Old 01-02-2015, 03:01 AM   #1
BirdofParadis
2009 27' FB International
CANYON COUNTRY , California
Regular Electrical Outlets do not work
A/S 27' International CCD: one moment all elec outlets worked ... now nada ... checked breaker box ... all switches on ... all fuses working ... what to do?
BirdofParadis is offline   Reply With Quote
Old 01-02-2015, 04:15 AM   #2
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
The transfer switch is known to fail, if you have one. That is, the switch that transfers shore power between the front shorepower inlet and the rear. Do you have AC to the converter?
Larry
lsbrodsky is offline   Reply With Quote
Old 01-02-2015, 06:27 AM   #3
ottawa (greely) , Ontario
Start up with checking for power at the supplied power outlet ( campground power) you can take a electrical table lamp and plug it into the campground socket with a adapter depending on supplied amp service ,that's if you don't have a multi meter and know how to use it then check the main breakers then all other breakers and then if still no power it's posible you have a failed component ( transfer switch )like was just mentioned. Or bad wiring .
Don
2012 silverado ext cab 4x4 ,5.3 L , 6 speed trans,3:42 final drive,tow package standard box 6 1/2 foot . 2014 honda forza 300 scooter, #2 2015 honda crf 250 L (Dual sport)
scamp is offline   Reply With Quote
Old 01-02-2015, 07:04 AM   #4
Gainesville , Florida
Everything else dead also or just the outlets? Jim
Old 01-02-2015, 02:33 PM   #5
1971 31' Sovereign
pickering , Ontario
Were you doing anything with electical load at the time it happened; if not, then unplug everything; shut off breakers; shut off all lights/switches; reconnect supply after checking all plugs and coated wiring; then open all breakers at panel and see what happens as you try each light or outlet;
If still not working; did you have anything plugged in at time of event; if you did check that wall plug wiring;if not, check main wiring harness from panel to power source; helps to have circuit tester also;
paulwhite is offline   Reply With Quote
Help! Battery not charging, outlets not working when plugged in AirGal04 Electrical - Systems, Generators, Batteries & Solar 9 06-06-2014 10:15 PM
Lights work but Outlets do not Jeremy9107 Electrical - Systems, Generators, Batteries & Solar 4 07-14-2012 02:37 PM
Electrical outlets not working 16' Sport TonyAlaska Electrical - Systems, Generators, Batteries & Solar 4 06-09-2012 02:16 PM
hooray! the outlets work! bookman Electrical - Systems, Generators, Batteries & Solar 2 08-07-2008 09:29 PM
Missing Electrical Outlets gklott 2001 - 2005 Classic 2 04-21-2004 02:03 PM
