03-20-2019, 08:11 PM
2018 27' Tommy Bahama
Bainbridge Island
Ready for Lithium and Solar - advice?
My wife and I like to boondock especially in the national parks. What we have now is the stock batteries and electrical, no solar, and a Honda generator, which is very limiting. When it's cold, the fan on the furnace takes so much battery, we have to recharge daily. This means we have to run the generator in the park, according to the park's schedule, and we hate the noise! We use the microwave at all without shore power, and it would be super deluxe if the wife could use her hair dryer every few days.
So our goals are to be able to do 3 or 4 nights and:
Run the furnace all night
Microwave for about 10 minutes per day
Hair dryer occasionally but can do without in case of long periods w/o sun.
Enough battery to last 3 or 4 days without much sunshine
Enough solar to recharge in one day (assuming direct sun)
I have a Victron BMV-712 on the stock system and monitored our usage on the last trip. Cold nights we used about 34 amp hours just for heating, and about 45 ah for the entire day. Of course that does not include microwave, or any luxuries like TV/satellite that we plan to add, much less the hair dryer.
I've got a big spreadsheet that says we would use 80 to 120 amp hours/day depending on various things and of course whether or not it’s a hair dryer day.
Peak inverter demand would be determined primarily by the hair dryer at 1400 AC watts plus a few more things at the same time but not the microwave.
I plan to do the work myself, as I have some experience wiring electrical systems, but am by no means an expert. My current plan is to use a Victron Multiplus and Battlebore batteries.
Things I’m looking for advice on:
Basic layout -
Our trailer is a 2018 27' Tommy Bahama 50amp, but just consider it to be a 27' front queen Flying Cloud or International, as the electrical and floor-plans are almost identical.
The electrical panel is in the middle of the trailer, curb-side, under the galley. The inverter is under the bed at the front of the trailer. The current inverter is 1000 watt and must be replaced, plus it doesn’t power the microwave or basically anything but the TV’s.
It looks like the best place to put the batteries is under the bed. Is there another location that would work better on this floor-plan?
It seems like the Multiplus should go close to the batteries, under the bed. Otherwise there will have to be big cables on a long run from the batteries to where else it is installed. Correct?
With the Multiplus up front, does it make sense to run the inverter AC power back to the electrical panel in the middle of the trailer? That way I can put circuits onto the inverter without rewiring outside the panel (with a sub-panel or replace the current panel).
Finally, the fridge AC circuit is on the same breaker as most of the duplex outlets including bathroom, galley, outside, and others. How do I get the outlets to run off the inverter without the fridge using the AC? Maybe I just unhook it and always run it on propane?
Wow, this is getting to be a big post. Eventually I will have a system design worked up, but I'll leave that for later.
David
03-20-2019, 08:30 PM
2020 Classic 33
Box Elder
, South Dakota
David for education have you looked at the information available at the www.amsolar.com website? Lots of diagrams and information to help you.
In your example of 120ah/day and going 4 days with no sun you would need 600ah of lithium batteries. Replacing 480ah of draw starting on the 5th day while still continuing to draw 120ah would take multiple days of sun. If you could get 800 watts of panels on the roof they would give you approximately 50ah/hour during the peak hours of the day. Looking at spring and fall something less. So it might take 2-4 hours of sun just to cover your 120ah of daily usage. Then the remained of 3-5 hours would generate less ah's. If those hours averaged 25ah then you would replace 100ah to start taking the batteries back to full.
All of that being said if you have a Honda 2000 watt generator that runs continuously at 1650 watts that would make up the shortfall pretty quickly.
So as you do your design there are lots of things to be considered which sounds like you are already considering.
Finally there are hundreds of posts on solar installs here on the forums. Lots of information and wisdom can be gathered. Helps avoid pitfalls felt by those who have been there and done that. The wisdom of measure once, measure again, check a third time and then make the cut comes to mind.
Gary
2020 Classic 33 Twin, 2019 Ram 3500 Longhorn, ProPride
NØVPN
03-20-2019, 10:02 PM
2017 30' International
Broomfield
I had similar needs / desires. I easily go through 100ah/day... if not 200. We like always on residential power and all of its benefits [emoji4] I also like to run the AIrCon of batteries or with a small honda generator that supplements the batteries.
I sized my system with 600ah and a mumtiplus 3000. Also installed 800w of solar which can put back 400ah on the best day of the summer. I have a 30’ international with a rear bed.
