTU unit and throw in the Heat Pump feature also? Just a thought.
uraljohn is offline   Reply With Quote
Old 08-24-2019, 03:35 PM   #4
Boerne , Texas
Images: 18
Check to see where the condensation goes. My Original Brisk 1 does not use the drain tube and just runs down the outside of the trailer. Thinking that if I ever have to replace it and find one that uses the tube.
James B.
1991 34' excella 1000, bought 05/10, oak floors, granite countertops, Marble bathroom counter and floor, 2 A/C's, 2005 Hensley.
Tow With: 2006 Dodge 2500 Quad Longbox 2WD, 5.9 Cummins, Edge Insight CTS, Smarty Jr programmer, Bilstein Shocks, Ingalls balljoints.
texascanuk is offline   Reply With Quote
Old 08-24-2019, 10:34 PM   #5
Paradise , Texas
Use a Coleman Mach 8.
15k btu, with condensate pump, and heat pump options is a magnificent, low profile, quiet ac that moves a ton more air inside vs a modern dometic airbox
Crackerman is offline   Reply With Quote
Axle replacement / Floor Replacement - Newbies! toesonoz Vintage Kin 12 07-02-2016 05:05 PM
