Old 02-27-2017, 10:54 AM   #1
easler7267's Avatar
2015 25' FB Flying Cloud
Hanscom AFB , Massachusetts
Questions about backup camera mounting (2017 Ford F-150 system)
Hello Airstream experts! My wife and I are in the process of ordering a 2017 Ford F-150 Lariat to replace our current tow vehicle. One of the nice features of the new F-150 is the camera that can mount to your trailer that integrates into the system so you can see what's behind you when parking the trailer. It's nice that it integrates and you don't have to deal with a second screen.
But i have a couple of questions about the installation that I'm hoping you experts can help me with:
1. Have any of you mounted a camera yourself? How did you do that? or did you pay someone to do that and if so, who? Airstream dealer? I'm nervous about drilling any holes in my Airstream myself for camera mounting brackets.
2. The camera isn't wireless. It comes with a really long cord. Have any of you found a good way to route that cord through, over or under your Airstream to be able to plug it into the back of the tow vehicle? If so, how did you do that? Is there a logical place to route those sorts of things? I would like to avoid having a big cord flapping around or being visible if it's possible to hide it somehow.
Thanks in advance for any advice or comments!
Dex & Kelly Easler
2015 Airstream Flying Cloud 25FB Twin
easler7267 is offline   Reply With Quote
Old 02-27-2017, 11:08 AM   #2
Rgentum's Avatar
2016 27' Flying Cloud
Woodinville , Washington
I mounted the camera on the inside of the trailer, under the storage cabinet at the top of the rear of the trailer. See attached photo. The camera is the black rectangle directly under the seam between the two storage doors. I drilled a hole on the underside of the storage cabinet and routed the cable through it, along the inside of the storage cabinet, and then through another hole on the underside of the cabinet at the inside edge of the trailer. The cable goes down from there alongside the inside of the window and through the floor & then up to the trailer hitch.
Alta & Richard, Seattle area --- WBCCI 8873
"Aurum": 2018 Ram/Cummins 3500
"Argentum": 2016 AS FC 27 FB
"BigDog": M Harlequin Great Dane, 150 lb
WL7Z --- NAUI --- WSBA
Rgentum is offline   Reply With Quote
Old 02-27-2017, 11:19 AM   #3
easler7267's Avatar
Thanks for your response! One more question, after you routed through the floor to go through the length of the trailer, how did you route the cable out of the inside of the Airstream to get to the hitch?
Old 02-27-2017, 11:31 AM   #4
Rgentum's Avatar
Under the right side of the trailer, mostly following and attached to pre-existing lines etc. There's a gap getting around the two axles. Buy a creeper for $25 at Harbor Freight and look for lines, holes, etc. under the trailer to attach the cable to with cable ties; and if nothing there, drill a 1/4" hole to put the cable tie into.
Old 02-28-2017, 11:45 AM   #5
rvb
rvb's Avatar
1977 Argosy 28
Euless , Texas
1/4" conduit under the trailer
I am thinking or installing a rear camera as well, but, am considering running a 1/4" pvc conduit under the trailer, up over the axles to the rear, secured with plastic clamps screwed to the belly pan. It is available at any big box hardware store and pretty inexpensive. I would recommend pulling the the wire during installation.
rvb is offline   Reply With Quote
Backup camera info 2017 23FB Signature troubadour1 2016 - Current International 9 03-29-2017 07:30 PM
Rear View/Backup Camera system westernjeep401 Airstream Classifieds 0 10-13-2015 05:28 AM
Backup Camera as Rear View Camera Rapa Nui Tow Vehicles 10 07-10-2013 04:37 PM
Replacement backup camera system humoso Land Yacht/Legacy Motorhomes 2 05-01-2009 11:11 AM
Backup Camera System CarlGeo Airstream Motorhome Forums 3 09-03-2007 12:24 PM
