Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 07-29-2006, 10:11 PM   #1
jpsdo
jpsdo's Avatar
Profile:  1977 31' Sovereign
Arlington , Texas
replace control panel with LEDs, Anyone??
Anyone have some simple circuit designs or ideas to replace the control panel on a 77 soverign (water tanks, voltage, amps etc) with a smaller configuration that just uses some leds maybe? I am doing a total remodel, and the gauges all spread out like they are are just too bulky. It just seems like a small cluster of LEDs could reduce the size needed for such a panel by one fourth or so. I have found one commercial unit that monitors the tanks, but I just want to avoid rewiring the whole thing. jpsdo private message or email jpsdo@hightream.net
jpsdo is offline   Reply With Quote
Old 07-30-2006, 06:22 AM   #2
wahoonc
Rivet Monster
wahoonc's Avatar
Profile:  1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 35
jpsdo,
The 1980 Excella has LED indicators in it. Maybe you could chase down the digram of a circuit board for that? The one used in the 1980 isn't very compact it is about 3" tall and 2' long, but that may have been the design.
Aaron
WBCCI #2449 AIR #2495
Old 07-30-2006, 09:44 AM   #3
jpsdo
jpsdo's Avatar
Arlington , Texas
Originally Posted by wahoonc
jpsdo,
Aaron
Thanks, Ill chase that one down and see what is in the board. jpsdo
Old 07-30-2006, 10:22 AM   #4
Zeppelinium
Zeppelinium's Avatar
Profile:  1970 18' Caravel
1977 23' Safari
1975 31' Sovereign
Palmer Lake , Colorado
can you publish just one leg of the sensor circuit (tank sensor to LED), when you find it? Thanks.
Current 6-word memoir: Vintage Airstreams: Four are not enough.
www.mindseyephoto.com www.airstreamdoctor.com
Old 08-09-2006, 10:24 PM   #5
Zeppelinium
1977 23' Safari
1975 31' Sovereign
quick tank circuit
Here's a design for a fresh water tank level sensor that uses LED indicators. Current draw of the chips is very low, on the order of 1 ma (if you use the CMOS versions), but the LED will draw up to 20 ma. I'll add some sophistication if there is enough interest in the community for a kit--a circuit that pulses the LED to reduce average current draw to about 4 milliamperes, low enough that the sensors can remain on all the time you're in the Airstream.
I took a look at discrete logic chips and it seems that 74LS (low power schottky) or 74HCT (CMOS) chips have a high enough input impedance that they can detect the connection due to imersion between the tank sensors. The early 70's Airstreams had 4 wires from the tank, a ground and 3 level sensors (I call them contacts--they are just screws through the side of the tank). The circuit in the graphic provides the following indications:
Green: Top contact in water/fluid
Yellow: Middle contact in fluid, top contact out of fluid
Yel/Red: Bottom contact in fluid, upper two out of fluid (this indication has two LEDs lit up)
Red: None of the upper 3 contacts is in the water/fluid (presumably the ground contact is always in the water)
I thought about getting four colors, but orange and blue are either not readily available or don't provide enough color discrimination. However, I wanted to show a definite difference between the lower contact in the water and the lower contact out of the water, to give 4 levels.
If there is sufficient interest, I'll lay out a small PC board, about 4x6", with three indicator channels--one for fresh water and two for holding tanks (the logic for the holding tanks is a little different, since they only have three wires--ground, half full, and full).
The cost of parts for what I've done herefor one channel is about $8--the most expensive piece would be a prototyping board from Radio Shack, about $5. The logic chips (74xx04, hex inverter, and 74xx08, quad 2-input nand gate) are like $0.40 each, plus LEDs, resistors and a small three-terminal voltage regulator. You can add a second channel (black tank) for another $2, just resistors and LEDs, since the two chips have enough gates for two channels. For everyone with a pre-1975 trailer, you ony need two channels. That's it.
