Old 04-01-2012, 09:40 AM   #1
2dabeach's Avatar
2007 25' Safari FB SE
North/East , New Jersey
Replace Grp 24 Batt with Grp 27 2007?
I have a 2007 25'FB Safari with the standard front frame mounted battery box with 2-Group 24 deep cycle batteries. I'll be replacing the batteries this season and want to know if anyone has replaced the 2-Group 24's with 2-Group 27 batteries without any modification to the battery box? I would go out and measure the box but my trailer is 50 miles away in a storage yard. Thanks
2007 Safari 25' FBSE LS
2006 GMC Sierra 2500HD Crew Cab 4WD Duramax
2dabeach is offline   Reply With Quote
Old 04-01-2012, 09:50 AM   #2
Evergreen , Colorado
Fairly sure they wont fit. I checked into this with my 2008 23D, and unless you have a slightly larger box it wont work. Might be easier to go with 6 volts as you just have to raise the height of the box. Width can be limited by the frame width.
Nightwatch is offline   Reply With Quote
Old 04-04-2012, 09:55 PM   #3
JFScheck's Avatar
2013 27' FB International
Bethesda , Maryland
Images: 20
I just checked and I agree that I don't think that this will work out as you have suggested.
John "JFScheck" Scheck
TAC Member ID = MD-1
TV = '13 2500 Ram Cummins 4x4 Laramie - Bright Silver Metallic & Black Leather
TT = '13 27 International - Serenity Decor with Espresso Ultraleather
Hitch = ProPride "Pivot Point Projection" (3P) Hitch
**I Love U.S.A.**
JFScheck is offline   Reply With Quote
Old 07-11-2012, 12:30 PM   #4
2011 25' FB Flying Cloud
Anywhere & , Everywhere
According to comments from Lewster you can replace 24's with 27's if you remove the plastic tray in the bottom of the battery box. Tight fit but will work and from measuring my battery box and looking at the 27's dimensions I believe it will work but have not tried it yet.
Al - K4GLU is online now   Reply With Quote
Old 07-11-2012, 12:34 PM   #5
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Originally Posted by Al - K4GLU View Post
...the plastic tray in the bottom of the battery box...
There's supposed to be a plastic tray in the bottom of the battery boxes?
I can see the potential for making the batteries easier to get out.
Vaughan
Old 07-11-2012, 04:06 PM   #6
2008 27' Safari FB SE
Mesquite , Texas
The plastic tray has to go.
The battery you select may or may not fit without slight trimming.
Many batteries have handles, mounting tabs, etc. that extend beyond the basic battery dimensions.
I saw a post where CrawfordGene put group 27 life-lines into the factory battery box of his 25FB. I can't locate the post but I am pretty sure he had to do a little trimming with an angle grinder on the top flange of the battery box as well as trimming a little of the plastic from the batteries where the carrying handle was attached to make it fit.
I was going to put Interstate Group 27's in but I couldn't figure out a way to make them fit without significant modifications so I abandoned the idea and went with Group 24's. I probably didn't spend enough time looking for a solution that day though. I was in a hurry and rain was heading my way....
wayner61 is offline   Reply With Quote
Old 07-11-2012, 04:22 PM   #7
2005 28' International CCD
Maple Plain , Minnesota
NIGHTWATCH has the right idea. You gain amp hours with 6 Volts which is what you want and the "fix" is simple by increasing the height of the box with four pieces of pt wood and reattaching the lid. I ripped some 2" x 2" pcs and screwd them to the top of the box.
Look at this link for dimensions: BCI Battery Group Size Chart
It will give yu battery dimensions for various "Groups" assuming you remember how well you Group 24's fit the box.
tomp is offline   Reply With Quote
Upholstery, remove or replace Hopichangi Upholstery, Blinds, Walls & Interior Finishes 34 05-31-2012 03:02 PM
Any issue with putting new floor over existing linoleum? mikeandnora Floor Finishes 7 04-04-2012 09:51 PM
Towing with the 345 galaxian Airstream Motorhome Forums 6 04-02-2012 11:14 AM
Bikes on classic ltd 27 ft Focusfactor1 On The Road... 9 04-01-2012 08:03 PM
Vintage 1966 27' Airstream Overlander International - ready for renovation eBay Watch Airstreams on eBay 0 04-01-2012 09:20 AM
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
