Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 04-15-2013, 08:47 PM   #1
DFlores's Avatar
1968 22' Safari
Buda , Texas
Re-wiring the '68 Safari
So, I'm knee deep in wires, I'm putting in a resetting circuit breaker in the wire between the tow vehicle battery and the trailer battery. The guy at my local RV parts place sold me a 30 amp breaker, ........the wiring diagram calls for a 25 amp breaker......the wire from the trailer is 8 awg and the wire from the vehicle is part of the new Bargman trailer end cable, so will it blow up if I do not go order a 25 amp breaker online?
Also, the breaker is labeled on one side "Bat", ( no I did not pay attention to this detail when I took off original) does the "Bat" go to the vehicle battery or to the trailer battery?
DFlores
David & Diana
DFlores is offline   Reply With Quote
Old 04-16-2013, 10:19 AM   #2
DFlores's Avatar
1968 22' Safari
Buda , Texas
47 looks, someone must know the answer
DFlores
David & Diana
Old 04-16-2013, 10:40 AM   #3
kokopat's Avatar
Hendersonville, NC , North Carolina
I wired my 12 volt systems on our '68 Overlander just like the drawings on a 2001 Bambi that I found on the Airstream web site. It shows a 30 amp breaker from the tow vehicle. I can send it to you if you like.
Pat
kokopat is offline   Reply With Quote
Old 04-16-2013, 11:02 AM   #4
DFlores's Avatar
1968 22' Safari
Buda , Texas
Pat
Yes please!!!
DFlores
David & Diana
Old 04-16-2013, 11:52 AM   #5
kokopat's Avatar
Here's link: http://www.airstream.com/files/libra...fe9a57a9a8.pdf
12 volt wiring is on G-11 and G-12 depending on how many axles you have. If you trace the 30amp from the tow vehicle you will find a 50amp breaker between the 30amp breaker on the way to the battery.
good luck, it works for me.
Pat
Old 04-16-2013, 12:51 PM   #6
DFlores's Avatar
1968 22' Safari
Buda , Texas
Thank you Pat, the resetting breaker I encountered is on the "Charge Line 10 Ga Black" on the diagrams on pages G11 & G12, it is located between the 7 way plug and the "30 amp type 2 breaker" shown on the diagram
DFlores
David & Diana
Old 04-16-2013, 01:37 PM   #7
kokopat's Avatar
You're welcome, sounds like you understand what you're looking at.
Pat
1969 Safari - Wiring Diagram VeggieBullet Electrical - Systems, Generators, Batteries & Solar 11 10-13-2011 09:12 AM
Wiring diagram for 1963 safari Theburrs Electrical - Systems, Generators, Batteries & Solar 5 09-24-2011 04:08 PM
Does anyone have a wiring diagram for a '68 safari?...Please HolyRoller Batteries, Univolts, Converters & Inverters 1 05-11-2011 09:45 AM