My batteries and multiplus are under the rear bed, power center is mid ship under the fridge.
A system install of this size is a very large job. I considered self-install (have the skills) but it was just too many man hours. I had Lew Fabre do the work and he put 80+ man hours in it... and he is a pro with a fully equipped shop [emoji4]
Here is a link to my install if you want more details....
http://www.airforums.com/forums/f539...um-182406.html
Good news is that I’ll get 30% of the cost back on my 2018 taxes based on renewable energy credit.
03-20-2019, 10:13 PM
2007 27' International CCD FB
San Diego
Probably not the advice you're looking for but..
You're asking for a Bentley. And going to pay for a Bentley. The install and complexity will be commensurate with a Bentley. Perhaps something to think about is maintenance on a Bentley cannot be handled by your average shop when you inevitably will need service.
Do you need a Bentley?
You've been living with a Kia.
Perhaps all you need is a nice Lexus?
To that end. I'd recommend 400W on the roof. Go ahead and splurge on that multiplus. And upgrade to some nice true deep cycle 6V golf cart batts that will handle 80% discharge (real usable Ah) without much impact to lifespan. This sidesteps the complexity and slippery slope of upgrades necessary for lithium.
This is a wild card but...
I'd pair this with a nice GoalZero 1000 that has built-in 1500W inverter for your other 120V needs. Portable and could serve so many other uses. Setup a timer such that it only charges through the 12V circuit during the day when the solar is producing.
Probably good to rethink how you watch TV. There's many digital low power devices and solutions. Much better investment there, than feed the traditional energy hogs that you have now. In other words, it's always better to conserve and still get the luxuries you want, rather than building a giant power plant to feed the power hogs.
03-20-2019, 10:19 PM
Broomfield
Agree with pteck btw.... a Bentley system (that is what you are looking at) will put a dent in your wallet like no other so you need to carefully consider how much you are willing to spend vs compromise.
Heck - you may also just start with a little generator and evaluate from there. I went 8 years before I put a big system in.
03-21-2019, 05:41 AM
2018 27' Globetrotter
Apollo Beach
The last few posts on the "Solar Show and Tell" thread, starting from the link below, demonstrate the installation of exactly the design the OP is considering with a Multiplus and 600AH of Lithium. The new drop-in Lithium's with built-in BMS makes self-install a possibility for average skilled individuals. The biggest obstacle I see is crimping 4/0 wire. Take a look at the three videos starting from this link:
http://www.airforums.com/forums/f448...ml#post2222227
2021 Northern-Lite 10-2 & F350 DRW PSD, 600W Solar/Victron/600A BattleBorn
146 nights 31,000 miles (first 10 months!)
Sold: 2018 GT27Q, 74 nights 12,777 miles
Sold: 2017 FC25FB, 316 nights 40,150 miles
Sold: 2013 Casita SD17 89 nights 16,200 miles
03-21-2019, 05:54 AM
2013 25' International
Boise
, Idaho
Sizing right does matter!
I originally installed 300Ah of lithium and 500w of solar on my 25'. My wife and I tent camped for many years and thus learned how to conserve power. We boondock 95% and do so near lakes and rivers where we recreate - me usually with a fly rod, and her on her feet walking.
When camping under clearish skies last year, I would use 50-80Ah a day and would be at 100% by 10:00am from sun. Cloudy days, by 1:00.
This year I am doing the Multiplus (should show up today) and I bought 1 more Battle Born on the sale last year. With 400Ah and 500w of solar, I consider my system more than enough. Remember that during the hours when the sun is highest, you'll often be 100% full on batteries and have a few hundred watts available "for free" since that energy can't be stored. Make use of this time to recharge laptops, use the hairdryer, etc. I wouldn't have done the 4th battery and the multiplus had I not wanted to run the AC briefly from batteries. I did the work with a good friend who has more skills than I do, and I learned a ton. I probably spent 4x the actual hours and I'm sure my install won't win awards compared to a pro, but it was very much worth it.
I would say the single most important upgrade was the lift (in our case a custom 4" lift) since it made getting in/out of the places we want to be easy. In fact the AS now has a little more clearance than my truck!
-Adam
03-21-2019, 06:12 AM
Bainbridge Island
Great feedback! I hadn't thought it would take that much solar & battery. The daily ah numbers are max, as the furnace takes the biggest bite of the power. When never run the AC unless it's really hot and we have shore power.
