Old 10-14-2016, 05:05 AM   #1
2017 27' International
Box Elder , South Dakota
Red light on power cord
The red light on my shore power cord is on, normally blue. Even when disconnected from my Airstream, but still plugged into the 30 Amp outlet at the RV park. Everything in my 27 foot 2017 International Serenity works OK.
alphamale49 is offline   Reply With Quote
Old 10-14-2016, 05:21 AM   #2
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
What does the plug in polarity indicator show?
Old 10-14-2016, 08:43 AM   #3
batman's Avatar
1964 22' Safari
modesto , California
I did not see the make of your particular cord set. There are many different cords and manufacturers out there.
If you have a Furrion cord set,
Blue LED is the Powersmart feature. It indicates when power is present to the cord.
Red LED indicates reverse polarity or neutral loss.
It is not uncommon to find the RV park outlet wired incorrectly. It is easy to verify with a volt meter.
-Dennis
batman is offline   Reply With Quote
Old 10-14-2016, 09:29 AM   #4
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
Is this power cord provided by Airstream? A $3 three light tester is pretty good for most problems. A $15 non-contact voltage sensor sensor penlight will do a better job testing for hot ground or neutral line.
Old 10-14-2016, 11:07 AM   #5
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario , Ontario
Both of these items are good, as well as a VOMETRE.
In addition, I use a plug-in Metre to check voltage, and...
I also made another plug-in voltmeter wired it to a plug such that one terminal is wired to ground, the other to neutral.
When plugged in, it should read zero.
I found a campground power plug-in that Read 120 V.
The plug-in three light gadget confirmed it as miswired.
The owner told me that it had Been like this for 12YEARS, and no one had caught it.
MelGoddard is offline   Reply With Quote
Old 10-14-2016, 11:52 AM   #6
interstateflyer's Avatar
2017 25' International
Los Osos , California
The Airstream supplied Marino 30 amp cord on my 2017 Serenity 25 has a red LED that is always red, when plugged into shore power at home or at a park. My TRC Surge Guard indicates "normal" power is being supplied in both cases and the little yellow circuit tester says everything is normal.
The Furrion inlet connector does not illuminate. They are normally blue. The blue lights on my late two Airstreams, even when replaced have burned out within a couple of months so I've given up the Furrion connector blue light.
2017 Airstream International Serenity 25FB
2016 RAM 2500 Crew Cab Cummins 6.7 Diesel
interstateflyer is offline   Reply With Quote
Old 10-15-2016, 07:14 AM   #7
The red light is on the Parkpower 800v 60hz power cord supplied by the dealer, not the Furrion inlet attached to the Airstream. The latter is not on but used to be blue. So it may be that the 'blue' light is just not working, although it should. The GFCI plug shows the two yellow 'correct' status in all the non GFCI protected outlets and all the appliances and lights are working. I hope I have answered all the responses to my initial post.
Old 08-27-2017, 12:03 PM   #8
2018 25' Flying Cloud
Roseville , California
I know this thread is fairly old, but I noticed on my brand new AS that it showed the red LED; all other trailers I had showed blue. In researching the Marinco cord (for 50 amp service) I discovered that Marinco's red LED is simply a power on indicator.
Larry
graywhale is offline   Reply With Quote
Old 08-27-2017, 12:11 PM   #9
Half a Rivet Short
Carlisle , Pennsylvania
Larry
Hi
Worth remembering if you have a shore power problem. Unfortunately it rarely is remembered as you run around trying to work things out ....
uncle_bob is online now   Reply With Quote
Red light on power cord head? chaseav Electrical - Systems, Generators, Batteries & Solar 24 01-24-2015 08:32 PM
Blue Light on Power Cord--is this sucker grounded? CalamityJane Electrical - Systems, Generators, Batteries & Solar 14 09-10-2012 09:45 PM
Red! Red! Red! Can Anyone Tell Me What This is About Now? Fly at Night Batteries, Univolts, Converters & Inverters 23 11-06-2011 01:18 PM
External Power Cord Replacement jstaad Electrical - Systems, Generators, Batteries & Solar 3 01-23-2003 06:16 AM
