Old 04-13-2017, 05:46 PM   #1
KatCave
Steamboat Springs , Colorado
Refrigerator and Outlet doesn't work
Hi- I have a 6ft Sport airstream. The refrigerator and one of the outlets suddenly doesn't work. I have looked the the panel with breakers and they all look ok. Other outlets work and I have read the manual and can't figure it out. Has anyone else had this problem? Kate :-)
The KatCave
Bambi Sport 2010
Steamboat Springs, Colorado
klogan1010 is offline   Reply With Quote
Old 04-13-2017, 05:59 PM   #2
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
Don't just look at the breakers. Cycle each one off and then on, and re-test. Sometimes a breaker won't "look" like it's tripped.
David
Old 04-13-2017, 06:21 PM   #3
Bigventure's Avatar
2016 30' Classic
Hinckley , Ohio
I believe the fridge outlet is direct wired. It is not fused.
If you could have a superpower, what would it be?
I chose America
Bigventure is offline   Reply With Quote
Old 04-13-2017, 06:25 PM   #4
DKB_SATX's Avatar
1976 Argosy 28
An unprotected electrical circuit is bad juju.
David
Old 04-13-2017, 08:00 PM   #5
2016 19' Flying Cloud
Portland , Oregon
Isn't the fridge 12v?
Snowy is offline   Reply With Quote
Old 04-13-2017, 08:19 PM   #6
Bigventure's Avatar
2016 30' Classic
Hinckley , Ohio
The fridges are propane or 110 volts in a 2010 sport
I chose America
Old 04-13-2017, 08:25 PM   #7
Adventure.AS's Avatar
2017 25' International
Port Dover , ON Canada
Is the fridge on a GFCI protected circuit? Could be I f another outlet isn't working too.
Ray B.
Adventure.AS is offline   Reply With Quote
Old 04-13-2017, 08:34 PM   #8
Bigventure's Avatar
2016 30' Classic
Hinckley , Ohio
OP could look in the owners manual for a wiring schematic.
I chose America
Old 04-13-2017, 09:18 PM   #9
Portland , Oregon
While the dead outlet points to a shore power issue you can see above that according to the manual the fridge requires 12v to operate on propane and 110v. Check the 12v circuits.
From the 2010 manual
https://www.airstream.com/wp-content..._sport2010.pdf
Cheers
Old 04-13-2017, 09:37 PM   #10
DKB_SATX's Avatar
1976 Argosy 28
The fridge requires 12V power for its control board, but a 12V failure or control board failure wouldn't result in any 120V outlets being dead.
Now, if the battery's dead or disconnected, a problem with the 120V side that included the converter's circuit would result in no 12V for the fridge...
David
Old 04-14-2017, 02:27 PM   #11
2004 25' Classic
Newmarket , Ontario
Check the GFI in the bathroom. In my 2004 Safari the circuit for the Refer is wired thru the GFI in the bathroom. Reset the GFI and u should AC
Jake is offline   Reply With Quote
Old 04-14-2017, 05:28 PM   #12
jackson center , Ohio
Refrig circuit is on a ground fault circuit. Either a circuit in beaker box or resettable outlet
Schu is offline   Reply With Quote
Old 04-14-2017, 05:40 PM   #13
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
I, too, bet your GFCI is tripped. When ours gets tripped (19' Bambi) the frig switches from 120 to propane, as they are on the same GF circuit. I can hear the click-click-click of the 12v electric ignition... To reset the GCI you need to go to the fuse box and flip the GFCI breaker off wait a couple of seconds and flip it back on...that should reset it. Test the outlet that wasn't working before. Good luck!
TB & Greg and Abbey Schnauzer
AirForums #21900 . Membership Chair & PastPrez, 4CU/WBCCI
#3954
Old 04-19-2017, 05:01 PM   #14
Portland , Oregon
Update? What was the issue?
Old 05-26-2017, 10:01 PM   #15
KatCave
Answer to Refrigerator doesn't work
And the answer was the GFI switch thingy! I had a repair man come out and he showed me where it was....it seemed to be hidden but now that I know exactly where it's at....I will be able to fix myself. Thanks everyone for all the information and replies!!! I really appreciate it. I am not mechanical so any help is appreciated!!
The KatCave
Bambi Sport 2010
Pump doesn't turn off and it doesn't pump water either. I don't know what to do! Melimelo Fresh Water Systems 10 05-25-2018 02:39 PM
Refrigerator light doesn't work- m.hony General Repair Forum 31 07-16-2015 01:58 PM
Refrigerator Doesn't Work! Mayday! chaseav General Repair Forum 26 04-05-2015 06:15 PM
12 v Outlet in overhead-plug doesn't fit wayneskid Sprinter and B-van Forum 6 05-27-2012 09:01 PM
WBCCI- Doesn't listen or just doesn't care Stream 1529 WBCCI Forum 30 09-29-2008 05:55 AM
