Old 10-21-2008, 09:03 AM   #1
boondockdad's Avatar
2008 30' Classic S/O
Dearborn , Michigan
Images: 21
Q 4 Trimetric 2020 installers
installed the 2020 unit, 100A shunt, and 35' supplied wiring harness.
walked through the setup procedure- volt setting, amp, shunt... only setting not defined was the battery bank capacity...
i can't find the aH rating on my OEM interstate batteries.. website doesn't list either-- but, from what i've read, not having the amp-cap defined, should not effect what i'm having a problem with...
the ampere draw reading..
at rest, with the 'kill switch' off.. getting a -.05 reading (seems legit between the 2020 itself, and the CO detector)
but the fantastic fan, on HIGH reads -.92
thats well below the manufacturers listed 3.0A draw on that unit
all the other items seem to be reading low
any thoughts?
A family of eight, blogging all things camping from our Airstream
https://boondockdad.com/
boondockdad is offline   Reply With Quote
Old 10-21-2008, 09:18 PM   #2
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
It'd be nice if manufacturers also provided a 'nominal' current demand but their legal departments prints the maximum it will draw under adverse conditions.
Group 24 75 to 85 Amp hours
Group 27 80 to 105 Amp hours
Group 31 90 to 120 Amp hours
Golf cart 180 to 220 Amp hours
Pick your type and start with the low figure and see how a 3-5 hours "at rest" voltage reading stabilizes at after a normal daily routine to see if you have more capacity than the low side figures given...
Old 10-28-2008, 08:42 AM   #3
just jd.
5cats's Avatar
2007 20' Safari SE
San Diego , California
Maybe your shunt isn't intercepting all the negative leads to the battery bank(s)?
With the factory inverter option, my coach was rigged with dual sets of battery cables. I had to contrive a single point of contact through my shunt that wasn't there before. (more)
2007 20' Safari SE/LS // 12063 //CA-5// ("ex") 2916
5cats is offline   Reply With Quote
Old 10-28-2008, 08:46 AM   #4
Dearborn , Michigan
Images: 21
thanks 5... I will definitely check this...
New Trimetric RV Battery monitor 68 Overlander Commercial Listings 14 04-15-2009 11:14 PM
2020 Committee reports eubank WBCCI Forum 49 07-30-2008 08:00 AM
Compare Link 10 with TriMetric guy99 Commercial Listings 0 06-01-2007 09:54 AM
Trimetric 2020 davidz71 Electrical - Systems, Generators, Batteries & Solar 3 01-30-2007 08:29 PM
Trimetric 2020 meter nickcrowhurst Electrical - Systems, Generators, Batteries & Solar 3 02-26-2005 07:49 AM
