Old 01-01-2015, 09:56 PM   #1
chaseav's Avatar
2015 25' FB International
Red light on power cord head?
Does anyone know what a red light, as opposed to a blue light on the power cord head means? I can't find ANY guidance in my manuals for this but I've got to believe red is bad in some way. I have full power and everything works fine. Brand new 2015 Intl Sig with 30 amp service plugged into a 20 amp service with adapter. Thanks is advance!
chaseav is offline   Reply With Quote
Old 01-01-2015, 10:07 PM   #2
1987 Avion 34W owner
PaulnGina's Avatar
Good Ol' , USA
I believe it is sensing that the polarity is reversed.
“What’s good for me may not be good for the weak minded.”
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
PaulnGina is offline   Reply With Quote
Old 01-01-2015, 10:14 PM   #3
SSquared's Avatar
2013 25' FB Flying Cloud
Longmont , Colorado
Reverse Polarity
The red light is bad news. I think means your electrical hookup may be/is dangerous.
Furrion makes the power cords for Airstream. The following quote comes from the Furrion web site at
F30R30-SS - Power cordsets - RV Camp Power - Electrical
"Furrion's Faultsmart Neutral loss and Reverse Polarity Indicator includes a bright blue LED power indicator and a bright red LED reverse polarity indicator. This reverse polarity LED indicates incorrect flow of electricity due to incorrect wiring."
The cord on our 2013 had a tag that also provided the explanation of the LED indicators.
SSquared is offline   Reply With Quote
Old 01-01-2015, 10:28 PM   #4
ottawa (greely) , Ontario
The red light on the furrion power cord means it is plugged into a reverse polarity power source,like others have said.
Don
2012 silverado ext cab 4x4 ,5.3 L , 6 speed trans,3:42 final drive,tow package standard box 6 1/2 foot . 2014 honda forza 300 scooter, #2 2015 honda crf 250 L (Dual sport)
scamp is offline   Reply With Quote
Old 01-01-2015, 10:38 PM   #5
2007 22' International CCD
I.e. Hot and neutral are reversed at the source. Which is a bad thing...
Old 01-01-2015, 10:47 PM   #6
mefly2's Avatar
2015 25' FB Eddie Bauer
2013 25' FB Eddie Bauer
2012 20' Flying Cloud
Small Town , *** Big Sky Country ***
You may have also received a yellow power checker with you unit when new. It has three LEDs which will give you a double check...we leave ours plugged in for continuous checking...
2015 25' Eddie Bauer International Sp Ed
2019 Chev New Silverado 1500 6.2 V-8; equalizer hitch
AIR# 44105; formerly WBCCI 2015.1
Terminal Aluminitis; 2-people w/ 2-dogs
Old 01-01-2015, 11:12 PM   #7
PaulnGina's Avatar
Good Ol' , USA
If you are plugging in to a "normal" 110vac outlet, one of these Amprobe PY-3 110V AC Receptacle Tester
will help isolate where the problem is originating. These testers are very helpful.
1987 Avion 34W
Old 01-02-2015, 06:49 AM   #8
Gainesville , Florida
Try a dif adapter and or a dif outlet! Be careful. Peace,jim
Old 01-02-2015, 11:31 AM   #9
Oregon Ms's Avatar
2015 25' International
Fidalgo Island , Washington
Hi. I have a 2015 International Sig and there was a company recall on the power inlets (I brought mine in this week). I didn't have a problem, no red light, but being that you do I wouldn't use it until I brought it in. They checked both of my power inlets, they were fine, it's a ten minute fix if there is an issue. The alternative is possible fire (according to the letter I received).
Oregon Ms is offline   Reply With Quote
Old 01-02-2015, 02:37 PM   #10
1971 31' Sovereign
pickering , Ontario
red light
Probably means there is a reverse connection at hook-up; your unit is ok but the polarity is backwards from the source;
paulwhite is offline   Reply With Quote
Old 01-02-2015, 04:54 PM   #11
GammaDog's Avatar
2014 25' FB Eddie Bauer
Vero Beach , Florida
Images: 26
What they said.
