11-12-2013, 08:05 PM
1973 Argosy 26
Chandler
Quick question for electrical wizards
I bought my first Argosy (1973) last year, and spent the better part of last summer and fall renovating it, painting it and repairing all except the axles. Now I am planning to upgrade to solar for battery maintenance and boon-docking capability, as well as replacing the original Univolt with either a WFCO, intellicharger or other convertor in the 55 amp range.
The question I have is can I hook up the positive wire from the convertor to a positive lug that I use in the solar configuration, or does it have to go directly to the positive battery cable for some reason? I also installed a shunt so I can get accurate readings from the separate meter, in the negative (common) side just before the battery. Can I also use the other terminal of that shunt or a bussbar to terminate negative conductors from the convertor or does that have to terminate directly to the battery?
I'm trying not to have more than one cable going to each battery terminal.
I would appreciate your feedback and hope to be able to stay more current as a member and share pics etc of the solar installation as I get closer to completion.
“The whole aim of practical politics is to keep the populace alarmed (and hence clamorous to be led to safety) by an endless series of hobgoblins, most of them imaginary.”
― H.L. Mencken
11-12-2013, 08:14 PM
1978 31' Excella 500
Venice
Mine connects through the fusebox.
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
11-12-2013, 08:18 PM
Marine city
, Michigan
Nothing should be between the shunt and the battery. It only works if all the current goes through it.
There is no difference electrically if something is connected to the battery or to a wire that is connected to the battery.
You should have a fuse or circuit breaker in the positive line at the positive battery terminal or very close (inches) to it.
11-12-2013, 08:37 PM
1973 Argosy 26
Chandler
The converter cables would then be hooked up (common) to the non-battery side of the shunt (so as not to interfere with the meter readings) and the positive would be hooked up to the lug I have installed on my board to hook the positive cables from the battery output on the charge controller to.
Would that also be the case if I decided to hard wire in an inverter? I have a small one I picked up but it's only good for about 140 watts, and I may need something a bit more robust.
Thanks for the info folks.
― H.L. Mencken
11-13-2013, 09:14 AM
Marine city
, Michigan
Originally Posted by SkooterPop
Would that also be the case if I decided to hard wire in an inverter? I have a small one I picked up but it's only good for about 140 watts, and I may need something a bit more robust..
Yes, neg input to non-battery side of shunt, positive to positive lug of battery.
140 watts isn't much, maybe enough for charging a laptop, cell phone, etc. Even 140 w though is 12 amps at 12 volts, quite a bit of current. Be sure to use heavy enough wire for the current.
11-13-2013, 09:20 AM
Alamo Heights
I realize that this is off the topic of your original question, but I recommend that you do *NOT* buy a WFCO converter-charger. Everyone seems pleased over the long term with Iota and Intelli-Power 3-stage converter-chargers. Thus far in about a year of service I have had no complaints about my Powermax 3-stage unit, but the WFCO that it replaced annoyed me with periodic variations in its voltage that were easily visible in the brightness of the lights in the trailer.
— David
11-13-2013, 07:22 PM
1973 Argosy 26
Chandler
Yeah, I have heard good and bad about several brands, and I can get a good deal on an Intellicharger from Best Converter. Have you had any dealings with Randy there? I hear he is a good person to have in your corner.
― H.L. Mencken
11-13-2013, 09:23 PM
Alamo Heights
I have bought 2 converters from Randy (for 2 different trailers) and a couple of other items. I have only good impressions from the transactions and pre- and post-sale communications from him.
— David
11-13-2013, 10:16 PM
Moderator Emeritus
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna
Greetings SkooterPop!
Something else that you might want to consider since you are going with a solar installation in your coach is an Inverter/Charger charger. While an Inverter/Charger will initially be somewhat more expensive than a converter/charger the added versatility when boondocking and relying on solar can be a nice feature to have. Part of the solar installation on my Overlander included replacing its converter/charger with an Inverter/Charter, and I have no regrets about the decision . . . after nearly a decade of use it has proven to be a very useful and reliable system.
Good luck with your project!
Kevin
Kevin D. Allen
WBCCI (Lifetime Member)/VAC #7864
AIR #827
1964 Overlander International
11-14-2013, 05:31 AM
Naples
Kevin
I was going to chime in on tis topic, but hesitated for fear of being accused of being too commercial…..but the dam has burst!
