Old 01-01-2012, 12:41 PM   #1
DougZ's Avatar
1972 27' Overlander
Venice , Florida
Removing the Univolt
Can anyone instruct me how to removed the Univolt box from a 1972 Overlander. It is mounted on a piece of plywood that seems to pivot a couple inches left or right but I can't find out how to get it to come forward. I would rather find out the correct way to do this instead of just ripping things apart.
Doug
TAC FL-1
W4JDZ
DougZ is offline   Reply With Quote
Old 01-01-2012, 12:59 PM   #2
Maniacal Engineer
barts's Avatar
Menlo Park , California
If I remember correctly you want to remove the Univolt from the plywood first; there's fastener(s) underneath holding the plywood down. If you want to verify this, scribe the arc the plywood forms; the center of the arc's circle is where the fastener is....
-= Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Univolt question Stonew98 Batteries, Univolts, Converters & Inverters 11 12-19-2011 08:15 PM
Weird Univolt noise (no not the hum) and power flicker ovrteakettle Batteries, Univolts, Converters & Inverters 12 12-07-2011 11:31 PM
Battery Tender and Univolt? AldeanFan Batteries, Univolts, Converters & Inverters 8 08-31-2011 11:16 AM
Removing window frames 61 GT streamahead Windows, Doors, Locks & Vents 3 07-30-2011 09:47 AM
Univolt on a 1976 Caravanner wba1 Batteries, Univolts, Converters & Inverters 12 07-27-2011 07:13 PM
