Old 05-15-2003, 10:32 PM   #1
drex's Avatar
re-wiring
i am re-wiring a 64 bambi and a 46 spartan manor - does anyone know where i can find a basic trailer wiring diagram and/or how-to-do-it info? thanks, drex
drex is offline   Reply With Quote
Old 05-15-2003, 11:45 PM   #2
Trailer rewire
The mechanical part of rewiring is easy. The most difficult part is the plan. Any trailer can be wired in many ways. A plan is a high priority. Trailer use is important. Where trailer is to be used is important. What support electrical equipment will be needed. Airstream trailers are mostly wired for the most use for the dollar.
The Airstream trailer has a few electric systems. There are the exterior lites and lites that are part of moving the trailer. There is a parked and plugged into house power as 120 volts ac. There is a 12volt dc system to supply electric away from any 120volt ac .
Visit Idaho The people are great
FrankR is offline   Reply With Quote
Old 05-17-2003, 08:39 AM   #3
drex's Avatar
thanks
Old 05-17-2003, 09:17 AM   #4
5 rivets, 1 loose screw
Rog0525's Avatar
1966 20' Globetrotter
Saginaw County , Michigan
Images: 11
wiring diagram
There is a wiring diagram of a '64 Globetrotter on this LINK which might serve as a reference.
Rog
Rog0525 is offline   Reply With Quote
Old 05-17-2003, 09:51 PM   #5
Airstream factory wiring drawing 12 volt
Zoom in as needed.
Name:	exterior 12 volt dc 2 .jpg
Old 05-17-2003, 09:56 PM   #6
As built 120vac drawing
This is a guide...
Name:	airstream  120vac dist. jpg.jpg
Old 05-17-2003, 10:00 PM   #7
Interior rear bath
A guide to a plan...
Name:	interior rear bath.jpg
Old 05-17-2003, 10:49 PM   #8
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
That's what I love about this forum....ask and you'll get it (within reason).
Frank, those posts are amazing!
Eric
Old 05-18-2003, 09:03 AM   #9
drex's Avatar
Frank- thanks for the great info, it will get me where I need to go. I appreciate all the effort it took to help me out.
one more question - the wiring on the brakes of my 46 Spartan is the old cloth covered type. I have cleaned the brakes and repacked the wheel bearings and the wiring is in good enough shape to be able to test the brakes. This old cloth wiring is not color coded, but instead one of the two wires is smooth and the other has ridges, does any one know which one is power and which one is ground? -thanks
Old 05-18-2003, 09:26 AM   #10
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
Doesn't matter
It doesn't matter which way you hook up the brake magnets. If you replace the wiring, just pick a polarity and go with it.
John W. Irwin
WBCCI #9632
trailer side brake wiring diagram? munimula Brakes & Brake Controllers 9 03-26-2017 09:53 AM
Wiring Diagram 84 Excella 31ft dscluchfc Electrical - Systems, Generators, Batteries & Solar 2 01-03-2005 11:09 AM
trailer wiring Cruiser Electrical - Systems, Generators, Batteries & Solar 4 09-02-2003 01:43 PM
Wiring tail & running lights JimC Electrical - Systems, Generators, Batteries & Solar 4 04-14-2003 12:38 PM
TV Antenna wiring??? tenrsingr Audio, Video & TV 6 05-06-2002 02:16 PM
