Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 09-06-2014, 05:57 PM   #1
2005 16' International CCD
Refrigerator, range hood fan and light and burners all out
After traveling a dusty, bumpy gravel road we pulled into an rv park for the night and the fridge, stove burners, and light and fan above are all out. Can anyone help with suggestions?
BambiBirder is offline   Reply With Quote
Old 09-06-2014, 07:07 PM   #2
Ottawa , ON
Check the fuses? Cracked, burnt out?
Old 09-06-2014, 07:42 PM   #3
Checked the fuses but did not see any burned out or cracked. I'm wondering if all the dust could have caused a problem. I'll double check the fuses again since that would be the most likely cause. Thanks for the reply.
Old 09-07-2014, 09:52 AM   #4
I double checked and lo and behold the 20 amp is popped so I tried to replace it twice and it pops each time. Anybody know why?
Old 09-08-2014, 01:00 PM   #5
Ottawa , ON
There's a short in that line somewhere.
Open each item (lamp, fan etc) and look to see if there are any stray wires.
'No stove burners' could be a relay that provides auto shutoff in the event of no power.
Leave out the dead fuse while you take a simple continuity checker (a cheap VTVM will do nicely too) and test the socket of all that can be checked on that line.
Do you have a diagram of the DC circuits? Might help if you did...
Baraldi Range hoods, The Stainless steel Range hood found in 2009 Airstreams AeryCorp Commercial Listings 18 05-10-2016 01:41 PM
Range Hood Fan and Light Stopped Working No. 13 General Repair Forum 21 06-05-2013 06:27 PM
Range hood exhaust fan KyMoonshine Roof Vents, Skylights & Fans 3 02-20-2011 06:28 AM
Range Hood Fan cooney Stoves, Ovens & Microwaves 5 07-29-2010 06:29 AM
Loud range hood fan lbrodsky 2000 - 2004 Safari 5 09-26-2003 06:08 AM