Interesting idea about the goal zero. That would solve the hair dryer load.
The TV ah do add up after a few hours. Would those run off 120v or 12v? 12v would require additional wiring.
I have seen some costs pushing $10K which is a lot.
Time to look at our requirements and evaluate things.
03-21-2019, 07:02 AM
Bainbridge Island
I'll have to check them out. Looks like it's a coach, I have a trailer, but should be easier in the trailer, right?
03-21-2019, 07:11 AM
Bainbridge Island
-Adam
I've seen similar results from others on this forum. I think most days we'll be in the 70-100 Ah range. A little higher but still do-able I think.
Thinking about the lift as well, to park in our driveway and get to more remote locations.
03-21-2019, 07:13 AM
Broomfield
Big systems can push triple that amount when you include professional installation.
Drop-in lithiums bring the cost down some for sure as you need a few less ancillaries and are a little less $/watt hour.
There are +/- to ever approach and component selection. Big investment either way, spend your time and do your homework. I'd also recommend giving AM Solar a call - they are the authority in this space, provide great support for DIY, can help with system design, have a ton of experience on airstream installs, and can walk you through everything you need. There are a lot of little "bits".
PS - IMO the biggest challenge will be installing a new 120 V split panel / sub panel - you will need to re-wire your 120v system with 50A L1/L2 service and the passthrough Multiplus 12/3000. Be careful, things can go very sideways if 120v is not done right.
03-21-2019, 09:48 AM
Apollo Beach
OK, now that we are considering "NEEDS" vs "Wants", let's put together an economy plan for you. I have the economy plan and it works great 95% of the time, as demonstrated in the "Solar Show and Tell" thread. That extra 5% costs dearly and this is what it avoids: 1) If I need to use the microwave or a hairdryer on higher than low setting, I fire up the generator for a few minutes. 2) If I need A/C, I fire up the generator. 3) If I stay under a complete canopy of trees, I may need to fire up the generator for a few hours occasionally. I use my generator very infrequently.
You can do this install in stages. You already have the generator and a BMV-712. I would just add solar this year and see how it goes. With a 27' Airstream, you can easily put 600W on the roof. I would put 600W in three series-parallel pairs using the factory prewire and rooftop box, a Victron 100/50 Controller, an on/off switch on the solar input to the controller and a 60A breaker on the output of the controller with 6 gauge to the bus bars, 50' of 10-2 for the roof. I'd buy it all from AM Solar and wire it up myself. You will get 45A of charging in full sun. You could drop in either 1) a pair of Lithium 100AH batteries into the factory battery box for $2k, 2) a pair of AGM Lifelines into the factory battery box for $800, or a pair of wet-cell 6V golf cart batteries into the factor battery box for $250. I chose the golf cart battery option. For about $3,000 you could have a system that will avoid generator usage 95% of the time with golf cart batteries, $3,500 with AGMs, or $4700 with drop-in Lithiums. This stage of the install is very easy for someone with some electrical skills. If you can keep positive and negative connected correctly, can wire a series connection, can make a good crimp connection, this stage of the install can be done by a novice.
If you choose the $3,000 system with golf cart batteries this summer, you could choose to have the multiplus and Lithiums professionally installed next year so you can run the microwave, hair dryer, or A/C for short periods of time. (The other 5%) I have no idea what professional installation of a multiplus and Lithiums (with relocation) would cost. I would call AM Solar and get a quote. Then you can decide if you want to spring for the extra 5% this year or next.
AM Solar is OK with you self-installing what you are comfortable doing then completing the job professionally in their shop. They offered to do that for me if I got in over my head installing my system. They were going to reconfigure my installation to full parallel if needed. In the end, I was able to completely install my simple system without their help and did not need to reconfigure the series-parallel to full-parallel because my batteries charged perfectly in series-parallel (and yours will too with 600W).