If you want the best (and I say this unequivocally) method of charging your batteries, replace your converter/charger with an inverter/charger. Just a few of the benefits:
• Full temperature compensation to properly control the charge voltage in a wide range of ambient temperatures
• Fully adjustable absorption times that are sized to the capacity of your battery bank
• Adjustable charge profiles that match the exact needs of your battery bank
• Full battery monitoring capabilities with the addition of a 500 mV shunt
Plus, you get the extra added feature of being able to produce 120VAC power from your batteries when off-grid.
An inverter/charger is light years ahead of any converter. It is an especially good fit with solar for off-grid use.
lewster
11-14-2013, 08:56 AM
1973 Argosy 26
Chandler
OK, I'm definitely going to look into inverter/chargers as a combination component and enhancement to my solar install. I appreciate all the feedback. I always ask about down-sides when considering alternative paths...so, are there any downsides or limitations to the inverter/charger combination units, other than an apparently higher cost?
Thanks again for your input!
11-14-2013, 09:06 AM
1973 Argosy 26
Chandler
What would really be sweet is to find a way to intelligently switch an inverter/charger combination to the existing outlets in the coach when not plugged into shore power, rather than having to find a place to locate the inverter so as to reach all the appliances. I believe I read about a component that could be added that would recognize I am off grid and then (and only then) energize the inverter. If I remember it was used to control the inputs of wind and gas powered generation units, when used in combination with solar.
I'll have to look into that too.
11-14-2013, 09:08 AM
Naples
Only down side, aside from cost..........is the need to have it properly installed by someone who is intimately familiar with the interactions between your trailer's AC and DC systems.
I recently finished installing a 900 watt solar charging system on a new Mobile Suites 5th wheel that had a factory installed Magnum MS-2812 inverter charger and I had to re-wire said inverter to NEC and Magnum specifications.....something that the factory had NO CLUE about doing properly.
Choose your installer very carefully!!!!
lewster
11-14-2013, 10:00 AM
1973 Argosy 26
Chandler
Since I have done everything else on this restoration myself, I guess that would be me. I would like to have someone with your experience level look over my proposed wiring and make sure it is sound before I hook everything up on my solar installation. I have a diagram that I roughed out if you would be willing to take a look.
I'd rather pay you as a consultant and learn to do the work myself, than to just pay someone to install everything. I've always been that way. I figure if I get in trouble down the road, and there's nobody around to help me, I can figure it out myself and get back in business faster.
Let me know if you'd be interested in looking over my diagram as a start.
Alamo Heights
It's generally a good idea to only supply a subset of the outlets from your inverter unless you have a big honking battery bank. For example, if you wired it in to supply every outlet and forget to switch the refrigerator to gas-only operation, when the inverter supplies 120v to the outlet the refrigerator is plugged into, it'll dutifully switch over to 120v operation to "save propane" (while sucking your batteries dry.) Selective is good.
— David
11-14-2013, 10:22 AM
Figment of My Imagination
2012 Interstate Coach
From All Over
, More Than Anywhere Else
Keeping the microwave (if you have one) and the air conditioner off the inverter is good. Even if you have a big honkin' battery bank! Either one can drain your batteries stony dead in less time than it takes to say, "stony dead."
11-14-2013, 10:57 AM
1973 Argosy 26
Chandler
Hey I didn't even think of the fridge. I guess it wouldn't be prudent to have that or the A/C hooked up permanently on the AC circuit. I'll have to check the wiring out and see if there's an easy way to hard wire the inverter/charger to just the outlets desired, leaving out the A/C and the fridge outlet.
Thanks for the help figuring this out. Once I get the solar finished, I'll start tackling the convertor replacement, keeping your sage advice in mind.
Cheers!
11-14-2013, 11:04 AM
Full Time Alumaloafer
1966 24' Tradewind
Livingston
Though I have an converter/charger (Intellicharger) and a small external inverter, I agree wholeheartedly with Lewster. If you can afford it, go with the Inverter/charger and definitely use a professional if you are not 100% sure you know what you are doing. Not only can a botched installation leave you in the dark, but can even be a fire hazard.
Lou Axt, Jr.
1966 Tradewind
1969 Chevy C10
_____________
Phillipians 4:13
