Old 03-04-2013, 09:27 AM   #1
2007 25' Classic
SW Florida , Florida
Remove one battery permanently
Very seldom do I boon dock, when I do I have a EU 1000 for battery charging. My question both batteries need replacing if I replace only one and tape up the + cable on the other side everything should work fine other than reduced 12 Volt capacity ? correct ?
tailpipe is offline   Reply With Quote
Old 03-04-2013, 10:01 AM   #2
dznf0g's Avatar
Oswego , Illinois
Yes, but I wouldn't rely on tape. I would remove the batt furthest away from the converter and remove the battery leads for the removed one at the junction of the present cables.
-Rich-
Old 03-04-2013, 11:12 AM   #3
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
If you're using the same amount of electricity off one battery as you did off two, you'll be charging that battery twice as often. If cost savings is the driving force behind the change, you might want to figure out how many hours you can run your generator for the price of that second battery.
Chances are, if you don't boondock often, running on just one battery and charging twice as often WILL be cost-effective. Especially if you time your recharges so that the main energy hogs can run directly off the generator while you're charging the battery.
For other people who spend a significant amount of time boondocking, that second battery might eventually pay for itself in terms of saved generator fuel.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 03-04-2013, 11:24 AM   #4
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Also take into account....
If you determine after a Season of Camping/charging that you do need two batteries, you'll have to buy two new for best results.
PFC
but Iím the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 03-04-2013, 12:59 PM   #5
1976 31' Sovereign
Oswego , Illinois
Smile
Older AS only used ! battery,I have had ! failure in 52 yrs. because battery went bad it was old
Old 03-04-2013, 01:14 PM   #6
Before anyone else chastises me for the over-simplification in my previous post, please note: while you'll be charging twice as often because your battery drains faster, you will be only running your generator about half as long each time, since it will take fewer amp-hours to bring the one battery up to full charge than for two.
It doesn't QUITE balance out. Because of the way charge controllers work, it's not a straight "twice as often for half as long." You'll still use more fuel than if you were charging two batteries half as often. But not a LOT more. And you can hide that increased consumption depending on WHEN you recharge.
Here's more practical adviceÖ
If you can at least get a full 24 hours runtime on one battery, and can run your generator for recharging during the hottest part of the afternoon while it's powering your air conditioner anyway, then it doesn't matter if you have to recharge every day. But, if you get less than 24 hours of runtime on one battery before needing a recharge, then buy two.
If you get MORE than 24 hours on one battery, so much the better; recharging every day before the battery is drained completely extends your battery life.
WBCCI #1105
TAC LA-4
Old 03-04-2013, 01:34 PM   #7
1988 32' Excella
Robbinsville , New Jersey
Something else to consider, with 2 batteries hooked in parallel when one dies and can't take a full charge the other battery gets overcharged until it dies to or the bad battery is removed from the circuit since no matter how good your converter is with both batteries hooked together it sees the average voltage of both.
With that in mind if you don't need the capacity for boondocking your 1 battery should last longer then 2 as long as you don't run it dead due to the lower capacity.
Personally I just run 1 battery myself, I put the second positive wire into an old radiator hose and taped it to insulate it.
Old 03-04-2013, 03:49 PM   #8
Wise Elder
Jammer's Avatar
2010 30' Classic
It will work ok.
Like others posting upthread, I would hesitate to rely on tape alone. I would suggest covering the battery terminal with a large piece of split loom and then taping it.
Old 03-05-2013, 05:20 AM   #9
2007 25' Classic
Thanks everyone, I do not like 2 batteries in parallel. If I needed two batteries I would look into installing a battery selector switch just like a boat...and yes I did protect the cable end.
Thanks again
Old 03-05-2013, 05:43 AM   #10
Bruce B's Avatar
2012 16' International
Jamestown , Rhode Island
Thanks again
You get more amp hours out of your batteries by paralleling them then by separating them. Just in case you were not aware...
The link is to a website written by David Smead for boaters. He is one of the people who literally wrote he book on 12 energy system design and care. His work was the foundation for all 3 step temp compensated charge controllers that we use today and is great reading.
The Preferred System
Bruce
Bruce B is offline   Reply With Quote
Old 03-05-2013, 06:15 AM   #11
1988 25' Excella
Trumbull , Connecticut
Sandy Hook Memorial Fund
Hello Robert. I an courious about the Sandy Hook fund that you display in your posts. My son lives in Sandy Hook CT, which is a section of Newtown CT, and I drive past the school almost every day. Memorials are still all over the place.
I was just inquiring to your involvment.
Happy Camping nm1oqrz (Joe)
nm1oqrz is offline   Reply With Quote
Old 03-05-2013, 07:15 AM   #12
Free Range Human
Drathaar's Avatar
2012 25' FB Flying Cloud
Twin Rocks , Oregon
If you do go to a single battery, consider a group 27 if it will fit the box.
Remove the parallel jumpers, don't use tape.
Old 03-05-2013, 07:31 AM   #13
Ahab's Avatar
2008 22' Safari
Oracle , Arizona
I use one GR27 and boondock quite a lot with no problems.
Ahab is offline   Reply With Quote
Old 03-05-2013, 07:51 AM   #14
Thumbs up
Several days after the tragedy I saw an interview with the woman's basketball coach explaining the Memorial Fund....
"UConn's Hall of Fame women's basketball coach Geno Auriemma and his wife, Kathy, have made an $80,000 lead gift to the fund."
I realized that what they had done was probably one of the best ways to Honor the memory of all those effected and made a donation.
Believing that some of us here might also like to help I started a thread and was very surprised at the response.
Thats the rational behind the signature link, it's visible with every post I make, maybe it will help....just hope it has in some small way.
Thank's for noticing.
PFC
RLC
