Old 05-07-2006, 04:56 PM   #1
1965 26' Overlander
Acworth , Georgia
Proper Grounding of 120V input
Folks,
Been troubleshooting problems with A/C, and noticed the 120V cable into the main electrical box in rear of trailer has both hot and neutral properly wired in braker box, but the green ground is cut off. The 120V outlets and appliances are grounded inside the box to a traler frame grounding wire. This doesn't seem safe.
Is there a reason whe the 120V input would be done this way? I would assume the appliance and outlets should be grounded all the way out of the trailer to my house/generator/park hookups. Am I wrong?
Phil
PhilMateo is offline   Reply With Quote
Old 05-07-2006, 06:09 PM   #2
WHR
1981 24' International
1967 17' Caravel
West Richland , Washington
Hi phil - I am also curious about any response you will get. I have a 24 foot international caravelle and discovered my ground was disconnected from the frame. Will watch your responses. Wade
WHR is offline   Reply With Quote
Old 05-07-2006, 06:17 PM   #3
steelbird312's Avatar
1956 22' Safari
2000 39' Land Yacht XL Diesel w/slide
Crossville , Tennessee
Images: 11
Phil, Are you saying your shore power cord does not have the ground wire grounded to the trailer anywhere, and that the trailer wiring is not connected to the trailer either?
If it were mine, it would be tomorrow! Since that is the way new ones are wired aas well as houses, etc I would want mine the safest it could be!
Some will reason that the jack as well as the stabilizers will effectively ground your unit but I'm skeptical about that.
steelbird312
2000 390 Landyacht XL
1989 29' Excella
WBCCI #6673 jerry Hodge
Have no intention of arriving at the grave safely, but rather to skid in sideways, chocolate in one hand,throttle in the other, totally worn out and screaming
"WOO HOO, WHAT A RIDE!"
steelbird312 is offline   Reply With Quote
Old 05-08-2006, 06:01 AM   #4
Over59's Avatar
Putnam , Connecticut
Images: 37
Three wires come from the cameground hookup, hot, neutral, ground. They need to stay separate in the trailer. Disconnect the AC and look inside your AC fuse panel. Are the neutral and ground connections common, that is are they connected electrically? Is there a third wire in the outlets. If not, prehaps someone modified a two wire system by adding grounded receptacles and grounding directly to the trailer. If so and your trailer is not connected to the service ground when plugged in at the campground I would fix it before using it again, the trailer could become hot and you become the ground when you touch it. The additional problems is how the fuse panel is mounted. Is the neutral electically connected to the trailer shell via the mounting. The neutral and ground "float" in a trailer and only come together out in the service panel at the campground, not in the trailer.
Over59 is offline   Reply With Quote
Old 05-08-2006, 06:01 AM   #5
RoadKingMoe's Avatar
2001 34' Limited
The State of , Ohio
The purpose of a ground wire is to provide a low resistance path (i.e. a short) back to the breaker panel, where the ground is tied to the neutral (completing the circuit), in case the hot wire touches an appliance case, or in this situation the body of the Airstream. This will cause the cirucuit breaker to trip, removing power.
Without it, if the hot wire touches the Airstream body, you can be electrocuted if you walk up to the Airstream and touch it. It can even electrify the ground around the trailer enough to paralyze you even if you don't touch it.
Whoever disconnected your ground wire should be sent to jail. That they did may indicate your trailer has a problem with the hot wire touching the trailer somewhere and they did this to stop the breaker from kicking off.
Neutral and ground should NOT be bonded together in the trailer, only at the campground source.
Maurice
Old 05-08-2006, 08:20 AM   #6
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Is that why I do not show a ground with my 3 LED indicator when I am hooked to my generator?
Richard
Old 05-08-2006, 09:00 AM   #7
1984 31' Excella
Norfolk , Virginia
Images: 11
Proper Grounding of 120 V input
House wiring (as it applies to our 120 volt trailers) goes like this:
BLACK WIRE: Goes to the Main Breaker. The Main Breaker supplies the Main Buss that the circuit breakers plug onto. Turn the Main Breaker off, the house is disconnected from the outside world.
WHITE WIRE: CIRCUIT GROUND. This provides the return path for the electricity supplied by the Black wire to return to the sourse to complete circuit.
GREEN WIRE: Safety Ground. This wire connects to all the round prongs of the 120 V plugs. It goes directly to the ground rods driven into the ground outside your house. Ther is supposed to be at least a number 6 size wire connecting the ground rods to the ground buss in the circuit breaker box. Why we don't connect to the water pipes is another story.
Note: If you measure the resistance between the ground buss and the white buss in the circuit breaker box it will be less than one ohm(for pratical purposes a dead short).
Our Trailers:
BLACK WIRE: On our shore power power cord connects to the Main Breaker. The Main Breaker likewise supplies the Main Buss inside the Circuit Breaker Box that the Circuit Breakers plug on to. Like the house, turn this Main Breaker to off and all 120 V power to the trailer is turned off.
WHITE WIRE: CIRCUIT GROUND. Same as in your house. Connects to the White wire buss in the Circuit Breaker Box.
