Old 12-10-2017, 08:03 AM   #1
Wray , Colorado
Regulating voltage on charging circuit from alternator
I have lithium batteries from a chevy volt that are limited to 12.2 volts max. Is someone aware of a way to regulate the circuit coming from my pickup going to the house batteries so that they are not overcharged?
Farmerdad is offline   Reply With Quote
Old 12-10-2017, 08:40 AM   #2
Ayr , Ontario
Check out this product. http://www.sterling-power-usa.com/BB...r12vto12v.aspx
gator.bigfoot is offline   Reply With Quote
Old 12-10-2017, 05:33 PM   #3
sgschwend's Avatar
1986 25' Sovereign
2008 F350, 6.4L diesel , Oak Harbor, WA
Images: 13
Your BMS should control that, there is a setting in the BMS program that sets the maximum charged voltage.
That is the way I do it. The setting I use is 12.5 VDC. Which I believe is the correct maximum voltage for a 3S battery.
I order the BMS from the Electric Car Parts company. Tell them your battery chemistry: NMC-LMO (nickel-manganese-cobalt).
sgschwend is offline   Reply With Quote
Alternator Generating High Voltage swebster Classic Motorhomes 14 09-24-2012 07:28 AM
Wiring a separate alternator for charging trailer batteries Streamside Batteries, Univolts, Converters & Inverters 12 01-04-2012 08:24 PM
Charging with TV Alternator baby_beluga Batteries, Univolts, Converters & Inverters 4 05-20-2011 10:13 PM
Pressure Reducer?...Regulating Valve? Hihosilver2 Fresh Water Systems 0 06-06-2010 03:10 PM
Alternator/ Voltage reg LKappenman Mechanics Corner - Engines, Transmission & More... 7 10-24-2002 10:24 AM
