Old 08-26-2011, 07:17 PM   #1
Lothlorian's Avatar
Loganville , Georgia
Question about ground block for Dometic circuit board
I am replacing my rm2607 dometic circuit board with a Dinasour 711-p cirucit board. This refrigerator is going into a 1960 airstream. Explain the ground blocks function? I don't have a ground block and I need to figure out how to properly ground this circuit board.
I have been told to just ground it to the frame. The board has a ground that goes to the screw that attaches the circuit board to the refrigerator and a ground that goes to the ground block that I do not have.
Brian
Brian & Adrienne
Lothlorian is offline   Reply With Quote
Old 08-26-2011, 08:46 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
You can ground it to the inner shell of your trailer. Just make sure the inner shell of the trailer has a ground wire going to the frame of the trailer.
The more grounds the better, circuit boards are not cheap.
Old 08-27-2011, 10:28 AM   #3
Lothlorian's Avatar
I got the new 711-P dinasour circuit board in and everything seems to be working fine. The AC heating element is hot and we are waiting to see if it cools down. The control panel is working fine.
Brian
Brian & Adrienne
Dinosaur board question cathy624 Water Heaters, Filters & Pumps 6 12-10-2015 06:07 PM
Circuit board resource for RM 3804 violiniste Refrigerators 2 08-25-2011 03:32 PM
Water supply question at a state park. meadowlm General Repair Forum 6 06-07-2011 10:57 PM
Water heater needs new circuit board. Boondocker Water Heaters, Filters & Pumps 0 04-30-2011 08:07 AM
'67 Caravel Restoration Electrical question vonzellen 1966-68 Caravel 1 01-15-2011 07:25 AM
