Old 12-22-2017, 11:58 AM   #1
2017 25' International
Ladysmith , Wisconsin
Refrigerator Fan
We replaced the old refrigerator cooling fan in our 25RB because it was running continuously and was very loud. Now we have not noticed the new fan running at all and are concerned it is wired incorrectly. Can anyone tell from this picture if it is wired correctly?
llanderson64 is offline   Reply With Quote
Old 12-22-2017, 03:40 PM   #2
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Picture?
Peace and Blessings..
Channing
WBCCI# 30676
Old 12-22-2017, 05:39 PM   #3
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
I don't see a picture either.
But continuous running and loudness are two different problems. A new fan can be quiet, if you chose the right one. If it's running continuously you need to check the wiring and the thermo switch. It should be attached to one of the cooling fins and it turns the fan on when needed.
2012 Dodge Durango Hemi/AWD
Old 12-23-2017, 02:18 PM   #4
ID:	301326 Well, this is the picture. Can't figure out if it will show or not. Hope so.
Old 12-23-2017, 03:12 PM   #5
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
Can't speak to the continuous running. The noise is probably just because the backside compartment of the fridge is, by design, open to outside air flow, including the dust that comes in with it. The dust can get into the little bearings of the fan and make it foul up: First noisy and then just quitting.
Those little 12-volt "desktop computer" fans are cheap and easy to install. I just put a new one in ours when the earlier one failed after about three years.
Lynn
WBCCI 21043
Old 12-23-2017, 04:09 PM   #6
1987 Avion 34W owner
PaulnGina's Avatar
Good Ol' , USA
I cannot tell from the picture if it is connected correctly or not. I can tell you that you will only be using the yellow (+12V) and the black (gnd) wires.
Do you have a meter so you can probe those connections? Where is that yellow wire going that is coming from the crimp-on splice?
“What’s good for me may not be good for the weak minded.”
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
PaulnGina is offline   Reply With Quote
Refrigerator fan switch or fan dugan Lights - Interior & Exterior 4 09-16-2016 02:59 PM
Fan-Tastic fan install Gordon Watt Roof Vents, Skylights & Fans 28 08-15-2011 11:41 AM
Fan-tastic Fan Installation With Photos Dabler Roof Vents, Skylights & Fans 9 09-09-2007 08:18 PM
Fan-Tastic fan??? definition needed hex Our Community 26 10-10-2002 02:17 PM
Fan-tastic Fan installation BobbyW Roof Vents, Skylights & Fans 4 06-17-2002 09:40 PM