I use the tester that paulngina and mefly2 mentioned in every new receptacle I connect to. Plus, if you buy a 30 amp male to 15 amp female adapter like this one
http://www.amazon.com/Camco-55233-El.../dp/B00192QB3I
you can use that tester on 30 amp hookups. I would not recommend using that adapter for anything other that testing the circuit since it lets you plug 15/20 amp wiring into a circuit that is protected by a 30 amp breaker. But it's a simple, inexpensive way to use the standard circuit tester on 30 amp receptacles at campgrounds.
GammaDog is offline   Reply With Quote
Old 01-02-2015, 07:13 PM   #12
chaseav's Avatar
Wow... interesting. Reversed polarity is a new concept to me... I have no idea what could cause that or why. This is the exact same outlet I've hooked up to since day 1 and it's the same outlet that gave me a blue light until just a few days ago. Nothing, and I mean nothing is inoperable or even acting weird on the electrics. I never thought to look at the big white sticker that's wrapped around it though. Duh I guess.
Interesting about the recall too. I bought the thing less than a month ago... I'd love to think they complied with this recall when I bought it. Glass half full.
Would / could water on the contacts have anything to do with the indication? Or have caused a fault somewhere?
Thanks for the help everyone. It takes a forum to raise a first time RV owner!
Old 01-02-2015, 07:17 PM   #13
chaseav's Avatar
OH! I am using an outdoor extension cord to run from the wall outlet to the RV power cord. That's felt like a bad idea for a while but the 30ft cord is about 3 ft short! I will troubleshoot this somehow and report back with findings. Bzzzz, zap, ouch.
Old 01-02-2015, 07:39 PM   #14
ShinyPete
ShinyPete's Avatar
2014 27' Flying Cloud
Bushnell , Florida
Based on your last post I wouldn't worry about it too much. It's not like the polarity of your outlet changed. More likely the poor quality power cord and/or inlet on the coach. The light in our power cord head-end lasted maybe 3 months and we're on the 3rd coach inlet now due to faulty lights and stripped threads. 😒. As soon as we're out of warranty I'll be switching to the stainless steel inlet and probably a better cord.
ShinyPete is offline   Reply With Quote
Old 01-02-2015, 09:12 PM   #15
Ag&Au's Avatar
Port Orchard , Washington
If all the posts that say the red led means reversed polarity are correct them my cord must be defective. The red light has always been lit my cord since new. I have reverse polarity detection both on my external surge protector and also on an outlet in the trailer which both show normal polarity. I always assumed the red light was a "power on" indicator.
Ken
Old 01-03-2015, 07:03 AM   #16
chaseav's Avatar
Ken, well your post is the most comforting... I think. The red light definitely indicates a fault but maybe it's indicating that the fault is within the head and it cannot guarantee that it's sensing a polarity reversal. How big of a problem is reverse polarity though... are campgrounds electrical systems that shoddy? Wouldn't a polarity reversal be indicative only of a really lousy electrician?
Old 01-07-2015, 09:38 PM   #17
chaseav's Avatar
The dealer says its a faulty cord. There is a recall on it and they will inspect and likely replace the cord and anything else that is associated with it. They have been fantastic to work with so far.
Old 01-07-2015, 10:55 PM   #18
Ag&Au's Avatar
What year and model trailer do you have? Perhaps I also have a defective cord. Although in my case it's not hurting any thing.
Ken
Old 01-08-2015, 03:50 AM   #19
Vintage Kin
Fort Worth , Texas
Only men believe their defects aren't hurting anything. This is the reason for wives.
Old 01-10-2015, 10:45 PM   #20
chaseav's Avatar
I have a 2015 Intl Signature 25FB. Took it to the dealer, they tested it using a different cord and determined it was a faulty cord. There is a recall on the Furion system but mine was fixed prior to delivery. This is unrelated. I didn't bother to get a new cord... If a false red condition is so common, what's the point in having an indicator? I might take it up with Furion direct at some point.
Blue Light on Power Cord--is this sucker grounded? CalamityJane Electrical - Systems, Generators, Batteries & Solar 14 09-10-2012 10:45 PM
Red! Red! Red! Can Anyone Tell Me What This is About Now? Fly at Night Batteries, Univolts, Converters & Inverters 23 11-06-2011 02:18 PM
30 amp power cord trouble davidz71 Electrical - Systems, Generators, Batteries & Solar 1 03-12-2003 06:29 PM
External Power Cord Replacement jstaad Electrical - Systems, Generators, Batteries & Solar 3 01-23-2003 07:16 AM