The prototyping board is laid out on 0.1" centers, perfect for chip sockets and spacing the LEDs. You'd have to make a new bezel on your own. If you wanted to use the existing panel (mine has 12V light bulbs--you'd have to add another chip that has open-collector outputs to handle the voltage. It's only another $0.40, but it's another 10 wires on the board and then all thew wires to the bulbs) there is a way to do it by wiring the existing light bulb sockets into the board. The logic is the same.
For 1975 and later, you need three channels (fresh water, grey and black holding tanks). But there is a twist. The three sensor wires are shorted together and the meters that indicate level sense a total resistance, as each of the sensors (contacts) is immersed. I need to do a little experimenting to see if I can create a small system to duplicate that method method of using only two wires, since only two wires show up at the control panel.
A printed circuit board that would go together without any discrete wiring would add about $30 to the project. I'd need to hear from 20 or so members who were interested in order to make that happen. Don't let all the above ancient electronic stuff scare you away. The PC board would be simplicity itself, compared to taking care of rear end sag and polishing!
The resistors can't be specified without further experimenting. The pullup resistors worked fine at 56K, but my quick test of water impedence showed 50-200K with the probes in the water, so I'd be more confident if the pullups were about 350K (for CMOS--none needed for schottky). The series resistors for the LEDs are necessary to limit the current to 20 ma max, but there is a further complication. The different LED colors have different efficiencies in converting current to light. So you would want to balance the brightness by using appropriate resistors to modify the current. For example, even low efficiency green, yelow, and red LEDs have brightness specifications varying from around 5 millicandles to 700 mcd. So the series resistor would vary from about 250 ohms to 5000 ohms.
It'll be a the middle of September before I can refine this. Let me know if you're interested.
Old 08-14-2006, 08:40 AM   #6
firefly007
firefly007's Avatar
Profile:  1964 17' Bambi II
longwood , Florida
Nice work on the LED, Led.
Here in Orlando we have a great resource for projects like this. You can see a sample of what they have online at www.skycraftsurplus.com . I have never ordered online because it is just down the street but it is a great place to find what you need. Ask for Alby or maybe it is Al B. He can pull whatever you need. I may have to build one from scratch some day because the factory units seldom work. After a month they seem to read FULL all the time.
Steve
firefly007 is offline   Reply With Quote
Old 08-14-2006, 09:29 AM   #7
Zeppelinium
1977 23' Safari
1975 31' Sovereign
would you be surprised to know that every time I pass through Orlando I go there and buy a pocket full of LEDs, hardware, connectors, etc.? great place!
The only one better is Mendelson's Hardware in Dayton. Even Colorado springs has one to match, OEM Hardware, that has similar stuff and is about 6 times bigger.
Old 08-15-2006, 10:48 AM   #8
firefly007
firefly007's Avatar
longwood , Florida
Not surprised, you seem to be about two jumps ahead of me. Wish I was closer to one of the bigger sources.
Old 08-19-2006, 09:54 AM   #9
Zeppelinium
1977 23' Safari
1975 31' Sovereign
PC Board Quote
I went out to a PCB house to see what a 6"x3" board would cost (cost of the bare board--probably add a few cents for tax and shipping).
10 - $25
25 - $12
100 - $6
How many owners out there need new control panels, or at least new tank level displays? PM me and I'll see if this should go forward as a kit or just plans.
Zep
GM a/c control panel rdm Mechanics Corner - Engines, Transmission & More... 5 11-11-2002 08:30 PM
replacement panel maznblu Ribs, Skins & Rivets 4 09-18-2002 06:45 PM
Should I replace the fuse box with a breaker panel? Andy R Electrical - Systems, Generators, Batteries & Solar 2 09-13-2002 11:21 PM
Control Panel Indicators niftypkg Electrical - Systems, Generators, Batteries & Solar 8 08-09-2002 04:24 PM
Control Panel indicators smily Electrical - Systems, Generators, Batteries & Solar 3 07-26-2002 04:55 PM
test