Here are some pictures of what needs to be installed for the 95% solution:
http://www.airforums.com/forums/atta...1&d=1526477509
http://www.airforums.com/forums/f448...-181608-2.html
http://www.airforums.com/forums/f42/...es-166881.html
03-21-2019, 10:23 AM
Apollo Beach
03-21-2019, 10:31 AM
2022 25' Flying Cloud
NCR
, Ontario
this is our DC deployment with BB Lion and mostly victron parts
i took out the LIO BB for winter and put in the old Lead acid.
after 5 month, i saw no mice inside.
the remote victron access worked all winter
03-21-2019, 10:34 AM
NCR
, Ontario
here is the inside temp for the last month during winter storage
03-21-2019, 06:34 PM
1964 26' Overlander
Milton
, ON
Will the standard golf cart batteries that you get at Walmart or Sam's Club handle a frequent 80% discharge? Or are there special ones for that? The AM Solar page makes it sound like all flooded deep cycle batteries should only be discharged to 50% if you want them to last.
03-21-2019, 07:18 PM
Apollo Beach
The Deka/East Penn Life Cycle Vs Depth of Discharge chart (Sam's Club EGC2 Duracell Batteries) shows 1000 cycles to 50% discharge and 800 cycles to 80% discharge in a controlled lab environment. To me, that means that I can go to 80% discharge and actually get more AmpHours out of the battery over its lifetime, but with less cycles. See chart here: https://marinehowto.com/wp-content/u...le-Battery.jpg
The Duracell EGC2 battery (Sam's club) is rated at 230AH. A 50% discharge is 115AH. 115AH times 1000 cycles equals 115,000 AH over its life. At an 80% discharge you get 184AH. 184AH times 800 cycles equals 147,200 AH over its life. Less cycles but more total amphours from the battery over its life at 80% discharges.
This article explains why the Sam's Club Duracell EGC2 battery is a great choice if you can live within its 115AH to 184AH range of use. The battery fits in newer Airstream tongue battery boxes without modification and older Airstreams by extending the battery box top with 1" square aluminum tubing. https://marinehowto.com/what-is-a-deep-cycle-battery/
I've been very happy with my pair of "Sam's Club" "Duracell EGC2" "Deka/East Penn GC15" batteries. All different names for the exact same "relabeled" battery. I've worked them hard for just over a year and 100+ days of boondocking and they still test as new. See the "Solar Show and Tell" thread to see snapshots of 30 days of usage documented. Example of one 30 day document: http://www.airforums.com/forums/f448...ml#post2133206
Also, by cycling a battery deeper, the charger uses "bulk" mode longer each day which is a more efficient form of charging. I don't see any downside to "abusing" these batteries with occasional 80% discharges. I had a set of 6V Trojan T-105 wet cell golf cart batteries in a golf cart that I ran until the golf cart died before recharging for years. Those batteries held up well to 100% discharges. Golf cart batteries are tough. I'm willing to abuse them and replace them when needed at $250 per pair.
03-21-2019, 07:38 PM
San Diego
Thanks AirMiles. I was about to post, but you surely more than covered it.
Golf cart batts, even the commodity ones, are just built to a different standard. There's studies that run of mill ones can easily outlast a typical starting/hybrid/deep cycle 12V batt by at least 2.5 times. The opportunity here is to be able to deep cycle them further, and still have meaningfully more life.
People get caught up in lithium, AGM, whatever. In the end, devices don't care, and all that really matters is capacity.
A single lithium battery at ~105 Ah (and 5X cost!) has nothing on even dual standard group 24 batts. They still don't recommend full depth of discharge which means usable power is 80 Ah. That is a recipe for the furnace to run out of power at night on a cold day, and you'll be hating the "upgraded" batts.
It takes 2x lithium batts (10X cost!!) to compete with the capacity of dual 6V batteries. Then you have environmental constraints and other integration concerns. Hope one never accidentally abuses these costly investments and having them die prematurely.
With a 6V flooded batts, which should easily go 5-8 years even with abuse, it would be cake to go down to any shop for replacements.
03-21-2019, 10:27 PM
:SPACE A" S/O 11 Air19745
2006 34' Classic S/O
Fort Worth
I have had three years with AM Solar equipment and Lew Ferber's installation. Top notch and no comebacks with plenty of free advice. I would not consider a new system without their consult. Prices are extremely fair. Lew's installations can't be beat.
AM Solar, Inc
3555 Marcola Rd.
Springfield, OR 97477
541-726-1091
Lew Ferber
Solar Tech Energy Systems Inc.
•3887 Mannix Dr. Suite 606
Naples, FL 34114
•2149 W. Cascade Ave. Suite 106A-214
Hood River, OR 97031
541-490-6357
guskmg
03-22-2019, 12:22 AM
2007 22' International CCD
Corona
Think it’s spelled Farber, but what do I know...
