Old 04-17-2014, 11:20 AM   #29
time2play's Avatar
2013 30' Classic
Kent , Washington
Originally Posted by kscherzi View Post
I don't like the red and blue flashing screen that it defaults to every time the trailer powers up. Kind of tacky.
I agree with this completely! Darn flashing lights are annoying as heck!
Yolanda (and Phil)
2013 30' Classic Limited
2015 GMC Sierra Denali 2500HD
ProPride 3P Trailer Sway Control Hitch
WBCCI #7878
time2play is offline   Reply With Quote
Old 04-17-2014, 12:47 PM   #30
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Just push the "source" button for 2 seconds and it will stop the "disco demo" mode.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 04-17-2014, 12:52 PM   #31
m.hony's Avatar
2013 30' Classic
When installed in a car, there are settings to over- ride this feature. I think to be able to do it in our trailers some re-wiring might be necessary. In a car, you have two 12-volt leads. One is constant to keep the memory for the clock, tone control setting, and station presets. The other is switched to make the radio power down when you turn off the ignition. Whenever you flip the "store/use" switch the radio goes to default settings. The radio needs a constant 12 volt source like the tongue jack has.
TAC #MS-10
Airforums #70955
Old 04-17-2014, 02:30 PM   #32
Ottawa , ON
You could pick up a constant 12V from the CO alarm, IIRC. I believe it stays alive regardless of where the 'Store/Use' switch is set. I think that the yellow wire is the one to keep 'alive'. I know it is on Pioneer units, in any event.
Old 04-17-2014, 02:32 PM   #33
m.hony's Avatar
2013 30' Classic
That is correct.
TAC #MS-10
Airforums #70955
Old 04-17-2014, 09:55 PM   #34
kscherzi's Avatar
2013 27' FB International
El Dorado Hills , California
Images: 24
Interesting. I'm already wondering how to bridge off the CO2 alarm to the radio. It in a overhead, so how to drag the wire....
kscherzi is offline   Reply With Quote
Old 04-18-2014, 06:56 AM   #35
Ottawa , ON
Might be easier with the CO alarm since they are only around 4" from the floor.
Old 04-18-2014, 01:32 PM   #36
first choice's Avatar
1997 25' Excella
Sault Ste. Marie , Ontario
Insert two plastic tie wraps, one on either side and it will work fine.
first choice is offline   Reply With Quote
Sony Radio Reception Ray Eklund Audio, Video & TV 26 11-22-2011 08:39 PM
Aux input for Sony CDX-F5000 Radio/CD Wingeezer Audio, Video & TV 12 05-31-2011 06:29 AM
Sony radio woes nwclassic Audio, Video & TV 26 04-03-2011 09:11 PM
Have you replaced your Sony radio? Kistler Audio, Video & TV 8 12-23-2007 04:46 PM
sony radio/CD player dhe9 1997 - 2004 Bambi 1 11-13-2004 07:22 PM
