Old 01-23-2018, 10:00 PM   #1
2016 19ft flying cloud
Spokane , Washington
Remote control for fantastic fans
Amazon has a conversion kit available for fantastic fans that adds a remote
Has anyone had any luck finding a retrofit kit that would add this feature to the fans airstream uses in their trailers ? The Amazon unit replaces practically the entire fan and is expensive
I have a short wife and it would be cheaper to get a remote added instead of a taller wife,
The other feature the new kit has is a reverse function too
Spinonedad is offline   Reply With Quote
Old 01-23-2018, 10:15 PM   #2
WaLee's Avatar
Nevada City , California
I don’t know about the conversion kits but the taller wife comment was pretty damn funny
WaLee is offline   Reply With Quote
Old 01-23-2018, 11:44 PM   #3
2007 22' International CCD
Not a safe comment around my house....
DW may not be tall, but she’s not known as the “Dragon Lady” for nothing...
KE4GNK/AE
Old 01-23-2018, 11:45 PM   #4
gandttimes's Avatar
2014 25' FB International
2007 20' Safari SE
2005 19' Safari
Qualicum Beach , British Columbia
When I wanted the reverse kit I just got hold of FF and got it from them. I believe they also had the remote available but as my wife is tall I didn't need it.😊
gandttimes is offline   Reply With Quote
Old 01-24-2018, 05:31 AM   #5
GLCMRANGER - Sue
2016 25' International
Littlestown , Pennsylvania
Just replace the entire fan with Maxxfans. Remote control and has a nice integrated cover. No need for the rain function.
glcmranger is offline   Reply With Quote
Old 01-24-2018, 10:41 AM   #6
Mike1997's Avatar
1998 36' Land Yacht Widebody
Ft. Lauderdale , Florida
Images: 14
Hey I replaced my original 1997 fan controllers (2 units) with the upgrade remote kit. Found it on Amazon and the install was easy.
My interior shroud had yellowed, cracked, and the rain sensor stopped working. The bedroom unit lift mechanism had broken also, however, the fans themselves were in good shape as well as the exterior cover.
The install took about an hour on first unit and half hour on second.
My original fans had a 3 speed switch visible from the inside. The bedroom unit also had a wall t-stat controller which I removed after the install.
The new remote controller says it has 12 speeds but mine only worked on high and low. It required a jumper switch being moved on the control board before the install which I did, but it still did not run at the various speeds. Spoke with company about this and they did not offer any suggestions other than moving the jumper.
Once installed they both work great and improved ventilation inside tremendously. They can be set for exhaust or intake. The new rain sensors are very sensitive and shut down quickly. Only thing you have to do on the outside is position the rain sensor, rest of install is done from interior.
Overall I am very happy with the remote operation but because they do not have a shroud cover over them, they will not run in wet or damp conditions. We had heavy due one night in FL and both units shut down before morning. That's a planned upgrade I will be making soon.
One last thing to keep in mind. Because they were changed to remote operation, there is constant current now going to them even when off. Inside the shroud at night you will see a red light glow that's similar to the antenna booster light. Just keep in mind the remote operation will cause it to draw current even when off where the manual operation did not.
Mike1997 is offline   Reply With Quote
Old 01-24-2018, 11:49 AM   #7
2018 19' Flying Cloud
Coeur d Alene , Idaho
Actually the new units as supplied by AS have the same red led and draw power unless turned off. This is a function of the rain sensor not the remote.
Dale & Jane
2018 Flying Cloud 19
2003 Dodge Ram 2500 Quad Cab Diesel
KelloggKid is offline   Reply With Quote
Old 01-24-2018, 09:43 PM   #8
greghoro's Avatar
2013 25' Flying Cloud
Wheaton , Illinois
Perhaps you can reach out to Kiss to see where they get their high lift shoes.
greghoro is offline   Reply With Quote
Old 01-24-2018, 10:23 PM   #9
Hey
Great ideal
You just saved me $300
Old 01-25-2018, 06:03 AM   #10
1975 24' Argosy 24
Wooster , Ohio
If anyone knows where to get a remote control for wives please let me know (no matter how expensive).
MaxD is offline   Reply With Quote
Old 01-25-2018, 06:14 AM   #11
BradT
2007 27' Safari FB SE
Milton , Georgia
I added a switch to totally turn off the power on both my fantastic fans for two reasons:
I have shrouds and like to use the manual feature to leave the lid to the vent cracked open for ventilation. The logic in the FF remote system causes it to close the vent every time power is interrupted and restored. I kept finding my vents closed.
The remote receiver and rain sensor are a small battery drain even when "off"
Added a switch on the stereo system too, for similar two reasons:
I like the stereo to stay "off" when i turn it off, but every time the power was interrupted and restored, it would initialize and light up. I kept finding the stereo on.
The stereo causes a small amount of battery drain even when "off".
bradt is offline   Reply With Quote
Old 01-26-2018, 09:26 AM   #12
Mike1997's Avatar
Images: 14
Brad....glad you mentioned the radio cause I got the same problem. Its a newer unit and lights up in Demo mode when power is switched.
Where did you mount the switch disconnect for the fans and radio?
Old 01-26-2018, 09:49 AM   #13
2017 27' International
Sioux Falls , South Dakota
I recently bought a couple of the Fan-Tastic 7350 upgrade kits. Yes, they are expensive, but as others have mentioned, you get a wireless remote control, reversibility, and a dozen speeds, including slow speeds that are whisper-quiet.
An important factor for me is that the new fans' solid-state speed controller draws way less power at low speeds that the old fans' inefficient resistor-based controller. The wireless remote uses infrared, but unlike most IR remotes it doesn't require super-precise aim. It has good range, too--I can control both fans individually from either end of the rig. For me the new fans were worth the money.
Paprika is offline   Reply With Quote
Old 01-26-2018, 12:57 PM   #14
GLCMRANGER - Sue
For that price, why not buy new MAXXFans?
Fantastic fans for Airstreams GJ Excella Roof Vents, Skylights & Fans 3 06-22-2008 06:14 PM
fans or no fans goransons Refrigerators 8 12-31-2007 12:21 PM
Fantastic Fans tslanier Roof Vents, Skylights & Fans 4 06-28-2006 09:34 AM
Fantastic fans very noisy - wore out? ipso_facto Roof Vents, Skylights & Fans 5 07-17-2003 06:47 AM
Bug filter for Fantastic Fans Bud Brown Our Community 3 05-16-2003 03:07 AM
