Old 11-14-2013, 11:00 AM   #15
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
Originally Posted by SkooterPop View Post
What would really be sweet is to find a way to intelligently switch an inverter/charger combination to the existing outlets in the coach when not plugged into shore power, rather than having to find a place to locate the inverter so as to reach all the appliances. I believe I read about a component that could be added that would recognize I am off grid and then (and only then) energize the inverter. If I remember it was used to control the inputs of wind and gas powered generation units, when used in combination with solar.
I'll have to look into that too.
It's generally a good idea to only supply a subset of the outlets from your inverter unless you have a big honking battery bank. For example, if you wired it in to supply every outlet and forget to switch the refrigerator to gas-only operation, when the inverter supplies 120v to the outlet the refrigerator is plugged into, it'll dutifully switch over to 120v operation to "save propane" (while sucking your batteries dry.) Selective is good.
— David
Old 11-14-2013, 11:22 AM   #16
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Keeping the microwave (if you have one) and the air conditioner off the inverter is good. Even if you have a big honkin' battery bank! Either one can drain your batteries stony dead in less time than it takes to say, "stony dead."
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 11-14-2013, 11:57 AM   #17
SkooterPop's Avatar
1973 Argosy 26
Chandler , Arizona
Hey I didn't even think of the fridge. I guess it wouldn't be prudent to have that or the A/C hooked up permanently on the AC circuit. I'll have to check the wiring out and see if there's an easy way to hard wire the inverter/charger to just the outlets desired, leaving out the A/C and the fridge outlet.
Thanks for the help figuring this out. Once I get the solar finished, I'll start tackling the convertor replacement, keeping your sage advice in mind.
Cheers!
SkooterPop is offline   Reply With Quote
Old 11-14-2013, 12:04 PM   #18
Full Time Alumaloafer
louaxtjr's Avatar
1966 24' Tradewind
Livingston , Texas
Images: 12
Though I have an converter/charger (Intellicharger) and a small external inverter, I agree wholeheartedly with Lewster. If you can afford it, go with the Inverter/charger and definitely use a professional if you are not 100% sure you know what you are doing. Not only can a botched installation leave you in the dark, but can even be a fire hazard.
Lou Axt, Jr.
1966 Tradewind
1969 Chevy C10
_____________
Phillipians 4:13
louaxtjr is offline   Reply With Quote
