Old 11-01-2014, 01:15 PM   #1
Boulder , Colorado
Range Ignitor
On my 2013 23FB, the range ignitor failed, got a warranty replacement, installed it, checked all wire connections...and it doesn't work. Made sure the gas was flowing by lighting the burners with a lighter. Anyone experienced failed ignitors?
BobGall is offline   Reply With Quote
Old 11-01-2014, 01:22 PM   #2
TinTin's Avatar
2009 23' FB Flying Cloud
Canmore , Alberta
Not failed, but seldom do we get ignition on the first go, particularly when stove has not been used for several hours. Sometimes it will take 3-4+ tries. We've considered getting a standalone sparker.
Bob and Nancy
http://www.rwcphoto.smugmug.com
Cheer Up, Slow Down, Chill Out!
TinTin is offline   Reply With Quote
Old 11-01-2014, 01:38 PM   #3
2011 23' Flying Cloud
Durango , Colorado
Yes, same issue in our 2011 FC23FB - the igniter just never worked well. I simply keep a butane bbq lighter by the stove.
Safe Travels,
JamuJoe
Safe Travels,
Joe & Joan Donnaway
Durango, CO
JamuJoe is offline   Reply With Quote
Old 11-01-2014, 01:45 PM   #4
1974 Argosy 20
Kooskia , Idaho
And my 2014 FC 20' has a range which the sparker works very well, on every burner, every time, so they can work just fine. Someone should be able to figure out the issue I would think.
Old 11-01-2014, 02:04 PM   #5
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
Ours works but sometimes it takes several bumps to light. Sometimes I use a lighter stick. I haven't taken a close look but was wondering if there is some adjustment that might make them work better. Maybe Bob can give us some insight since he replaced his. So Bob, when you put your new one in did you find any sort of adjustable parts ???
Thanks all, see ya'll on the road sometime.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 11-01-2014, 02:14 PM   #6
Boulder , Colorado
Range Ignitor
When I replaced it, which was today, 11/1/14, I look for a way to adjust it when it wasn't working. Nothing there. It's a very simple looking little thing.
Old 11-01-2014, 03:27 PM   #7
retired USA/USAF
2001 30' Excella
Thanx Bob for settling that issue. I shall look no farther.
Roger in NJ
TAC - NJ 18
Replacing the ignitor on a Dometic RM100 wacnstac Refrigerators 2 03-29-2009 08:55 PM
water heater ignitor ground john hd Water Heaters, Filters & Pumps 14 08-26-2006 08:58 PM
Main Propane Ignitor "Element" Cat Furnaces, Heaters, Fireplaces & Air Conditioning 11 05-23-2005 04:28 AM
ignitor points trumpwer LP Gas, Piping, Tanks & Regulators 2 05-02-2005 01:44 PM
65 Dometic Refrigerator, ignitor ChromeHome Refrigerators 10 04-24-2005 04:15 AM
