Old 12-28-2008, 12:50 PM   #1
1972 25' Tradewind
Dallas , Texas
Replace Power Cord
Just bought my first Airstream... a 1972 Tradewind. I saw it for the first time this weekend and it needs some work. For starters, the power cord is completely dried out and cracked and needs to be replaced. Is this relatively easy for a newbie to replace? Any hidden issues to prepare for? Any advice would be welcome. Thanks.
ZacharyTX is offline   Reply With Quote
Old 12-28-2008, 01:05 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
Try and see the cord after it enters the trailer to see it that section of the cord is still good. You may have to cut an access hole in the floor but if the section within the trailer is good you can splice your new cord in there.
I say this because snaking the cord through the trailer body to the panel box may be impossible short of removing the inner skin.
2004 Excursion 4x4
Old 12-28-2008, 01:37 PM   #3
cameront120's Avatar
1972 25' Tradewind
Do an in line splice joining a new chord to the old and pull it through from the inside. It's a sort path from the rear bumper compartment to the rear closet housing the univolt.
North Vancouver, BC
Old 12-28-2008, 02:44 PM   #4
Janets Husband's Avatar
1977 Argosy Minuet 6.0 Metre
1964 26' Overlander
1977 25' Tradewind
Eastern , Washington
Here is your chance for an upgrade. If you should choose to do it you can put a Detachable Power Cord set in. They are made by Marinco and they have instructions. Pretty cool to detach your power cable and store it inside. This is an example of the kit: Amazon.com: ParkPower by Marinco 30ARVKIT RV Detachable Power Conversion Kit (30-Amp): Sports & Outdoors
If you chose not to do this upgrade, buy a new cable with a 90deg. angle plug molded onto the cable. 25' should do you. It will have to be pulled up into the trailer service box and attached to the main breaker. You probably have at least one cable clamp to deal with on the old cable. You and a helper can then pull the new cable in place. You should be able to attach the new cable to the old one and slowly tug the new one into position. Strip the outer jackets of the cables and join them together and try to keep your pull connection as small as possible or it will hang up going through the floor.
Peace
Gary
Janets Husband is offline   Reply With Quote
Old 12-28-2008, 04:04 PM   #5
The original city power cable was 25 feet long, totally.
We suggest that the Canadian replacement be used, since it's specs are the same, but it's 36 feet long.
That extra few feet will come in handy far more times than you think, eliminating the usual need for an extension cord.
Power Cord replacement, 1959 Tradewind plowboy Electrical - Systems, Generators, Batteries & Solar 16 12-31-2013 04:03 PM
Battery to AC power cord??? Jim Casavant Batteries, Univolts, Converters & Inverters 9 07-22-2007 03:46 PM
Stand up power cord Happycampers Electrical - Systems, Generators, Batteries & Solar 0 04-18-2004 07:03 AM
power cord end Rick's73 Electrical - Systems, Generators, Batteries & Solar 6 07-29-2003 08:34 AM
Hot Power Cord GoldFever Electrical - Systems, Generators, Batteries & Solar 7 07-13-2003 05:49 PM
