Old 08-06-2018, 07:29 PM   #1
2018 20' Flying Cloud
Puyallup , Washington
Refrigerator Fan - Testing
Hello fellow streamers. We recently purchased a new Airstream last month and I am pretty sure the refrigerator fan in our FC20 does not work. My last few trips I have never heard or seen the fan kick on (the switch is turned on and illuminated). Right now I have both the fridge and switch on and I know for sure it's over 100 degrees in that compartment and yet the fan still has not kicked on.
We have a trip coming up in a couple of weeks and the dealer here in Washington is unable to get me in for warranty work until after our trip to Idaho. I am pretty sure the temps will be well above 100.
My question, is there anything I can do to test the fan myself without voiding any warranty? I did test the switch with a meter and it is indeed working correctly and has power.
Much appreciated!
JakeS is offline   Reply With Quote
Old 08-06-2018, 07:35 PM   #2
Wrangler's Avatar
2019 19' Flying Cloud
Renville , Minnesota
The Fridge fan in my New Flying Cloud is behaving the same as yours. So I am eager to see what folks say.
I currently camp in a 19 Flying Cloud towed by a Nissan Frontier.
Wrangler is offline   Reply With Quote
Old 08-06-2018, 07:41 PM   #3
2017 23' International
hendersonville , North Carolina
Fan fix
Much appreciated!
Just jump the two terminals on the little dime size thermos switch on back of fridge. Small jumper wire or even a paper clip will work. If fan is good it will come on. I had a bad thermo switch on my fridge in my 2017 23D. I called Dometic and told them I could save them a warranty call if they would send me the switch. 2 minutes to install. Fixed. I also added another fan at top vent to help exhaust hot air out of fridge chamber. Huge difference in fridge performance. Also, prop open both doors for better airflow thru that cavity. Exhausting the hot air out of that cavity is essential. Refrig performs better on propane than electric. safe travels.
uraljohn is offline   Reply With Quote
Old 08-07-2018, 08:35 AM   #4
Airstream Ambassador
AirstreamInc's Avatar
Jackson Center , Ohio
Hi JakeS and Wrangler,
Please send us a direct message with your contact information and the last 6 digits of your VIN so we can share it with our Customer Service and Technical Support team. We look forward to helping you get this resolved.
You can also reach Airstream Customer Service and Technical Support at customer_support@airstream.com
Thank you.
Official account for Airstream, Inc.
Airstream Customer Service and Technical Support can be reached at 1 (877) 596-6111, option 1.
AirstreamInc is offline   Reply With Quote
Old 08-07-2018, 10:07 AM   #5
Wrangler's Avatar
I have not had the opportunity to bring this to the attention of the dealer so they could deal with it under the warranty.
Old 08-07-2018, 11:31 AM   #6
Jkohnle's Avatar
2018 19' Flying Cloud
2019 25' International
McKinney , TX
I too have a 2018 19CB Flying Cloud & tow with a Frontier SL (2X). I always turn on the fan, and it did not come on until the ambient temp was above 102 on a recent trip. The fridge has always cooled well.
On another note... how do you like towing with your Frontier? sometimes I wish I had more power. Have you done any mountain trips in yours? Thanks!
Jkohnle is offline   Reply With Quote
Old 08-07-2018, 12:01 PM   #7
Wrangler's Avatar
I just bought my trailer last month, so I am trying to identify potential warranty issues to minimize trips to the dealer. My fridge cools well, I just have not seen or heard the fan run. I have not yet towed in the mountains, but I suspect that I will wish for more power when I do.