GREEN WIRE: Connects to the Ground Buss in the Circuit Breaker Box. This Ground Buss MUST be connected to the Frame/Skin of the trailer, if not, it is possible (probable), in the event of a short(black wire comes in contact with the skin or an appliance shorts out) that the skin of the trailer could have 120 V on it. In short (no pun intended) if you touch the trailer barefoot, you will get shocked.
GFI: GFI recptacles and GFCI Circuit Breakers compare the amount of electricity flowing toward the appliance on the Black Wire and with that current flowing back to the source on the White Wire. If the two amounts are not equal the Recptacle pops or the GFCI Breaker will trip. The only reason that the power flowing down the White Wire back to the sourse will be different is when there is a short and a portion of the power delivered to the appliance by the Black Wire is now flowing back down the Green(ground) wire. This is why it is so imporntant that the Ground wires(Green Wire or Bare Wires) only attach to the ground bus in the Circuit Breaker Box. If you have connected the White Wire to the Ground Wire(Green or Bare Wire) anywhere in the trailer or in the house at a recptacle, the return current will divide between the White Wire and the Ground Wire(Green of Bare wire) and the GFCI Breaker will trip because it sinces that only half the power is returning on the White wire and trips(does its job).
At least thats my take on it.
Beginner
Beginner is offline   Reply With Quote
Old 05-08-2006, 09:08 AM   #8
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
just to add, we had a scarey (and "shocking", literally, for some) experience at our recent rally, when it was discovered that there was a wiring fault in the campground's electrical system. Turned out to be a faulty ground at the transformer that supplied a large section of the campsites. All "new" stuff, too...a recent upgrade. It took the electrician a long time to figure it out, too, because everything "appeared" to be correct, was all new, had just been inspected by the PTB, etc, etc. and STILL, with all those safeguards, was not right.
Several campers got zapped by touching their trailers. turns out, we were all "HOT". (those of us on this particular branch). voltmeter testing from the shell of one trailer to a steel anchor in the ground showed 120vAC
so even if your trailer is "right"...you still need to be wary. I'd like to know if there is any reliable way to test for this condition before hooking up.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 05-08-2006, 09:20 AM   #9
1984 31' Excella
Norfolk , Virginia
Images: 11
Proper grounding of 120 V input
If you have on of those little testers that you can plug into a recptacle and tell if it is properly grounded you can plug it into the circuit breaker box at the campground (the 120V house recptacles) and see if it gives you a good reading there. If not, have the campground people try and explain why your little tester is giving you a faulty indication( I can't think of any reason plausable). The best version is to get an adapter that will plug into the socket that your trailer will be pluging into to a common house recptacle then plug your tester into that for a good reading. You should get a good reading. Don't let them snow you.
Old 05-08-2006, 09:27 AM   #10
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
is there a test you can do with a common voltmeter?
Air:291
Wbcci: 3752
'73 Safari 23'
Old 05-08-2006, 09:41 AM   #11
1984 31' Excella
Norfolk , Virginia
Images: 11
Exclamation Proper Grounding of 120V input
Theoretically (uh-oh) you should get 120V from one of the rectangular openings where the flat prong goes to the other rectangular openings. Then from one of the rectangular openings to the round opening you should get 0V. From the other rectangular opening(where the flat prong goes) to the round opening you should get 120V. Then from the round opening to the metal circuit breaker box you should get 0V.
I like using an incandesent light bulb/wocked and pigtails because the light bulb draws enough current to tell the truth. A meter draws so little current (micro amps) that in some instances it will lie to you. That 100 watt blub draws 1 amp and will force thd issue but not enough to cause injury. By the way, if the bulb flaches and goes out and so does its replacment, or if it pops(explodes), you probally have 220V where you should have 120V or you have just blown up a 12 volt light bulb.
Beginner
Old 05-08-2006, 10:20 AM   #12
2001 34' Limited
The State of , Ohio
That is correct. Small inverter type generators do not bond neutral with ground. They rely on a GFCI for protection.
Maurice
Old 05-08-2006, 10:52 AM   #13
ibedonc's Avatar
1983 31' Excella
Caldwell , Texas
the guy I got my 83 from had the white wire going to one side of the bus and the black to the other and not though a main break ( both sides should been jumped ) of course nothing worked I wired it like my house , so I need to move green to trailer ground
ibedonc is offline   Reply With Quote
Old 05-08-2006, 11:01 AM   #14
1984 31' Excella
Norfolk , Virginia
Images: 11
That's Scary. That means that inorder to ensure safety when running your generator, you have to establish an eath ground system(#6 solid wire running to two 8 foot ground rods driven in the ground at least 8 to 16 feet apart).
Saggy Bottom ( rear end ) smily Repairing/Replacing Floor &/or Frame 127 10-01-2006 08:28 PM
proper rivet gun for AS oldvws Ribs, Skins & Rivets 12 11-23-2002 09:04 PM
Photos on the Portal Page. WE NEED YOUR INPUT! Vote please! Andy R Our Community 6 10-25-2002 08:55 AM
Best way to reground airstreamcaravel Electrical - Systems, Generators, Batteries & Solar 3 03-08-2002 07:20 PM
