Old 04-08-2019, 12:51 PM   #1
2016 25' Flying Cloud
Vadnais Heights , Minnesota
Reconnecting our batteries
I would like to get an external total disconnect switch installed on our interstate batteries. I’m hesitating because we are now proficient at unhooking and reconnecting them when needed like for storage or longer periods of not using the trailer. I manage them at home when plugged into shorepower by checking for voltage and when at 12.7 or more I disconnect from shore power and let them sit. Then check on the voltage periodically and when it gets to 12.5 or so I plug back into shore power .( Lately that doesn’t take very long)
I’m told the external disconnect would make life easier managing the batteries.
But would we still be able to so easily unhook the batteries and reconnect them like we do now when we want to put them on the battery minder?
Or will it just complicate that process and better to just leave what we are doing alone ?
Fipp is offline   Reply With Quote
Old 04-14-2019, 02:10 PM   #2
Half a Rivet Short
2022 Interstate 24X
Carlisle , Pennsylvania
Hi
There is no difference at all between using a switch (or relay) to disconnect the batteries vs un-wiring them as you are now doing. Both processes do exactly the same thing.
If your batteries are anywhere near good shape, they should hold voltage for a couple months after disconnect. If they don't, they likely have issues. Get them checked and replace as needed.
Since it's cold out, the voltages on the battery actually should be a bit higher than normal and it should take longer for them to discharge. I have no idea when our where you last checked things so this may not apply to your situation.
Old 04-14-2019, 08:14 PM   #3
Thanks Bob! I always look forward to your input!
I was most concerned about ease of actually removing the battery’s once an external disconnect is wired to them.
As it turns out I’ve decided to contact Randy at Best converters ( as you suggested to me last fall) and upgrade to a multi stage converter for better maintenance of the batteries when I’m plugged into shore power. I’ll probably skip the additional battery disconnect and just unwire them when or if I need to remove them from the trailer.
I just need to find someone to install the new converter. Im a total non DIY!
Thanks again for the input!!
Old 04-15-2019, 05:28 AM   #4
Half a Rivet Short
2022 Interstate 24X
Hi
Unless the batteries are in bad shape, there is no real need to pull them out of the vehicle. If they are in bad shape - replace them . If they are flooded batteries, make sure they have a water level top off from time to time. Also with flooded batteries a different converter *might* help things. (it's a win / loose sort of situation). If you have AGM's the fancier charger really does not do a lot.
Old 04-15-2019, 09:13 AM   #5
mefly2's Avatar
2015 25' FB Eddie Bauer
2013 25' FB Eddie Bauer
2012 20' Flying Cloud
Small Town , *** Big Sky Country ***Western Montana
$10-15 per battery for a switch is mental comfort ...
Hello all, Our 'Valentine' is the love of our life, and fast becoming our 24/7 addict errol108 Member Introductions 6 10-14-2019 07:04 PM
Need help with reconnecting electrical Cristina1966 Electrical - Systems, Generators, Batteries & Solar 19 12-27-2014 04:13 PM
Reconnecting black water tank Lfemat Waste Systems, Tanks & Totes 1 05-22-2012 01:36 PM
reconnecting Univolt jubei Batteries, Univolts, Converters & Inverters 6 04-18-2012 05:13 AM
Batteries..All about batteries FrankR Batteries, Univolts, Converters & Inverters 0 07-17-2002 09:05 PM