Old 08-07-2018, 01:24 PM   #8
2016 19ft flying cloud
Spokane , Washington
The fan only comes on after the insides riches a certain temp on mine ,above 40 usually
Get yourself a inside wireless thermometer for freezer and bottom unit
They work great and you can monitor the temps without opening the doors
On Amazon for $25 with two sending units
AcuRite 00986a2
Spinonedad is offline   Reply With Quote
Old 08-07-2018, 02:32 PM   #9
Houston , Texas
Guess what. Some newer Dometic fridges don’t have fans. Check out “love your rv” on YouTube and search for his “new fridge video”. He says when his old fridge conked out and he replaced it with the same model, no fan. Call whomever the fridge maker is and ask. Or, heaven forbid, check the manual. All of this is said in fun. ��
Asherstanton is offline   Reply With Quote
Old 08-07-2018, 03:48 PM   #10
2018 23' International
Gulf Breeze , Florida
Fridge Fan
I own a 2018 23Fb with almost identical issues. Since getting back to the mother ship is a long haul I worked with Customer service since I work on and understand refrigeration for home and vehicle but not evaporative systems. Understanding how critical the cooling stage function is on the rear fins I checked the temp of the thermal switch and as stated in these threads mine was well over 100 degrees. I checked for continuity of the thermal switch and this was operating as advertised. Tracing the wires I found where the middle connector to the on/off switch that is actuated from inside the camper had fallen off most likely as a result of traveling vibration. The middle leg on the switch powers whatever is supposed to energize when depressed. The LED will still illuminate but that is due to 12v's coming in the switch and running to a ground on the opposite side of the switch making a completed circuit still allows a completed circuit for the light. Until the middle leg is reconnected the fan has no power being delivered. If you are not electrically inclined to safely play around in the back of the refrigeration unit please do not and potentially get bit period. If all wires appear to be connected and you can test for 12v's going into the fan and the thermal switch has continuity, then the fan being inop would be suspect. Again, I understand how to safely test electrical systems but by no means promoting anyone to follow my suggestions if they are unfamiliar with anything for the safety of life and also for warranty issues if the trailer is still under warranty. All the other checking of fuses is fine but if the switch is lit then 12v's is passing through the circuit that also has that fuse designated on the schedule in the fuse panel label or it is suppose to be! I hope this was clear enough to help. Thx
Dawny is offline   Reply With Quote
Old 08-07-2018, 04:37 PM   #11
Uncle_Bert's Avatar
2018 23' Flying Cloud
Pittsburgh , PA
We took delivery of a 2018 FC 23CB in May. I too have not heard the fan come on, so I checked several times when the temperature outside was near 100, but I have never seen the fan running. I jumpered the disk thermostat and the fan came on immediately, so I guess the thermostat is faulty, or just for an even higher temperature. Does any know the temperature at which the fan should should come on?
-Bert
2018 Flying Cloud 23CB
2017 F150 Ecoboost 4x4 SCrew
Outward bound, upon a ship that sails no ocean... (Tom Paxton)
Uncle_Bert is offline   Reply With Quote
Old 08-08-2018, 02:42 PM   #12
Refrig fan performance
Check out "The 23D Thread". It has many suggestions and photos of improvements for better refrig cooling. Some of these guys on this thread are absolutely brilliant. Take a look. Lots of reading, but worth it.
Old 08-08-2018, 02:54 PM   #13
2007 22' International CCD
Data point:
I did notice one time that my 2007 22' International fridge fan came on (battery switch was in 'use') without the fridge turned on at about 98 degrees Fahrenheit outside air temperature. The fan noise alerted me when I walked by the streetside fridge vents. Mine has two side louvered vents made out of plastic.
Since I don't have a switch for this fan, I unplugged it to save battery power.
Next steps are an inside switch with a pilot light or a better fan controller integrated with the fridge, as well as much better mounts for the fans and better doors ($$).
Old 08-08-2018, 06:21 PM   #14
Just wanted to come back and say thanks for all the responses. You all are amazing!
Refrigerator fan switch or fan dugan Lights - Interior & Exterior 4 09-16-2016 03:59 PM
testing/replacing ceiling light/fan '75 Sovereign casbc Roof Vents, Skylights & Fans 0 05-20-2015 05:10 PM
Spell Check is here... At least for testing! Andy R Forum Admin, News and Member Account Info 7 06-27-2002 01:45 AM
testing the elec brakes? Rog0525 Brakes & Brake Controllers 3 06-11-2002 04:02 PM
