Old 07-29-2010, 06:03 PM   #1
1976 Argosy 26
Blandon , Pennsylvania
Red and White Wire
I am restoring a 1976 Argosy 24. Up near the water pump and terminal block for the wiring going to the tow vehicle, there is a Red and White wire coming up through the floor. I cannot make sense of what it is for, nor can I remember if and what it was connect to.
Any help is greatly appreciated...
lpgasguy is offline   Reply With Quote
Old 07-29-2010, 06:12 PM   #2
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
For starters red is positive, white is negative
Old 07-29-2010, 07:14 PM   #3
Kevin245's Avatar
Without photos it's a guess. There are photos and wiring diagrams in the attached thread that may offer some insight. There's a red and white feed from/to the battery in our 76 Sovereign.
http://www.airforums.com/forums/f37/...hlight=univolt
Good luck,
Kevin
Eleanor Roosevelt
Old 08-10-2010, 10:26 AM   #4
1976 Argosy 26
It was the brake wires. I was confused because the wiring diagram said that the brake wire is yellow and there is also a yellow wire there. Any thoughts on what the yellow wire is for?
Old 08-10-2010, 12:07 PM   #5
Lumatic's Avatar
1993 34' Excella
Images: 16
Yellow is usually for the brakes.
Old 08-10-2010, 12:56 PM   #6
Splitrock's Avatar
Sioux Falls , South Dakota
My brake wires are black and white (look like romex). My break away switch wires are red and gray. My break away switch was disconnected and the wires were tied together and stuffed back into the wall. When I re-wired the 7-way, I used the OEM wire colors out of the trailer side for future ease of identification.
This is what it looked like when I started.
Name:	LIGHT PLUG-2 (Medium).jpg
This is what it looked like when I finished.
Name:	7 WAY FUSES (Large) (Medium).jpg
A jumper light, a multimeter, a small battery charger, and a 7-way tester were my tools of choice.
Green wire/White wire magnets robbier49 Brakes & Brake Controllers 3 07-08-2009 06:26 PM
White Gas? doorgunner Stoves, Ovens & Microwaves 31 04-14-2008 02:15 PM
Two wire and three wire converters??? max7 Batteries, Univolts, Converters & Inverters 1 02-28-2008 05:27 PM
Why white box ads? yukionna Off Topic Forum 18 08-16-2005 01:06 PM
white top Voyager Our Community 22 06-14-2005 12:48 AM
