Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 06-12-2014, 11:29 AM   #1
2008 23' Safari FB SE
Boulder , Colorado
Replacement 7 way pigtail different than original - 2008 23 FBSE
I have a 2008 23FBSE and the pigtail 7 way connector was getting worn. I asked my dealer to order a new one from AS and replace it.
Lo and behold the new pigtail is not the same as the old one and is not snugging up into my pin receptacle like the old one did. The original pigtail that came on my 2008 23FB had a plastic notch on the top of it that when plugged in would stick up and I could then press down the receptacle cover over it and it would sit snug against the plastic notch thus holding the pigtail in the receptacle.
The replacement pigtail's notch is a good 1.5 inches away from where the old one was and therefore I can't push the receptacle cover down over it to hold it in the receptacle.
I called Airstream and the parts group told me all of the pigtails they use are the same.
Has someone else run into this problem and is there some old part number that I need to be referring to in order to get a replacement pigtail that is the same as my old one?
Of course, the dealer threw out my old one when they did the replacement.
Will try to snap a few photos later today so you can visualize what I am describing.
bonginator is offline   Reply With Quote
Old 06-12-2014, 12:06 PM   #2
richinny's Avatar
2011 34' Classic
i suspect that the new plug is not fully inserted into the truck. one of the male pins might not be aligned properly.
Ricky
Old 06-12-2014, 12:57 PM   #3
noreen&sal's Avatar
1981 27' Excella II
mays landing , South Jersey
Very common with a new plug. Try a little persuasion (light tap with something). Sal
Sal & Nora
Let us live so that when we die even the undertaker will be sorry. Mark Twain
AIR 42483
TAC N.J. 17
WBCCI 24740
noreen&sal is offline   Reply With Quote
Old 06-12-2014, 01:02 PM   #4
Boulder , Colorado
Richinny - It is inserted all the way. I get a connection reading on my brake controller that is good and operates.
The problem is that the tab sticking up is too far inward toward the receptacle so when I put the receptacle cover down, it doesn't snug up over the tab and hold the pigtail in.
Attached is a schematic diagram of old versus new..
Old 06-12-2014, 01:04 PM   #5
Boulder , Colorado
Trying diagram attachment again.
Old 06-12-2014, 01:09 PM   #6
Mantua , Ohio
Upside down, try it. Jim
Old 06-12-2014, 02:06 PM   #7
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Picture?
GCinSC2 is offline   Reply With Quote
Old 06-12-2014, 05:46 PM   #8
Boulder , Colorado
OK - I am eating a little humble pie right now, everyone. I went back to the pigtail and pushed it very hard into the receptacle and then put the receptacle cover down over it - bingo it latched onto the tab on the pigtail.
Thanks for all of the help! Problem solved - user error
Old 06-12-2014, 05:58 PM   #9
richinny's Avatar
2011 34' Classic
wow, that IS odd. ask the dealer to measure one from stock and compare it to one on a trailer on their lot.
Ricky
Old 06-12-2014, 06:15 PM   #10
GCinSC2's Avatar
Might want to look carefully in the plug contact sections just to check. Also MIGHT want to get a small tube of dielectric grease for terminals.
CAT Scale Results - '08 Safari 23' FBSE + '08 Tundra DC 5.7 4x4 bonginator Towing, Tow Vehicles & Hitches 9 06-17-2010 07:54 AM
Airstream not any different than the others Krazyjohnny 2007 Safari SE 360 03-26-2010 06:15 AM
Different Looks on Different Computers COArgosy78 Forum Admin, News and Member Account Info 3 09-20-2003 02:38 PM
