Old 03-25-2005, 01:19 PM   #1
Tin Tortuga's Avatar
South Lee , Massachusetts
puzzled by fuse at battery connection
Hi folks.
I am puzzled by the 50 amp fuse at the battery leads inside where it connects to univolt. (Which doesn't seem to work)
Wish this was a better drawing . Make sense to anyone ??
(ignore drawing , it changed when i posted)
RED-_______________________ _____________
fuse > univolt
Black_______________________/_____________
Tin Tortuga is offline   Reply With Quote
Old 03-25-2005, 02:47 PM   #2
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
yep
yes, the negative connection is fused, this is to allow the interior of the trailer to clear a short circuit AND still allow the the trailer break away to work. it may also give some limited protection in case the battery is installed backwards.
the break away circuit is not fused as it should be.
john
you call them ferrets, i call them weasels.
Old 03-25-2005, 03:13 PM   #3
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
Univolting
Does it look something like this, minus (a lot of) the jerry-rigging present in mine? As to it not working, I assume you mean the Univolt itself. You can, of course, measure the DC output itself directly. From what I have read on the Forum, they all “Hum” when turned on and functioning normally. The one in my ’73 Overlander is very, very loud. I intend to replace mine with something more modern as part of the overall rebuild of the trailer. This partly due to its advanced age, the noise it makes, the weight and it appears to putting out only about 11 volts (I haven’t had a chance to check it with a digital meter, yet, only an old style analog meter).
Be very careful around this thing, as they say.
ID:	11181   Click image for larger version
ID:	11183   Click image for larger version
www.nesa.org
Air No. 6427
Battery Location uwe 1970-79 Tradewind 23 12-02-2015 07:41 AM
Battery Dead - Again & Again eraffety Airstream Motorhome Forums 10 11-01-2002 11:03 PM
igniton switch and the mystery of the dead battery Curtis-79MH Airstream Motorhome Forums 3 10-25-2002 02:58 PM
Battery Dead/Power jack question jcanavera Jacks, Stabilizers, Lifting and Leveling 34 08-16-2002 01:51 PM
Battery drained while on shore power 68International Electrical - Systems, Generators, Batteries & Solar 4 07-15-2002 02:51 PM
